Question about Motorola Boating
I purchased a Motorola GM 1200E VHF radio, type MD534AE. what are the uses for this radio and can it be used as a marine radio in Australia? cheers Kieran
SOURCE: Manual for atlantis radio
http://www.uniden.com/pdf/ATLANTIS%20250om.pdf
Is this it?
Posted on Oct 21, 2009
  • 3 Answers
SOURCE: not receiving information
The same thing happened to me, and I'm just hitting the two-year mark with this thing. I tested it using the aux speaker leads and that still works. So it is only the little front-panel speaker that is broken. And I checked the leads on that little speaker, and they seem fine. So it is the little speaker itself that broke. Easiest repair is to connect the aux leads (red and brown) to another speaker.
Posted on Feb 17, 2010
  • 3 Answers
SOURCE: how to hook up an external speaker to uniden solara dsc vhf
the reddish-orange one and the brown one. The green and yellow ones are for data coming in.
Posted on Feb 18, 2010
  • 64 Answers
SOURCE: IC-M302 VHF Marine Radio: need to have wiring schematic coming out the back ...
Blue: Speaker (+)
Gray: Speaker ( -)
Yellow: NMEA IN (+)
Green: NMEA IN (- )
Posted on Jun 14, 2010
  • 102366 Answers
SOURCE: need a manual for uniden solara dsc marine vhf
http://www.uniden.com/products/productdetail.cfm?product=SOLARA%20DSC
Posted on Aug 10, 2010
Can this SWR be accurately be used for a boat VHF radio antenna? I have tied it and it seem to work but do not know if the reading are good.
Standing wave ratio is standing wave ratio. This meter is not reading based on frequency. It is reading based on the measurement of electrical energy. I see no reason why it wouldn't work.
Jun 22, 2011 | Astatic (PDC7) CB Radio
I have an older uniden marine radio that i just bought and i am wondering how i get on the weather channels
Turn the radio on, set the radio to USA then use the up-down channel selector and scroll down to channel 1 that's it. Good luck.
Jan 30, 2011 | Uniden Solara DSC VHF Marine Radio
Ihave an old icom icm- 55 marine radio what ariel do i need and do i need to swr the ariel will a cb ariel work basically what do i need to do to get it working
All marine VHF radios must be licensed. A marine radio station must also have a call-sign allocated to the vessel it is installed in. Shore based stations can also be licensed but only where they are involved in marine based activities e.g Yacht Clubs, Marinas, Harbour Masters, Rescue Services etc.
In the UK ships radio licences can be obtained from Ofcom. They are free for non-commercial users.
The user must also have a Marine VHF Radio operators certificate. This requires taking an exam. In the UK contact the Royal Yachting Association for a copy of the syllabus and local examiners.
More information about the licensing rules, courses and exams can be found here. http://www.rya.org.uk/infoadvice/regssafety/Pages/licensingelec.aspx
The ICOM ICM55 is a good radio set and can still be used in an existing (marine) installation but it does not meet the standards for new installations as it does not have DSC (digital selective calling) capabilities - which all new fixed sets must now have. It is therefore very unlikely that you will be able to get a licence to install one.
To get it working you will need a proper marine band VHF aerial which operates in the frequency range 156-MHz. They usually come with cable attached but if a longer cable is needed, or the aerial is not cabled in the first place, use flexible 75 ohm co-axial cable with a copper core and braid/foil screen. Use proper aerial connectors (type F or BC are most commonly used and can be obtained from most good electronic component suppliers more cheaply than from a boat chandlers. Do not use push-fit TV aerial plugs)
Citizens Band radio works on the much lower frequency MHz band and therefore a CB aerial will not work with a marine VHF radio set. Please see this Wikipedia article for more information http://en.wikipedia.org/wiki/Marine_VHF_radio
Jan 28, 2011 | ICOM Informatique IC-F420-55 UHF...
Which antennae to use with a Uniden Oceanus radio?
Marine two way radios operate on 156 MGZ. You have to use an antenna desinated for that purpose. Type marine vhf antenna on google search and it will pop-up lots of web sites.good luck
Jul 21, 2009 | Uniden Solara DSC VHF Marine Radio
Vhf radio antennae
There's radioworld.ca on Steeles Avenue in Toronto.
Sep 16, 2008 | Motorola Radio Communications
2 way radios
Your radio with model number M33GMC09C2AA is a GM300 made for Central Asia, Eastern Europe and Turkey. It is VHF 25 watt with 12.5 channel spacing. It will do frequencies between 146-174 MHz. It should be able to be "read out" by a Motorola dealer. If it has been in a boat, it most likely is programmed with Marine frequencies. If you have another marine radio you may be able to determine the frequency by process of elimination.
The wiring kit for power is readily available for around $18 ea. If your boat has a marine VHF antenna onboard, you will be able to attach the antenna to this radio. It takes a mini-PL connector.
Sep 14, 2008 | Motorola Radio Communications
Any recommendations?
You can find a helpful guide at the following link:
http://www.boatsafe.com/nauticalknowhow/...
Have fun!
Nov 20, 2007 | Icom M302 VHF Radio
Boating Logo
201 people viewed this question
Top Motorola Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Motorola Boating Expert? Answer questions, earn points and help others
