Question about LG 42PC3D 42 in. Plasma Television
I cant adjust volume or turn my TV off with the remote. I can change channels. Any thoughts of what is wrong. I was thinking the IR eye went out but then how can I change channels
  • cdingma Feb 07, 2012
    I have verified that the remote works - I think it is the IR eye on the TV. Is anyone aware of where or how to get an external IR eye?
    Problem Solver:
  • 3 Answers
Either there is a crack or other "short" in the circuit board of the remote or something has spilled on it and is preventing contact at those points (that do not work, such as volume and power).
If you're somewhat handy, start by removing battery cover and batteries. If there is a screw (or screws) visible, remove them. Next, very carefully insert a wide, thin screwdriver or other such instrument anywhere in the seam that runs around the sides of the remote and give your screwdriver/what-have-you a wiggle/twist. I would suggest starting near the buttons that DO work. BE CAREFUL as the plastic is relatively soft and can be easily gouged/broken.
Continue around the remove until it splits into two pieces (top and bottom). Check for obvious damage to the circuit board as well as obvious signs of dirt or other debris on top of the board where the rubber piece that contains the buttons would touch it. Use rubbing alcohol to clean both the top of the circuit board and the bottom of the rubber button pad. Snap it back together and insert the batteries.
This works about 75% of the time in correcting an issue such as you describe. Otherwise, it might be time for a replacement -- suggest a "universal" remote from big box store for $20 or even less.
Posted on Feb 07, 2012
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 139 Answers
Sounds like some buttons on your remote have failed
3 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: No remote (LG or otherwise) works
The remote receiver in the TV set, or its associated circuits inside the TV are not working. This would be fully proven by trying another known working remote on the TV set.
Jerry G.
Posted on Apr 10, 2009
SOURCE: can't turn tv on with remote, only manually, when on volume is at 100 and cannot be adjusted with remote or manually. channels cannot be changed with remote or manually. Changed batteries in remote,
replace with new batteries and it works --- so simple
Posted on Sep 22, 2009
My 32 in insignia tv I cant change the channel with the remote or change from the actual tv,i can adjust the volume
replace the remote think it got bad if you cant get the tv remote try to get a master remote read the instruction on how to program your tv brand name this remote can help and work both tv and sound system because its master remote.
Jan 17, 2018 | Insignia Televison & Video
I was watching T.V. and when I went to change the channel, the remote control wouldn't respond. I changed the batteries (generic) & the new ones didn't make the remote work either. I hit the power...
You won't be able to see the light from remote's LED (Light Emitting Diode) because it is IR (Infra Red) which is invisible to the human eye.
Try re-entering the code for your tv to see if it works.
If that doesn't work, the remote might have just died. It happens.
Get yourself a new UNIVERSAL REMOTE for less than $20 and just program it for your tv.
Good luck and post back to let us know how it works out.
Jan 24, 2011 | Televison & Video
I cant turn my sharp aquos 32" on or off with the remote. I also cant mute it or adjust the volume.
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
New remotes: www.remotes.com
Jun 29, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
The tv is on but the remote control does not work. I thought maybe it was the remote control that came with the tv so i went and bought a compatible universal tv remote but that does not work either so i...
I have the same problem as you Lisa and am beyond frustrated....any fix found yet? I think it is the receiver in the tv as even the remote that came with the tv won't do anything but turn it on/off...no channel change or volume control. The cable co remote will do volume after tv warms up....
Apr 10, 2010 | RCA L32HD31 32 in. LCD HDTV
My remote turns the tv on and off and adjusts the volume just right,but it will not do anything else!I can't flip the channels I cant go to the guide,etc..
laboribella8
I have provided a link with instructions on how to readdress your remote to your receiver. I hope this helps
Readdress remote, step 5:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Apr 08, 2010 | DISH Network IR Remote Control
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Oct 29, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
TV input
it is likely that your tv is interpreting a random button on your remote as a signal sent for it to change inputs, next time this happens turn the tv off and back on and note what comes up on the screen, for example video 1,
Aug 04, 2008 | DISH Network IR Remote Control
Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Jun 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV Volume goes up when channel is changed Philips 20S240
I don't think the IR sensor has anything to do with it. It sounds like a surface mount micro processor to me...
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Everything slowly went wrong
Most likely you have a locked up micro on the main board. You would need to have the main board replaced. If the set is not under warranty your cost to repair would exceed your cost to replace.
Sep 11, 2007 | Insignia IS 20" TV040919 TV
LG 42PC3D 42 in. Plasma Television Logo
66 people viewed this question
Computer Repairing
Computer Repairing
