Question about Dishwashers
Top rack not washing. All soap not cleaned out of dispenser
Glasses not washing. all soap not washed out of the dispenser.
    Problem Solver:
  • 3 Answers
This may sound ridiculous, and I'm no "expert", but are you starting out with really hot water (i.e. running the faucet at the kitchen sink until hot water comes out)? My wife refuses to do this and she encounters the same problems: dirty dishes and leftover soap. *I* make sure that hot water is readily available to the dishwasher (even though it's *supposed* to heat it for you) and never have either issue.
Posted on Feb 07, 2012
Testimonial: "Solution 3 was the correct solution to the problem. Amazing how much junk accumulated in the well to the suction of the pump. The pump was starved of water so that water did not flow to the racks. Thanks."
SOURCE: Kenmore Dishwasher leaving SAND behind
1. Remove the top rack and lower rack.
2. Remove the lower spray arm by holding the top of the center hub and rotating spray arm counter clockwise.
3. Remove water tube feed from the back wall of the dishwasher by unclipping at top and back. Pull towards you and lift tab at the bottom on the big tube to remove the plastic clip from main water feed.
4. Remove the main water tube by turning quarter turn clockwise, then lift off. Keep the center hub from falling out so you don't lose the plastic washer.
5. Using a star tip screw driver; remove the four screws and lift off the filter cap assembly. The assembly consists of the screen filter and the food trap grate (The outer edges look gear like).
6. Look down inside this area and clean out anything foreign. usually there will be seeds, paper, and other gook. I used tweezers, toothpicks, and needlenose pliers. I remove from my dishwaser quite a bit of paper, two wooden match sticks, lots of undissolved soap etc.
7. When you have removed as much as you can, put everything back together in the order you removed it.
8. When you run the next cycle, you should immediatly hear more noise to indicate that you have cleared the pathway that allows water to flow at its intended pressure.
Posted on Nov 13, 2008
catriver
  • 878 Answers
SOURCE: dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Posted on Nov 25, 2006
ve3wtj
  • 147 Answers
SOURCE: top rack not cleaning
Some dishwashers have a telescoping nozzle in the center on the bottom. If this is blocked by a large pot in the middle of the bottom tray, the nozzle will only extend up into the pot, and not be able to spray the entire top rack.
Also, some models have an arm mounted in the top. Check and see if it can spin freely, and if it's nozzles are clogged.
De-clog by soaking the part in vinegar.
Posted on Sep 17, 2008
lancer721
  • 229 Answers
SOURCE: dishes still dirty after heavy wash cycle
There is a screen on the drain area of the bottom of the dishwasher that needs to be cleaned. It has a plastic mesh screen on it - you can't miss it. Second get an old toothbrush and clean out the little jets on the washing arms that spin around. You will notice these holes are clogged up with calcium deposits etc. Those things done you will have a new dishwasher again. You need to do this every 6 months or so. Also use a rinse conditioner for a while to assure the jets are clean. Good Luck
Posted on Nov 29, 2008
kram26
  • 544 Answers
SOURCE: My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Posted on Mar 18, 2009
Ge Profile soap dispenser doen't fully open during wash
Pour boiling water into the dispenser, it may be gunked up with soap residue
Mar 21, 2017 | Dishwashers
Hi I have a Blanco dishwasher BFDw8 which is having poor wash results in the top tray I have tried all the trouble shooting things in manual. Investigated further by opening door during wash cycle several...
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Scrape away large pieces of food, bones, pits, toothpicks, etc. Burned on food should be loosened before loading. Empty liquids from glasses and cups. Foods such as mustard, mayonnaise, vinegar, lemon juice and tomato products may cause discoloration of stainless steel and plastics if allowed to sit for a long period of time. Unless the dishwasher is to be operated at once, it is best to rinse off these food soils. Load racks so that large items do not prevent the detergent dispenser from opening. If the dishwasher drains into a food disposer, be sure disposer is completely empty before starting the dishwasher.
just click on the above questions for more help the answer will come to the screen
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
Oct 05, 2008 | Dishwashers
Dishwasher deposits grit on inside of glasses on top rack
Hi, it sounds like your either using to much soap or the water is not hot enough. Use alittle less soap the next time and see if you have the same problem. Check the water temp after you machine fills for the wash the temp should be 120 or higher.
Clean out the filter and the back flush arm. Also clean the wash arms (every little hole.)
Jun 26, 2011 | Dishwashers
Dishwasher soap still in door after wash cycle, so dishes are not very clean. Soap dispenser cover is sprung open but soap (on both sides, wash and prewash) is still mostly where it was poured, only now...
Check for the right amount of water in tub. In this unit close to the lip of the tub after fill. If water fill is correct check movement of lower spray arm. Other possibilities delayed action of dispenser from defective wax motor. Most probable is wash motor. Start unit after fill and when was starts, open door and see if water is being pushed to the top rack and dripping from the top of tub. Motor is easy to install.
Oct 12, 2010 | Maytag MDB7100AWB Dishwasher
There has been a trail of dry soap on inside of door after wash is complete, also dried soap on some dishes in bottom rack as well as not being clean and on top rack spots on glasses and sometimes some...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 28, 2010 | Hotpoint 24 in. HDA900X Built-in...
Glasses in top rack not getting clean anymore.
-Have you changed the dishwasher soap recently? What are you using? Is the powder remaining behind in the soap dispenser?
-Have you removed the filter in the sump area, cleaned it and removed any debris under the filter. (watch out for broken glass that is almost always found in 5 year old dishwashers.)
-You are running water at the sink until it gets hot, but you may still have problems if the heating element has failed. Recommend you check that element. If you can get to the element, check resistence of the heater to see if is has any at all.
If heating element checks out good, the next common problem is a failing wash pump motor.
Mar 30, 2009 | Whirlpool 24 in. DU915QW Built-in...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
UNDISSOLVED SOAP RESIDUE AND
I have the same dishwasher and kept having soap still in the dispenser at the end of the wash. Someone mentioned this, but what was happening is that the soap dispenser lid was blocked from fully opening by the top rack. You also typically have large pans in this area, so the water spray is blocked from getting under the half open lid well. I started opening the dishwasher after I heard the dispenser latch release, so the lid could fully open. After that, I had no problem with soap still in the dispenser. I started setting a timer to open and shut the dishwasher door about 20 minutes into the wash process (after the latch had released for the 2nd wash cycle), so the soap dispenser lid would be fully open. This was a pain, but it worked. The other thing to be careful of with this dishwasher is to ensure you have pushed the top rack in tight before closing the door. Look at the water connection for the top "spinner" and you will see how the plastic pipe fits up to the supply. If you don't have the rack pushed in tight, you get leakage around the connection and don't get good water spray from the top spinner arms. This can definitely affect the quality of the wash. You mentioned the dispenser lid is open when the cycle is complete, but that is because once you open the door it can fully open.
Mar 26, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Dishes not getting clean
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Dishwashers Logo
89 people viewed this question
Top Dishwashers Experts
Owen Barnes
