Question about Leica DISTO A5 Rangefinder
Leica disto classic 5a
My leica disto classic 5a cannot seem to measure over 25m outside on a good day.By good day i mean at the first attempt even when its tripod mounted.I have used a reflector of the type that ships with the Hilti pd20 but its no better. This tool was bought 2nd hand and advertised as "As New" and Vgc and measured up to 200m. The battery checker shows 3-4 bars out of 5 and its supposed to measure up to 10000 times on new batteries. On small thing is the cover of the battery holder is missing and has been replaced by a copper clip, but the unit appears to be working fine indoors in every respect allbeit that i haven't tried over 25m indoors yet. When the laser is on, I can somtimes see it 70 m away outside through the viewfinder but other times i cant see it 10 metres away using the viewfinder.
Please advise if possible
  • 4 more comments
  • Andy Bathgate
    Andy Bathgate Oct 24, 2008
    thanks benimur
    for the links to support for this item, in response to your comments, i agree that it is posssible that the laser strength may becoming weaker, only thing is that in a weak laser there is a widening of the ray and in the manual it gives the beam width over certain distances so its easy to interpolate the beam size at 10m and it seems to be bang on. The error code I keep receiving is a 255 which is that the beam is not being reflected strongly enough. Another reason i'm not totally convinced that the laser is failing is that these instruments have a built in system checker and if anything is moving out pf spec, it should throw up a 287 service fault, Having read one or two customer reviews on the Classic 5a they say that it cant get anywhere near 200m without proper leica reflector. I think what I need is a chat with someone who uses this tool on a day to day basis and compare notes.
    thanks again benimur and var pun
  • Andy Bathgate
    to benimur and var pun if you can think of anything else following this further information then i would be happy to hear from you both
    thanks again for your input
  • Andy Bathgate
    i think you've emailed me on someone elses pd20 problem natrin
  • Andy Bathgate
    thank you for your comments fixe-you but only zinc-carbon batteries recommended for this model and i have replaced with new which increasead my range to 35m without reflector
  • Andy Bathgate
    thank you ready but i have changed the batteries and the range has increased to 35 m without a reflective target and the laser is in spec with the manual i have just measured the beam width at 10m =6mm at 50m=30mm and at 100m=60mm (outside in the dark)using plyboard as a target and if the laser was weak these dimensions would increase, im still sure the problem lies in the reflective properties of the targets used
  • Andy Bathgate
    ginko m8 i had considered the quality of the transparency of the lens but on the double check after your email i noticed a slight misalignment of the laser lens...as if had been pushed back at one corner less than 0.5 mm, possibly previous owner cleaning,this misalignment means there will be a certain amount of refraction from of the front bezel since the lens is recessed by about 3mm. Makes good sense to me. your a star m8
  • Leica Master
  • 19,396 Answers
The optical lens of a laser rangefinder must always be kept clean for optimal performance.
The most common cause for a reduced range on this devices, is caused by dirty, or defective lens.
If the lens are dirty, on the outer or inner side, or they are opaque or defective, or there is wet inside the lens, than that is the cause for the sensibly reduced range.
Posted on Oct 24, 2008
    Scholar:
  • 136 Answers
Try replacing the old batteries with new batteries.
and also get your laser strength checked to the nearby repair center.most probably it is the problem of laser strength.
thanks.
  • 1,800 Answers
Hi
this problem related to the batteris 100%.
because when the LI ion is exausted inside the batteries it gives to many Bad performance troubles aswell as the laser issue
purchase new batterise and replace it from the previous link
i recommand with new fresh batteris
    Sergeant:
  • 306 Answers
Shut the unit off by using the power button then turn it back on holding down the power button unitl the menu is displayed allowing you to turn the beep on/off with the + key and change the units with the - key.. else hav a look at tis. http://www.eurooptic.com/leica/Leica-Laser-Range-Finder.asp?category=XCRF&vendor=XXLE&parent=XXLE&gclid=CPfysJqYwJYCFQZmegodY2pDyg
    Brigadier General:
  • 6,966 Answers
Being a laser equipped device, there are special precautions, repair procedures as well as calibrations and alignment specific to this units. You may want to considering seeking the services of professionals.
Incidentally, replacements for the cover of the battery holder are available online. Pls start here.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 22, 2008
  • Louie  Role
    Louie Role Oct 23, 2008
    Hi again,
    Have you tried a reset? Procedures are better explained in the manual.
    Sergeant:
    Champion:
  • 331 Answers
The only thing which comes to my mind is that
the laser may have become weak ....
did u try with new batteries..
ne way the new ones also cant measure more than 200 m...
the device might be loosing its strength..(maybe that guy had used quite a few times)
What does error 270 mean?
There is no error code 270 listed for a Leica Digital DISTO D3a 100M Laser Distance Meter.
Are you sure that's the code?
Or do you have a different make or model of laser distance meter?
Sep 06, 2016 | Leica Digital DISTO D3a 100M Laser...
My leica disto A5 is not measuring more than 2.5 meters , if i measure more thank 2.5 meters it give info 255
First, insert brand new Duracell batteries. Then you might try cleaning the optics with a Q-tip and some rubbing alcohol. A 255 error indicates that the unit is not getting a strong enough signal, essentially that not enough of the laser is getting back through the optics to the sensor. If these don't make a difference, contact the dealer you bought it from, it may be eligible for the Leica repair program. (good luck if you bought it off ebay or from an unauthorized dealer)
Mar 06, 2015 | Leica DISTO A5 Rangefinder
Does not measure distance
Put in new batteries, clean lens, and calibrate. If this does not work, type " Leica Disto A6 Laser Distance Meter user manual " into computer search engine. It will bring up sites for manual.
Oct 18, 2014 | Leica Disto A6 Laser Distance Meter
Leica disto
Low battery. Mine does that when batteries are too low to operate the laser.
Aug 20, 2013 | Optics
Leica Disto D3a shows ERROR 220
I had this exactl problem and resolved it by replacing the batteries
Feb 19, 2013 | Leica Digital DISTO D3a 100M Laser...
Always get error 279 on my Disto Classic
Put in new batteries and clean lens and calibrate if it has that function. If that doesn't work, Type the " Leica Disto A6 Laser Distance Meter user manual" and it will bring up sites to manual.
Jun 28, 2011 | Leica Disto A6 Laser Distance Meter
Have a Leica Disto basic and need to know how to change measurement from m to ft.
Press and hold the circle button down, after a few seconds it will flash 'beep on/off', dont stop holding it down, it will then cycle to 'units', press +/- to change between metric and imperial, then press the = button to store. If you keep holding it down you can set the reference pont (where the measurement is taken from, the back, middle or front edge of the machine) add an offset (add take away from the displayed dimension), and you can also reset the machine.
May 20, 2011 | Leica DISTO A5 Rangefinder
After I changed the batteries for my Disto A6 the screen stayed blank. I see the laser beam and beep. but nothing in the screen.
MY LEICA DISTO D5 SCREEN DOES NOT LIGHT UP ALTHOUGH THERE IS LEISER AND READING. HOW DO I RECTIFY THIS.
Jan 18, 2011 | Leica Disto A6 Laser Distance Meter
I have a Leica Disto 5 laser device. The view screen has a crack in it that is spreading. Can that small, clear plastic screen be removed and replaced? The unit functions fine and I'm assuming that the...
It depends on the model that you have. I may have some replacement screens for that device, but I need to know the exact model number. (DIsto LIte5, Classic5, Classic5A, and DIsto A5) . Leica does not sell these parts, you just need to find someone that has an old unit like yours that still has a good screen. Contact me with the model number and I can let you know if I have any.
Greg DeTray
Distagage.com
Dec 16, 2010 | Leica DISTO A5 Rangefinder
Getting error code 279 on my Disto Classic 5a
can not measure distance.
each time the button is pressed dist, 279 error appears.
Aug 12, 2009 | Leica Disto A6 Laser Distance Meter
Leica DISTO A5 Rangefinder Logo
1,102 people viewed this question
Top Leica Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Bill Boyd
Are you a Leica Optic Expert? Answer questions, earn points and help others
