Question about Sony PlayStation 3 40GB System
PS3 Disk drive will not accept disk
I bought this PS3 off of craigslist, the guy fixed the YLOD but broke the ribbon cable clip on the mobo, i have managed to wedge a piece of a gift card in with the male end of the ribbon cable to keep it in place, now when I turn it on I no longer get the 800...... code for general malfunction, instead I get all the way into the XMD screen, but the **** blue LED is solid and I can not get around it, i have taken apart the drive and reset the gears but nothing. THe drive is one of the older ones without the infared sensor on the top instead it has the switches inside under the "deck" of the drive, If i set the drive so there is a disk inside then do the emergency eject the "deck" goes down and the cd will eject, but when I try to put the cd back in I can force it in until my finger meets the face of the drive but that's it, the motor never takes over and pulls it in; why would it? it thinks there is already a disk in it, Someone please help me fix my confused blu ray player. PS it is one of the old school drives that has the dual lenses, one red and one blue. Contemplating getting a new ribbon cable and new clips to hold it in place because I think one possibility is that I messed up the ribbon cable while wedging into place and some of the contacts are weak or not correct.
  • Allen Watts Feb 07, 2012
    By the way, Im not paying someone to fix it, I have already invested too much time in it to just turn it over to someone to see if they can fix it.
SOURCE: ps3 not pulling in cd's
get someone to take it a pat and see what the problem
Posted on Apr 27, 2009
SOURCE: My ps3 wont take the disk!!!! HELP ME!!!!!!
if you take the system apart, check the blu ray optical sensor. its the really small board on the top front of the BluRay player. if it is positioned wrong it wont accept disks correctly. its worth a shot, and a easy fix. if you dont want to try that , i would suggest sending it to sony or selling it.
Posted on Jul 23, 2009
phoenix09
  • 54 Answers
SOURCE: I just recently installed a new blu-ray drive into
ok sounds like you did every thing correctly and switching the board was in the right directio however the controller chip on your daughter board very well could be damaged since these boards rest directly overtop of the gpu and cpu the heat goes smack dab into the metal caing wich in some cases the case toushes the bottom of the daughter board resulting in a over heated controller chip
possible repair is
replacing that chip
with a infectus chip
i am still working on this problem
ive had 2 good repairs matching problem..hope this was helpful
Posted on Oct 19, 2009
SOURCE: PS3 Playstation 3 Disassembly, Forgot to Remove disc.
remove the 2 screws holding in the motor then rotate gear that has screw on top of it counter clockwise,,should drop everything to nodisk position then put back together
Posted on Jan 27, 2010
SOURCE: the ps3 froze and it can't read blu ray disk
You have the same problem i had just a couple of weeks ago you need to call sony and tell them your problem and send it in it will cost $140.Their phone number is 800-488-7669 .This happens when you play MW2 to much but its hard to stop its so fun.
Posted on Feb 16, 2010
Sony ps3 with kes-410aca laser not spinning
seems like u have a bad ribbon cable.. that can cause the problem.. i had the same problem with many consoles,
before u buy a new ribbon cable, try to clean all ribbon's connectors with a connector cleaner spray.
Feb 14, 2013 | Sony Playstation 3 Blu Ray Laser Drive...
Tip
Fix all your PS3 Problems
Send Your Console to Sony = $150
You need a PS3 Repair Guide = less than $35
THE NUMBER 1 GUIDE IS YLOD REPAIR WIZARD
This guide has proven permanent fixes for the following errors:
In order of the most common:
1.YLOD (Yellow light of death)
2.Green/Red/Blue Flashing errors
3.Disk Read Error/Blue ray Drive Error
4.Hard Disk Corruption
5.No Display Error
6.Red Screen Error
7.Freeze ups
8.Fix All error codes (8001050F)
9.Sync error
10.Blank Screen error
Need More Info On PS3 Repair guides and the YLOD repair wizard
on Aug 25, 2010 | Sony Playstation 3 (PS3) Console
I need help fixing a broken ribbon clip for the bluray drive of a ps3 what part do I order a replacment mother board or control board?
You can probally get a junk ps3 for parts and take the part you need off and re-sell it on craigslist or something. Look on craigslist for a ps3 for parts. Or you can call Sony and they will tell you the part number if you explain it to them. You will probally need the board that the clip is broke off of.
Jun 10, 2011 | Video Game Consoles & Games
The clip holding my ribbon from my blu-ray disk drive on my ps3 has broken so now the drive wont work..how can i fix it and how much will it cost?
These are extremely difficult to replace due to the minute connections they have to the motherboard. What you can try doing is using a very thin piece of plastic and wedging it in between the clip and the cable on the motherboard but it is a bit hit and miss as to whether or not it works. Usually it means you have to replace the motherboard.
Hope this helps
Sep 26, 2010 | Video Game Consoles & Games
Cannot start. The correct hard disk was not found.
As with many of us current and former PS3 owners you need to have your HDD (hard disc drive) replaces. sorry
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
Ps3 not reading games or dvds
the cable that went from the bluray drive to the console that was/could be being/be pushed. I removed the cable and reseated the cable (be damned careful if you try this. You have to lift a plastic flange and slide the cable out. a guy broke this flange and figured out that it holds the cable through compression and wedged it back on. So try not to break yours .
or
The problem seems to be that there are sensors under the bluray drive that may not be making contact with the base of the system. I have opened my unit before to fix a clicking noise. If you put very slight pressure over the area where the disk loads, your disk should begin being recognized.
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
2 disks stuck in ps3
You are A ******, try beating yourself with a hammer
Aug 22, 2008 | Sony Playstation 3 (PS3) Console
Disk tray
If the drive is physically incapable of accepting a disk you may have to send it to sony for warranty work. If you aren't under warranty you can still send it in for a nominal fee ($150) and they will repair or replace the unit. If you risk trying to fix it yourself by tampering with it sony will void the warranty and any factory work paid or not.
link- playstation.com use the support link to get the number for your region for returns.
Hope this helps.
Mar 27, 2008 | Sony Playstation 3 (PS3) Console
Open Questions:
Sony PlayStation 3 40GB System Logo
62 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
