Question about Samsung CLX 3160fn All-In-One Printer
Scanner locked when i turn the printer on the top flap pops open the dialogue box reads scanner locked. then i here this "studering noie" and it wo't int. it also keeps saying to empty toner tray---bu t i have done that. is there a way to reset the "empty toner tray setting?
  • 1,113 Answers
The noise is your scanner the light trying to move, you probally have the scanner lock on or the scanner rail needs a lube or moter is stuffed, but good chance scanner lock is on.
Waste toner... clean the bottle... dont just empty it... most machines try to see threw the container to see if it is empty... if it has dust on the sides it cant see threw so thinks it is full
Posted on Mar 06, 2012
  • Soulvisitor
    Soulvisitor Mar 06, 2012
    http://www.fixya.com/support/t209098-sam...
  • Soulvisitor
    The scanner lock on the 3160fn is located underneath the scanner where you reach your hand into pull out the printed papers. On the top to the left. Flip the switch... power off ... then power back on and it works. Hours of anger management could have been averted with some simple user guide documentation.Author jwaawaa Jan 05, 2008
Where is the scan button and how do I start it?
Try this steps:
1. Load the document in your printer/ copier/scanner
2. On your computer, click on start (the windows logo button)
3. From the pop-up menu, click on Devices and Printers
4. From the window that opens, right-click on the printer/ scanner you loaded the document and click on the options for scan. (Make sure it is checked as the default printer)
5. A dialogue box will pop up options for you to choose and scan your document. It will be saved to a folder in the documents My Scans. Does this help?
Aug 05, 2014 | Canon PIXMA MG2520 Inkjet All-in-One...
Install epson stylus tx110 with out disk
Search the printer driver "epson stylus tx110 printer driver" in the google. Download the driver, run the application then follow the dialogue box. Turn on the printer and connect the printer usb wire to the computer using the usb port if it is ask in the dialogue box. Enjoy!
Sep 02, 2013 | Epson Stylus Multifunction Inkjet Printer/...
My files are created in adobe pagemaker now I want them to convert in jpg or pdf format how?
1. Save the Pagemaker document. If you don't do this before proceeding, a pop-up box will remind you.
2. Go to File>Export>Adobe PDF. A dialogue box of PDF options will come up.
3. Determine what you want to use the PDF for. If you are exporting for a specific print job, the printer will give you Distiller settings. Otherwise, in Job Name, just choose the settings that most closely meet your requirements: High Quality Print for a printout, Smallest File Size for a document that will be viewed online.
4. Click "Export." An "Export PDF As" dialogue box will pop up. Choose the folder in which you wish to save the PDF, and name the file. Check the "View PDF" box, so the PDF will open after it has been created.
5. Watch the dialogue box. It should show that Distiller is creating the file. When finished, the PDF document will open.
Good Luck!
John Vickers
Aug 13, 2011 | Computers & Internet
I cannot scan
If you on windows xp, go to My Computer and in the list of drives and devices you will see your scanner icon. Double click to open the scanner dialogue box. From there simply follow the instructions to complete your scan.
If you are on windows Vista, go to start/all programs/windows photo gallery. When it opens click on file/import from scanner or camera. The dialogue opens for you to select your scanner. The scanner dialogue box opens and simply follow the instructions to complete your scan.
Good luck & God bless!
Nov 23, 2010 | HP J3680 Officejet All In One Printer
"Window cannot connect to the
You must restart the Print Spooler Service. To do this you must be logged in as an administrator:
1. Press the Win Key (between left "ctrl" and "alt) + "R". That will open the Run Dialogue Box.
2. Type "services.msc"
3. Scroll down to Print Spooler
4. Right click ----> Properties
5. Verify startup type is "Automatic"
6. Click "Start" ---> "Apply ----> "OK"
Oct 29, 2010 | Brother MFC 240C All-In-One InkJet Printer
How to replace an ink cartridge on Epson Dx7400.Cyan has run out TO712.I have lost my user manual and I cannot remember which button to press to get the Printer part to the right spot for changing the...
On your printer and then click on the start menu goto Printer and Faxes. After that goto your default printer Epson Stylus and right click the printer then click properties. Dialogue box was appear click on the maintenance and then click replace cartridge their was dialogue box will also appear. Just click the next button and read the instruction when you press the Next button. After that open the cover of your printer when the cartridge are at the center thats the time you can change the cartridge. Then close the cover when your finished to change the cartridge. Then click the next button and so on to finished.
May 28, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Printer properties dialogue box for mac
Go to the Apple Logo (top left) and choose System Preferences. In the hardware (second) line, choose Print and Fax. You can add printers by choosing the + sign, From here you can choose which printer is the default. You can also choose Printer Setup and paper size
Also, click on the desktop and enter the keystrokes Command (Open Apple) f. Enter print in the search box and scroll down to Applications. You should find the printer utility icon and some other print related icons. You can open these and read the directions. It's hard to be more step-by step since I don't know what you wan to change. Within an application (such as MS Word) you also have the page setup choice under the FILE menu.
Nov 16, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
The print to file dialogue box keeps popping up
chage the printer port. START- SETTINGS-PRINTERS & FAXES - right click on the printer icon and goto properties you will get another window. goto port choose the right port
Sep 25, 2009 | HP LaserJet 3055 All-In-One Printer
My kodak esp3 will not scan it prints and copies.
I had the same problem and I got it to work. I have Windows Vista and Microsoft Office 2007 on my computer. Here's what I did...
Go to "Start" then "Control Panel".
-Click on "Programs and Features".
-Scroll down to Microsoft Office Home and Student 2007 - click on that and then click on the "Change" link above.
-A box will pop up, click on "Add or Remove Features" and then click "Continue".
-Click on the "+" next to "Office Tools"
-Click on the "+" next to "Microsoft Office Document Imaging"
-Click on the down arrow next to "Scanning, OCR and Indexing..."
-Then, click on "Run from my Computer"
-Next click on "Continue" at the bottom of the dialogue box and your configuration process should begin
Once completed go to the start menu and type in "Scan" into the search box. Go to "Microsoft Office Document Scanning" Once there, plug your scanner into you computer, chose what color you want your scan to be in, and click on the picture of the scanner to the right. To make my scans clear, I had to click on "Scanner..." and chose KODAK ESP AiO as my scanner even though I have a KODAK ESP-3 printer/scanner.
I hope these instructions weren't too confusing and I hope this helps some of you out! My scanner was causing me a lot of frustration for a while!
May 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Samsung CLX 3160fn All-In-One Printer Logo
114 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
