Question about Craftsman Saws
14 inch professional 1 1/2 hp bandsaw 22424
Manual
  • 2692 Answers
SOURCE: jet model jwbs-14cs bandsaw purchased used, need manual
Here is the company webpage for your product. No download area that I found. May have to write to them.
http://www.cpojettools.com/search/20080825144306/index.php/search?terms=+710115K+&submit_x=18&submit_y=8&submit=Search
Posted on Dec 29, 2008
efs_perpends
  • 1996 Answers
SOURCE: manual for Rockwell 52-235 14'' bandsaw
I don't know how old that machine is, and I can't get any hits on the model number you gave, but have a look at this link and the other Delta/Rockwell bandsaw manuals available at the same site, and you may find something that you can use. Go to machine info>publication reprints>and choose either Delta or Rockwell, then you can filter the results by bandsaw and see what's available out there. To download, just click on the blue letters PDF under the publication preview picture.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 15, 2009
  • 58 Answers
SOURCE: ATM BANDSAW
Go here :
http://powertool.manualsonline.com/
Posted on Jun 13, 2009
heatman101
  • 43501 Answers
SOURCE: 14" Delta Bandsaw keeps tripping the internal motor breaker.
The first thing that I would check is the wiring to the saw. My guess is that the wire to the saw or the cord is not heavy enough.
As saw like that can pull a lot of amps. Probably 15 or more when working hard. What happens is that when the amp draw goes up and the cord is too light, the voltage drops which increases the amps. and starts a vicious cycle...
The one thing that finally gives is the internal overload in your motor.
Try running heavier wire or a heavier extension cord if you are using one.
#12 wire or a 12 wire cord would be minimum, if running over say 50 feet then you should be looking at #10 wire.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Nov 29, 2009
Testimonial: "Thanks. I will replace the power cord. I do not use an extension cord."
  • 33 Answers
SOURCE: need lower guide pins for my Dayton 14" bandsaw
graingers carries some repair/replacement parts for this model.
Posted on Dec 06, 2009
How to install belt on rikon 10-325 bandsaw
For the high speed, (2950 ft/min), the belt should be installed on the rear pulley of both the motor and the wheel. For the low speed( 1445 ft/min), the belt should be installed on the front pulley of both the motor and wheel. To properly adjust the belt tension, turn hand wheel until there is 1/2" deflection in the "multi-vee" belt. Check this link to see the manual. http://www.highlandwoodworking.com/library/manuals/10325_manual.pdf
By the way, where do you get your band saw blades? I got mine from sawblade.com and I happy with them.
Dec 13, 2013 | Rikon 10-325 Deluxe 14 inch Bandsaw with...
Need help identifying my bandsaw
I'll bet it is a Universal BS360. Try Googling (universal)(BS360)(manual) without parens.
Oct 29, 2017 | Saws
I am looking for a Jet 1$" manual. Model
Hi Dean,
The manual is available here:
http://www.retrevo.com/support/Jet-JWBS-14CS-manual/id/23013ci556/t/2/
Click on the red download button.
You just need to enter an e-mail address on the download page for them to send you junk mail !
Hope this helps !
May 07, 2011 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
I'm looking for replacement bandsaw blades for a McGraw-Edison 10" Bandsaw, M/N - T6760. Any Ideas?
I have 11[6 tooth scrolling blades] & 3[3/8" 14 tooth general purpose metal cutting blades.T8380-16 & T8382-16 for McGraw Edison 10" bandsaw. blades are 57" been hanging in my garage for past 25 yrs lol. would like to sell to best offer. contact me at tazzdh1959@yahoo.com
Feb 24, 2011 | Saws
I need a manual for a delta 14 inch 28-207
Here's an exploded diagram of your bandsaw.
http://owwm.com/pubs/1141/2461.pdf
This exploded diagram should help with the parts list and how things lock together. Seems no-one readily has a more comprehensive manual available online. You might track one down behind an old workbench that hasn't moved in 50 years but it's unlikely to be digitised!
Jul 31, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
In the Market for a better Band Saw
Everybody wants to resaw, but the only saw I've seen that will do it is a resaw, they are big, powerful machines. I have an old delta 14, with an aftermarket 1 hp motor, trying to resaw is a nightmare. I don't try anymore. Jet makes a big resaw, so does grizzly, both Taiwan machines, what isn't>? But they work. If you are lucky enough to find an old bandsaw with 36 inch wheels and a ten HP motor, that would be nice, you could resaw whole cars in that thing.!I The $300 special might be worth getting and customizing to work, You would need a big blade, about 1 inch min, and a bigger motor, say 2HP min, Then hope that the tracking system will take the heavy cuts. When I have to slice something , I do it first on the table saw, cut both sides, then run it through the band saw at its max cut, 6 1/2 inches, then plow it through the planer. Always a way around this stuff. Hope this helps.
Mar 01, 2010 | Ridgid 14" Band Saw with Stand
I just purchased a used Rockwell bandsaw. I need
Ok so you understand that Rockwell became Delta, or was it the other way round?? Either case the best source of manuals for these much loved machines is over at Old Wood Working Machines:
http://www.owwm.com/mfgindex/detail.aspx?id=698&tab=3
You should find your model.. 14" Delta doesn't really pin it down too exactly. The model number should be on the warning plate.
Feb 26, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
Top wheel part broke off
I suspect the part you need is 150086 "Upper Wheel Shaft". You can confirm this by checking the exploded diagram for your bandsaw which can be downloaded at http://content.wmhtoolgroup.com/manuals/708115K_man.pdf.
See page 25 for exploded diagram showing wheel shafts, bearings, etc..
It might be worth checking with JET about warranty since I believe that band saw has a 5 year warranty. You can check here for a service center near you.
Jan 10, 2010 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
Manual,fence and rail
The manual doesn't seem to be available online at the moment. There's a parts diagram, if that's helpful, or perhaps you can find an alternate site that provides instruction manuals. See this link, in any event.
Otherwise, you might check Woodworker's supply (woodworker.com) for the accessory fence and rail. They carry genuine Delta parts, which should fit your old Rockwell, as well as some aftermarket fences and guides that will usually adapt easily to fit a 14" bandsaw. The 14" Rockwell is one of the industry standards, and many woodworker catalogs carry fences that will bolt on with a minimum of fuss.
I recommend you do a web search on "14" bandsaw fence", and browse the results. You may even find something used to suit your needs.
Good luck, and let us know if this solves your problem or we can provide any further information!
Mar 23, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
Jet model jwbs-14cs bandsaw purchased used, need manual
http://www.cpojettools.com/products/708115k.html
Scroll down and click the "Manuals" tab. Your free PDF awaits...
Dec 28, 2008 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
Saws Logo
89 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
