Question about Kitchen Ranges
Hot poinbt gas stove , mouse inside,
I turned on my stove for the first time since spring and this awful smell came out. I realized it was the mouse my cat brought in last July and it nested inside the stove. It smells so bad. I cant seem to see a way to take stove apart. HELP!
  • lrjm45 Jan 10, 2009
    I too just bougt a used gas range and the insulation is ruined. I noted that you used pink house insulation. Is this type safe for a gas range? (meaning able to stand a high temperature unlike an attic or house wall)
    I thought about doing this becasue the parts would be over $100 from a parts store.
    lrjm45@comcast.ner
We had this happen recently. The smell of urine got to be too much. My wife wouldn't even go into the kitchen. I took the stove apart. the insulation under the range, which is where he was living, was soaked in urine and **** .I removed all the insulation. Spoke to a repair man. Replaced insulation with pink house fiberglas insuation and gave it a good cleaning. Smeel is gone. Repairman said this happens all the time and is a an easy but labor-intensive job. Call someone to do it if you aren't comfortable taking your stove apart.
Posted on Nov 11, 2008
Igniter knobs on my gas stove turn just enough to let gas escape.
There isn't much you can do to the stove outside of buying a stove that has standing pilots or shutting off the gas each time you leave the kitchen. This is a problem with the pilotless design. If the knob isn't turned far enough the activate the spark switch, gas can escape without being lit. Vigilance is your only answer outside of the solutions suggested.
Apr 28, 2013 | Kitchen Ranges
Smells like something died in there
hello, There is nothing inside that unit that can cause an odor. Most likely something did die in there like a mouse they love to live in stoves, I see it all the time...please dont forget to rate me thanks
Jun 07, 2011 | Whirlpool Gold GW399LXU Gas Range
Small gas leak smelled inside house from GE Adora (just 2 yrs old). Have moved stove and have put soapy water with paint brush on every connection including regulator...don't see any leak evidence...any...
You may have to use dish soap straight, do not use the brush. I use an old spray bottle and dish soap straight, not watered down, to find my leaks. Gas is a very low psi. Soapy water will not bubble up. It can and will just be pushed out of the way. Do not forget any other gas appliances in the house, hot water heater, stove, any thing that uses gas. Please check all. Recheck your stove and even any connections inside, on/off valve etc. Hope this helps Fixya up.
Dec 13, 2010 | Microwave Ovens
Won't get hot, smells like gas
Most of these new fangled gas stove feature a silicone carbide ignitor to light the oven. Older stoves used a standing pilot light. As silicone carbide ignitor age a little they tend to get weak and fail to open the gas safety vave sufficiently enough for ignition. Take a look
Jul 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Jun 27, 2009 | Tappan TGF657 Gas Kitchen Range
I have a Garland Stove and Oven. The oven is not working right.
Hi there, most of the newer unit parts are available still, but not seeing it makes it hard to guarantee. I would advise calling a Factory Authorized Servicer in your area, having a problem with gas entering the oven, and not igniting is a serious problem, and it sounds like the pilot is lit in the oven, but could be malfunctioning.
Here is the telephone for Garland: Tel: 1.800.424.2411.
They can recommend someone in your area, or check your local phone book, for Restaurant repair companies, and contact them.
Hope that helps, and thank you.
Feb 04, 2009 | Garland H283 Gas Kitchen Range
Oven over heats/gas smell
Hi the fact that you smell gas near the floor suggests you do indeed have a gas leak, propane is heavier than air to will fall to the floor.
you really need to get the gas company to check
Mar 14, 2017 | Maytag MGR5875QD CleanDesign Gas Kitchen...
GE XL44 Working fine but awful burnt propane smell
Remove the burners and clean them with EASY OFF oven cleaner. The passages are likely plugged and this causes incomplete burning of the gas. If you do smell raw gas shut the gas to the stove off RIGHT AWAY and call the local gas supplier.
May 12, 2017 | Kitchen Ranges
Oven gas
For safety purposes call gas technician to check your gas pipe. If stove turn off supposed not to smell gas.
Jul 23, 2008 | Frigidaire FGB24S5A Gas Single Oven
Kitchen Ranges Logo
813 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
