Question about Magellan Maestro 4700 Car GPS Receiver
I want to hard reset my magellan maestro 4700
Its stuck on aquiring a signal
sids8065
  • 61 Answers
SOURCE: Magellan Maestro 3100 stuck on
you have a failed firmware install. If the rollback has not worked and is stuck on the magellan screen, it needs to be send to magellan repair center
Posted on Feb 28, 2008
AZJudy
  • 4 Answers
SOURCE: Magellan Maestro 4250
I just called Magellan.....1-800-707-9971. I got my 4250 for Christmas 2007 and never did register it. We did that over the phone and then he gave me a repair order and an address to send the unit to them. It will be fixed under warranty.....my only cost is the UPS or FED EX shipping. He said I will have it back in 7 to 10 days. OUTSTANDING service.
Mine was stuck on the blue screen.......and the pin reset did nothing.
SO......best of luck to you all......and I highly suggest calling Magellan.
Judy in Arizona
Posted on Aug 23, 2008
  • 3 Answers
SOURCE: My Magellan maestro 3225 wont charge or start up
Same here - the problem, at least with mine, is that the power pin on the unit has become loose and not making contact with the machine - thus will not charge most likely from pluging and unplugging it in multiple times and breaking the connection inside the unit - FWIW, this GPS a real piece of **** and I have already replaced it with a Garmin- I'm trying to figure out how to take it apart to see if I can solder the power pin back in place but it is not as easy as removing the 4 back screws...
Posted on Jan 24, 2009
  • 1111 Answers
SOURCE: hi i have just bought a magellan maestro and can
you say the voice directions are not working, but does the voice work at all..like when you scroll back through the screens, it should say back ect ect. if the voice does not work at all, ck the speaker icon on the main map screen to see if its muted, indicated by a slash through the icon..if it is not on mute, go to the system folder the to the sound tab go in there and make sure its not muted in there, if it is, unmute it and restart the gps..its a common problem on these magellan if the battery is run to low or completly dead which causes more problems. if all else fails, do a hard reset
Posted on Jun 26, 2009
  • 23 Answers
SOURCE: My Magellan Maestro 31100 won't power on
You could have a defective power connection in your Magellan Maestro 3100 which will not allow you to charge the internal battery or power on your unit.
You may try to contact Magellangps.com or Autonav2000.com to see if they can provide you with repair service.
Might be cheaper to purhcase another Magellan Maestro than spend the money on repairs.
Good Luck
Posted on Apr 03, 2010
No signal
Your GPS is defective. Contact Magellan for repair return instructions.
Nov 05, 2012 | Magellan Maestro 4700 Car GPS Receiver
Magellan 4700 stuck at acquiring signal. nothing else happens. is there a fix?
on some units this may take awhile to load depending on the area you are in. mine does the same thing. if it really never finds the signal and it does this continually then try to reset it
Aug 16, 2011 | Magellan Maestro 4700 Car GPS Receiver
Maestro 4040 satellite is "stuck" and will not update to current location
make sure it has a good charge on it, then turn it on and find yourself a paper clip or something similar...looking at the 4040 screen, look on the left side of the gps near the bottom you will see a little pin hole (thats the reset)..use the paper clip to depress the reset, you will know you have reset it when the unit restarts...now take it outside in clear view of the open sky and let it there for up to 30 minutes to allow it to aquire the satellites...you will know they are locked on when you see a few green bars on the top right of the map screen.
if you want to know how to prevent this in the future, post back here.
bill
Aug 18, 2010 | Magellan Maestro 4040 GPS Receiver
How do i reset to factory settings?
www.magellangps.com/assets/.../magellan_roadmate_series_en.pdf
http://support.magellangps.com/support/
manual and help site
May 21, 2010 | Magellan RoadMate 700 GPS Receiver
My magellan position froze in Colorado and stays frozen.
try a hard reset. start the gps and using a paper clip insert it in the little pin hole on the side of your 4040 and take the gps outside in full view of the open sky and let it aquire the satellites, it may take up to 30 minutes it lock on to the satellites. if that fails, follow the link below to update the unit to the latest firmware for the 4040 you must register it on the magellan site before they will let you download anything.
Aug 15, 2009 | Magellan Maestro 4040 GPS Receiver
My maestro 4050 stopped receiving a signal from the satelite
try the hard reset, set it out to the open sky for a few minutes (may take as much as 30 min) to acquire the sats
Jul 01, 2009 | Magellan Maestro 4050 GPS
have you updated the maps on it? if no try and update the maps also do a firmware check to see if you need an update.
Nov 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
There is a RESET button on the bottom of the unit on the left side
Nov 22, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4700 Car GPS Receiver Logo
158 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
