Question about Kenmore Dryers
Kenmore Dryer Model 96589210
Kenmore Ultra Fabric 80 Series Heavy Duty Dryer when front door is closed the light is still on inside dryer. Restart button will not reset to start dryer.
GodBlessU
  • 3513 Answers
SOURCE: washer leaks water
The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with metal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement.
Thank you for contacting Fixya.com
Posted on Aug 10, 2009
hunter19_46m
  • 7482 Answers
SOURCE: We have a Kenmore Ultra Fabric Care Heavy Duty 80
You probably have a faulty heating coil, or thermostats.
If you plan to repair it yourself, remove the back of the machine, locate the air tube going from the blower to the drum. Normally inside of the air tube is where you will find the heating coil, and thermostats.
Check your heating coil with a continuity meter across the two terminals.
Good luck,
I hope this helps
Posted on Oct 05, 2009
shastalaker7
  • 1515 Answers
SOURCE: I have a Kenmore Ultra Fabric Care Heavy Duty 80
Good Morning, I would be looking at the motor or if it has a door switch that is intermitent, that would cause it to not come on all of the time. It is a switch that is mounted by where the door latches and is depressed when door is shut.It will not start if the switch is starting to fail.You can also remove the back and check for lint build up on all of the safety's as these get covered and will cause it not to start all of the time.I doubt the motor is at fault, because it runs and doesnt stop from over heating. It could also be the push button start switch, it has been pushed for 14 years and maybe worn, contacts in it.I would remove it, mark the wires and give it a good look over. This is where the problem starts, so replace it and you should be up and running. But do check everything I have mentioned as the lint is probably bad. Let me know and best of luck to you. Sincerely,
Shastalaker7
Posted on Nov 25, 2009
Testimonial: "Thank you shastalaker7....I will check. Happy Thanksgiving!"
heatman101
  • 43501 Answers
SOURCE: Kenmore Ultra Fabric Care heavy Duty 80 Series
A dryer can not start for many reqasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 06, 2010
heatman101
  • 43501 Answers
SOURCE: i have a kenmore ultra
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 01, 2011
I have a kenmore ultra fabric care heavy duty 90 series soft heat i will not come on hum not nothing
heatman101
Aug 28, 2011 | Dryers
We have a Kenmore Ultra Fabric Care Heavy Duty 80 series. It won't heat up.
Good luck,
I hope this helps
Oct 05, 2009 | Kenmore Dryers
Dryer Belt
your model number is inside the dryer door,you can go to your local appliance part store or to sears.com or repair .com or ebay to buy one-mike
Jun 22, 2009 | Kenmore Dryers
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Aug 11, 2008 | Washing Machines
Motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
remove screw at each end of console. pull & flip back out of way. remove top, remove bottom panel, slide putty knife to release both retainer clips. remove screws to remove door panel assy. remove belt, remove drum. remove motor clamps & remove wires from motor conector.good luck.
Aug 07, 2008 | Dryers
Kenmore heavy duty 70 Series Electric Dryer
If you are using Fabric Softener Sheets than look in the dryer closely for one to be wedged in a fin or anywhere inside .They will make the streaks you mention. Please rate this !!!
Jul 03, 2008 | Kenmore 63942 Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
