Question about GE DGE505N Multi-disc DVD Player
Dvd dge505n code lock problem
  • sajid sajid Jul 30, 2006
    code lock problem
Parental lock on cant eject dvd
1 try un plug and plug back in
2 if not work enter menu and look for settings and look for parental lock or ratings most codes are 1234 / 0000 / 5555 or 8888 but if you changed code i will not know
3 open dvd and look for rubber belt and cog then turn it until dvd draw opens ( UN PLUG FIRST )
hope this helps
MERRY CHRISTMAS
Dec 12, 2009 | JVC XV-N322 DVD Player
Cant play dvd baught in england. player baught in the usa
There are different region codes for dvds and the player may only be able to play dvds with a north american region code.
Sep 08, 2009 | Radio Shack Accurian LMD-5108A Portable...
Parent control lock
The parent control lock out code is 1234, you need to press yes then enter the code using the remote type in 1234 then press play button again and it unlocks the parent controls!
Jul 07, 2008 | Disney Princess DVD Player
Samsung region dvd problem
What I am saying is very generic, and does not apply to any one type of DVD player.
Apparently, for many models the region codes can only be changed a number of times, and then the unit locks. This is how most of these units are designed. It is probably locked to the last code used. The user instructions will normaly give an indication to the number of changes allowed.
When the unit is locked, it cannot be changed. The locked code is burned in to the EPROM of the DVD player.
You need a true multi region DVD machine. This would be a player that will not ever lock. There are some on the market. Carefully research this spec before making your purchase.
There are some models that will lock, but it is possible to patch them to not lock. The patching has to be done before the unit does get locked. You would have to explore the net to find this information.
Jerry G.
May 03, 2008 | Samsung DVD-HD870 DVD Player
Unlocking my region code
Open My Computer, right click the DVD icon and select properties,
click hardware tab at the top.
Select your DVD player from the list, click the Properties button, and then the DVD Region tab. Select the Country you want to change the region code to and click OK.
It should tell you how many changes you are allowed. When you have used them all it stays locked at the last one you chose.
Mar 26, 2008 | Computers & Internet
Philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Mar 23, 2008 | Philips Magnavox DVD/VCR Dual Player
Parental control code that i didnt set
The factory preset override code for the parental lock is 3308. This code, however, will NOT remove the parental lock code in place. This is just a code to get around the lock. I'm not sure how to dissable to code someone else entered...still trying to figure that out!
Feb 06, 2008 | Televison & Video
DVD not playing due to "Parental Lock" being set..
In the back side of your equipment mentioned that the regeion code.please check read the region code and try to play the same region dvd cd's.other cd's not possible to play with out chaging region code.you can contact the nearest service provider to chage the region.
Jan 15, 2008 | Sharp DV-NC55U DVD Player/VCR
Help
take it to a tech some one could have enterd a code by mistake.good luck
Mar 23, 2007 | GE DGE505N Multi-disc DVD Player
GE DGE505N Multi-disc DVD Player Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
