Question about Dishwashers
Potscrubber 1200 by G E
It won't drain.
I can't seem to find a manual to help me take it apart.
  • 1,543 Answers
I believe you have a model with the screen running along the back at the bottom of the tub. I would remove the four stainless steel 1/4 inch hex head screws holding the screen and remove it. Next you will find a round part in the center with two tabs protruding from it. Use those tabs to unscrew that part and replace it (WD24x10018 check valve). At least replace it if the cone shaped part will not seal at the top side when the spring loaded plunger is pushed up. That is the most common reason your model will not drain. If that is OK, you may have to check for drain line obstructions.
Posted on Oct 22, 2008
I have a GE 1200 Potscrubber portable dishwasher it was running good until it started to drain then water started coming out the bottom is there a way to fix this? Please help me.
You can take the unit and lay it down. There will be some water leakage. You can then see the hoses and connections. Sounds like the drain hose is either cracked or loose.
Feb 08, 2014 | Dishwashers
When the water drains at the end of the cycle, water drains from the bottoom of the dishwasher, around what looks like an actuator arm? not exactly what the model # is all i know is it is a GE potscrubber...
Hi, I have seen this a lot when I did maintenance work for apartment communities.The part to fix this depending on modle was $85-$125 six years ago, I would just replace it.
Mar 05, 2011 | GE Dishwashers
Looking for dishwasher manual for Model Number GSC700X01AD. GE Potscrubber 700
is this the manual your looking for http://www.managemylife.com/mmh/owner_manuals/4241/GE-Dishwasher-L0801045?brand_name_search=GSC700X01AD+GE+Potscrubber+700+ if you have any further questions or feel that this is not the right manual message me back and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to help others in similar situations in the future Thanks Rick
Feb 13, 2011 | Dishwashers
I have the GE 206c1513p001 Potscrubber and recently found a black seal or rubber band in the dishwasher. Since then, it has been making a continuous clicking noise when it is run and does not clean the...
I have the exact same problem!!! Found 2 loose rubber bands, the bottom doesn't drain completely, and the dishes are left either dirty with a white film on them. Please help!
Oct 06, 2010 | GE Dishwashers
GE Potscrubber will not drain or cycle.
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 13, 2010 | Dishwashers
The dishwasher tower arm is broke
if the spray arm assembly is still in one piece(what i mean buy this,is that the bottom of it has'nt snapped off in the pump)it should be a simple matter of plugging the arm back into the pump & tightening the clamp(this is located on the neck of the pump)you will need to pull the unit out to gain access to this(it's under the tub)if this is not the case the arm itself is under 20$,as the sleeve & clamp assembly is under 10$hope this is of some help.thanx for using fix-ya.please rate all replys
Nov 15, 2008 | Dishwashers
Water not draining
For starters does it drain at all?If the drain line is connected to the sink drain and you have a garbage disposal,the drain hose could be plugged up.
Aug 06, 2008 | Dishwashers
GE Potscrubber 1000 with temperature sensor GSD1000M20-Water in bottom at end of cycle
Does it sound like it is trying to drain or is it just silent?
Jul 08, 2008 | Dishwashers
GE POTSCRUBBER 1200 DISHWASHER
I have a Ge Potscrubber 1200. Fairly new I guess as I bought it with the house that I purchased 1 1/2 years ago. Sometimes it drains and sometimes it does not. Today there was two inches of water! About to remove the bottom panel. Sounds like the drain valve it blocked but not sure. Any thoughts?
Apr 14, 2008 | Dishwashers
Dishwashers Logo
81 people viewed this question
Top Dishwashers Experts
