Question about Uniden Cordless Phone
The phone will not ring- lights uo but shos
Shows bell mute. How to turn on so it rings
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you declined to specify the model of your Uniden phone, I can only direct you to select it from the list beginning here to download a copy of the manual.
Posted on Feb 07, 2012
3 Suggested Answers
divatif
  • 39 Answers
SOURCE: handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
Posted on Mar 17, 2009
  • 102366 Answers
SOURCE: My phone won't ring, but
Since you didn't specify the model of your phone, select it from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl
to get the manual to see how to change the ringer volume.
Posted on Sep 09, 2011
Why doesn't it ring?
The phone may have been set to vibrate-only initially. You may have to repeat the initial set up to get it to ring.
Apr 06, 2016 | Unnecto Air 5.5 - Unlocked Black
The phone will not ring. There is a bar across the bell
its muted
if its a handsfree telephone you need to enable ring
usualy a button in the middle of the keypad
has a bell with a bar across the middle
if its a mobile set it in settings profile to normal ...
Dec 09, 2014 | Lands Phones
Samsung Convoy cell phone will not ring in. screen shows bell with a red hash through it.
try the volume button on the side. the red bell means u have it on mute. otherwise find the profiles settings im using a rugby and they are in settings, profiles and adjust your ring volume in there
Jan 17, 2011 | Samsung Convoy Cell Phone
I want to change the nombers of the rings to get start the answering machin
These are the instructions from the manual, which I found here:
http://safemanuals.com/user-guide-instructions-owner-manual/GE/21028GE3-A-_E
RING SELECT (FOR ANSWERING MACHINE)
This feature lets you select the number of times you want to phone to ring
before the answering system answers a call.
1. Make sure your phone is OFF (not in talk mode).
2. Press the MUTE/PROG button to go to the main menu.
3. Press CID/VOL (up or down) button to scroll to HANDSET SETUP.
4. Press MUTE/PROG button to confirm.
5. Press the CID/VOL (up or down) button to scroll to the RING SELECT menu.
6. Press MUTE/PROG button to enter the menu. RING SELECT 3 4 5 6 TS shows in the display.
7. Use the CID/VOL (up or down) button to scroll to the your selection. The default setting is 5.
8. Press the MUTE/PROG button to confirm. You will hear a confirmation tone and the new setting shows in the display.
NOTE: If you select Toll Saver (TS) the unit answers after the 3rd ring if there
are NEW messages, OR the unit answers after the 5th ring if there are NO new
messages. This allows user to access their answerer from another location and
then hang up after 4 rings to save long distance charges.
Oct 13, 2010 | GE 21028GE3 Cordless Phone
How to put phone so when phone rings, cannot hear it
Press MENU/SELECT to display menu when in idle mode
Press Up or Down arrow to reach SETUP HS. Press MENU/SELECT.
Press Up or Down arrow to reach RING VOLUME. Press MENU/SELECT.
Press Down arrow all the way down, then Press MENU/SELECT to confirm.
A ringer off icon (Bell with a line through it) will be displayed on the screen.
Note: While the phone is ringing, you can temporarily silence the ringer by pressing OFF/CLEAR or MUTE/REMOVE. The next call will ring normally.
Rest of Manual details here: http://www.vtechphones.com/docMgt/public/art/52882/6041_manual.i4.pdf
Jan 14, 2010 | Vtech Cordless 6041 Phone
Set call rings
From the manual:
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press mute/menu OK button to enter the menu. SET RINGER LEVEL 5 shows in the display.
3. Use the CALLER ID-VOLUME ( 6 or 5) button to scroll to your selection. LEVEL 5 is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
Apr 26, 2009 | General Electric 28811FE2 Twin Cordless...
Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
Nov 19, 2008 | Panasonic KX-TD7896 Cordless Phone
No ring on incoming call
i had the same problem and went searching on line till i found the answer, press the # button it takes the mute off or puts it on.
regards patty
Nov 08, 2008 | Samsung SGH-D900 Cellular Phone
Uniden Cordless Phone Logo
29 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
