Question about Gateway NV53A24u Laptop
How to take apart a gateway nv5sa24u laptop
I need to take apart my laptop to repalce the power jack but i can't get to open it theres a screw or something in the vga output area that doesnt let mee finish taking it appart. please help
LaptopExpert
  • 458 Answers
SOURCE: Power Cord Slot Repair for a Gateway ML6230
First Of All.... STOP WIGGLING IT!!!!!!!!
WHat Your Doing is Shorting Out The DC JAck And Causing Further Damage Every Time You Wiggle It For A Connection....
Which Could End Up Ruining Your Motherboard....
Your Problem Is The DC Jack You Need To Have Yours Replaced... THis Involves Complete Disassembly Of the Laptop Down To The Motherboard, Then The Old-Bad DC Jack Needs To Be Desoldered and removed and a new one Soldered Into Place....
http://www.ifixlaptops.com
Posted on Nov 18, 2008
ashish13
  • 75 Answers
SOURCE: how can i open up my Gateway 7322GZ to replace DC power jack?
Here is the direct link for downloading the manual that will walk you through the procedure you wanna pursue.. It's gateway's original manual n hope you get some idea about how to open up ur laptop
http://www.adrive.com/home/downloadfile/136709577
Posted on Feb 13, 2009
  • 130 Answers
SOURCE: how to take apart gateway mx6447 laptop need to
usually you need to take out most of the screws you can seen, then pop off the faceplate above the keyboard. then take out the keyboard and then take out another set of screws and components, continue until you get to the power jack.
Posted on Jun 13, 2009
emmetmyers
  • 37 Answers
SOURCE: Im trying to replace the dc jack on a gateway
yes you need to pull ALL parts HDD, dvd drive,....
then turn it over and pry loos the cover above the keyboard you should then be able to remove the keyboard
Posted on Jun 19, 2009
SOURCE: Gateway MT3705 Overheating
http://www.madshrimps.be/?action=getarticle&articID=643
here you go, dis assembly info
Posted on Sep 14, 2009
I have all screws out of back of gateway ma3 all tabs are clear on top of key pad but wont come out
The only things you could hope to upgrade in a laptop that old is the RAM and the hard drive. if it's an x86 computer the most you get get is 4GBs of ram and maybe a 250GB IDE drive in that. Laptop's are not really meant for upgrading. It isn't cost effective to upgrade laptops anyways. Spend $300 on a new low end laptop and you will have something at least twice as powerful as this laptop you currently have.
Dec 16, 2011 | Gateway MX6453 Notebook
Hey i need to purchase a gateway nv53 power board,cable,spring & button cover. I would like where can i purchase it & where to get it fixed.
From a quick search edrence89,
http://www.skyline-eng.com/index.cfm?fuseaction=product.display&Product_ID=7564
http://cgi.ebay.com/GATEWAY-NV52-NV53-NV54-SERIES-POWER-BUTTON-BOARD-/110641410161?pt=LH_DefaultDomain_0
Pictorial disassembly of a Gateway NV53 series Notebook PC,
http://www.insidemylaptop.com/disassemble-gateway-nv-series-laptop-fix-power-jack/
[The Gateway NV5302u is part of the Gateway NV53 series, just as your NV5378u is.
The heading is for replacing the DC Power Jack, but I thought the pictorial guide may come in handy ]
Free Service Manual for the Gateway NV53 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Drop down to the second line in the first paragraph, and click on NV53.
This is a PDF file. It may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 17, 2011 | Gateway NV5378u Notebook
Access to solder joint Gateway MX6440
Hello. I have seen this happen with all models of laptops. Too bad Apple has a patent on that magnetic power cord they use...
You can find all of the service and user manuals for your Gateway laptop here...
http://support.gateway.com/support/manlib/Notebooks/notebook.shtml
Dec 03, 2009 | Gateway MX6440 Notebook
Gateway Laptop it not powering with or battery or plugged in
Try to connect AC/DC power supply to your PC. If it works there is something wrong with your DC Battery. If you have done this, try to use tester to test if the power battery can still transmit power from source. If power is down, may be another kind of battery that is compatible to your PC. Insert only battery required for your laptop that would destroy your PC totally.
Jun 19, 2009 | Gateway Computers & Internet
How to take apart gateway mx6447 laptop need to check the power jack and possibly re solder.
Jun 13, 2009 | Gateway MX6447 Notebook
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Opening laptop
I had a similar problem taking apart my laptop, come to find out I had to open it up, remove the keyboard, under which there were two more screws.
Dec 13, 2008 | Computers & Internet
GATEWAY ta6 WAS DROPPED ON THE CONNECTION FOR THE EXTERNAL POWER SUPPLY (ac adaptar) AND IT MADE THE PIN LOOSE ON THE LAPTOP. I WOULD LIKE TO TAKE THE COVER OFF AND REPAIR THE PRINTED CIRCUIT BOARD AND PIN...
Try here - detailed photos for same problem on different model Gateway:
http://www.insidemylaptop.com/take-apart-gateway-nx570x-laptop-disassembly-guide/
Dec 11, 2008 | Computers & Internet
Power jack repalcement Gateway 7330GZ Notebook
you have options....#1 send it out to gateway for an arm and a leg...(i have the same model and had the same problem), #2 find a local computer repair store...they will most likely charge about 30 for the part.(that's what i was charged + 60 an hour for labor took 2 hours...) or #3 do it yourself, if you can solder then i can talk you through most of the dis assembly..plus you can get the part remarkably cheaper
Nov 08, 2008 | Gateway 7330GZ Notebook
Opening a Gateway Solo 2150 laptop
I found the answer on another wed site. I tried it on my Gateway Solo 1500 and it works! The extra screws are hidden on top. You carefully remove the small face plate around the power button. I used a very small screw drive to lift it off.
Opening Gateway Solo 1400
by Aelanna - 2/3/05 11:04 AM In reply to: Gateway SOLO 1400 by hunjibunji
I'm also an A+ certified tech, but I've done notebook service for a lot of years. I just finished opening up a Gateway Solo 1400 and it was NOT easy! There are no screws holding the keyboard on the bottom of the machine. You can get the case open about 95% and there will be one area stuck, in the back near where the screen cable goes into the unit. There is a hidden screw on the top of the case next to the hinge. To get to it, you have to remove the two screws that hold the plastic hinge cover and pry off the cover. I only managed to find it after removing the keyboard, the display, and the panel with the LEDs and power button. (The screws holding the keyboard are on the top of the machine, underneath the cover with the power button on it.)
May 02, 2008 | Computers & Internet
Open Questions:
Gateway NV53A24u Laptop Logo
321 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
