Question about HP Office Equipment & Supplies
Stuck ink cartridge - HP Office Equipment & Supplies
    Guru:
  • 731 Answers
  1. Turn the printer OFF using the power button.
  2. Open the front access door. The carriage moves to the far right side and Wait until the carriage is idle and silent.
  3. Press down on a cartridge to release it and Pull the cartridge toward you and out of its slot.
Posted on Feb 07, 2012
How can I remove the stuck cartridges so I can try to reinsert them?
Are they original ink cartridges? Sometimes if they are compatible inks, they will be slightly different and may not clip in.
Feb 28, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
Print head parked at left, error code 3527
This problem has plagued me for a very long time. The issue is that the printer head is "glued" in the resting position under the guard of the printer, so you can't remove the ink cartridges to clean it. Solution is to (I know this sounds stupid, but it works) turn the printer on the side where the printer cartridges are (if they are stuck on the left side, turn the printer on its side so the cartridges are on the bottom). Turn the printer on, and the cartridges magically start moving! I guess there are some sensors that get tricked out when you tip the printer on its side. If the cartridges are still stuck, click the "ok" button, and before it gets a chance to see if you actually fixed the problem, turn the printer off using the power button. It takes a long time, but you should see the ink trap lower (release the ink cartridges) and the ink cartridges start moving to prepare for shutdown! Grab the cartridges when they move out of their hiding place and don't let them go back until you clean the print head so it doesn't get stuck again. Remove the ink cartridges, then push the grey tab to release the print head. Wipe the bottom of the print head clean with rubbing alcohol (it will have a lot of gooey - sticky ink stuck on the bottom). I used nail polish remover since I didn't have rubbing alcohol available. You can also wipe down the ink pad which is where the ink cartridges were previously jammed to clean up more of the mess and prevent this sort of thing happening again too soon. Good luck!
Dec 27, 2013 | Kodak ESP 7250 All-in-One InkJet Printer
Kodak 7250 print head jam
Jan 20, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
Carriage for the ink cartridges is stuck, the carriage wont move to the middle so i can change the ink. i turned off the power & then turn it on , the carriage just move a little from the right and...
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X2600 InkJet Printer
C 3180 hp printer, just bought from thrift store, ----but,,,it seems the thing that holds the ink cartridges is stuck, though its trying to slide as it should, it seems to be hitting,jamming , light re;...
First of all, if the ink cartridges are stuck, as you rightly guessed, it may not be the correct cartridge.
Now, even suppose, it is the correct cartridge, it would not have been installed correctly . the Label side of the cartridge should face upwards, Not towards you.. when you are inserting the ink cartridge.
if you are from India the compatible ink cartridge would be HP 850(BLACK) AND HP 855(COLOR)
In North,South America it is HP 92(BLACK) AND HP 93.
Aug 14, 2010 | HP Photosmart C3180 All-In-One InkJet...
Ink Cartridge stuck
The dell printers are funny sometimes. When i've had that problem I unplugged it from the wall for 30 seconds and plugged it back in to reset it and the cartridge came to center.
Sep 01, 2009 | Dell 922 All-In-One InkJet Printer
After replacing ink cartridge printer dose not reconize one of six
Using refilled in cartridges and incompatible inks result in the following problems.
  • Refilled ink cartridges might leak and cause product damage. One method for refilling ink cartridges is to drill a hole through the cartridge, refill the ink, and then plug it. In some cases this plug does not hold, and the ink runs into the product and damages the printed circuit boards.
  • Refilled ink cartridges frequently exhibit spotty printing or fail to print. This problem might be a direct result of the nozzles being plugged with dried ink. Because the vents of the refilled cartridges have been opened, air is able to enter the cartridge and dry the ink.
  • Refilled ink cartridges might exhibit lower print quality, for the following reasons.
    • Printing algorithms used to create the various colors are based on particular printer inks. Using incompatible inks might result in color matching problems.
    • Refilled cartridges might have damaged nozzle orifices, result in various problems with print quality.
    • company products to which the printer belongs to can use a time delay between pages to accommodate the properties of the specific media type and ink being used. This prevents smearing problems from one page to the next. Using incompatible ink will alter the effects of this time delay and might result in poor print quality.
  • printer might not recognize refilled ink cartridges. The refilling process may involve altering the ink cartridge enough that the product is unable to recognize it. The condition of the print cartridge electrical contacts deteriorates with use. This also results in the product being unable to recognize the refilled cartridge.
  • Refilled ink cartridges might get stuck in the product. Because the cartridges from other manufacturers have been altered, cartridges might become stuck in the product. This problem might require that the product be disassembled to remove the cartridge.
  • printer at times cannot predict the long-term effects on product reliability from using different ink formulations.
try this.
please rate my solution.
have a nice day.
Jul 08, 2009 | Office Equipment & Supplies
Ink cartridge
Is the ink cartridge now unstuck? Are the cartridge ports free of any dried ink, etc. are new cartridges in place? Try turning your printer off for several minutes and then turning it back on. Let us know if this does not work.
Aug 15, 2008 | HP DeskJet 810c InkJet Printer
HP PhotoSmart 7760 InkJet Cartridges Stuck to the RIGHT.
What do you mean by foots sticking the cartridges, is it part of the printer, or the cartridge
Aug 15, 2007 | HP PhotoSmart 7760 InkJet Printer
24 people viewed this question
Seeker5211
Seeker5211
