Question about Kenmore Washing Machines
Kenmore washer 8566645 wont stop filling and overflows
zeusfaber
  • 247 Answers
SOURCE: washing machine overflowing
I'd have a look at your water level detector to start with. Usually a narrow bore hose running from near the bottom of the drum to a pressure switch somewhere near the top of the machine. Most common problem is that the hose gets blocked with gunk. With the machine off and drained, try removing the hose and giving both it and the barb on the drum that it came from a good clean through. A.
Posted on Jul 17, 2007
huuum
  • 750 Answers
SOURCE: Kenmore elite SM9711174
Hello kenmooreMOMMY, ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Huuum At your service!
Like with an error code.
This can reset the system.
For starters unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
But in my opinion it is most likely a switch problem in the control board.
let me know how it works out.
How old is the appliance?
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Bless You, Huuum
Please remember to enter a rating here when you finish!
Thank You
You have a Kenmore washer. It's a top loader, and when the machine is filling up it just keeps on filling and won't stop. It doesn't go to any other cycle cause it's just filling and filling. It overflows all over the place. What can You do to fix this problem. You're clueless.
Posted on Sep 23, 2008
  • 21 Answers
SOURCE: Kenmore 70 series washer
if the water was overflowing from the top of the tub it sounds like the pressure hose came loose. tilt the control panel back and you will prob see the hose that connects to the left side (where you adjust the water level) has come loose. cut about 1/4 inch off of it and re-connect it.
Posted on Dec 29, 2008
Thunder55
  • 318 Answers
SOURCE: Kenmore 80 Series top loader washer overflows
It will not be a sensor,,,it will be what is called a "Ball **** valve" and they are pretty cheap to replace.
This same valve is in your toilet tank.
Posted on Jan 19, 2009
kel1guy2002
  • 3740 Answers
SOURCE: water keeps going and overflows
Hi and welcome to FixYa. I am Kelly
You will have to open the top panel for steps below
Water level control is handled by the water level pressure switch inside the top panel. It is about 3.25 inches in diameter, has 3 wires connected to it and a hose that looks like a small vacuum line.
Check that vacuum looking line for any holes, kinks or disconnects.
You will need about 3 feet of the same knid of line available from any autoparts store for this test.
Remove the machine side hose and connect the 3 ft hose you just obtained. DO NOT drop the machine hose into the machine.
Place the timer on the wash cycle and start the cycle
Result = fill
Force air into the hose orally until you hear a click.
Result = fill stop agitation begin
If it does not pass this test then the pressure switch is bad.
If water never stops flowing the water inlet valve has debris internally and will probably have to be replaced.
Don't forget to reconnect the machine side hose to the pressure switch.
Thanks for using FixYa!
Kelly
Then remove the vacuum
Posted on Feb 18, 2010
My Sears series 80 washer fills till it is overflowing and doesnt shut off water flow, it was overflowing onto floor this morning, it is full to the rim now, and wont drain or do anything when it is turned...
The usual arrangement is there are 2 electrical water inlet valves, one for Hot and 1 for Cold. These valves are turned on by the timer, and remain on until the water level switch turns them on, and allows the washer to then run. It sounds like this water level switch is bad. This switch should be in the panel above the top of the washer, and has a rubber/plastic tube that goes toward the washer drum. It is also possible that the rubber tube is off or blocked. (if the water inlet valve is stuck open, turning the washer off will NOT stop the water).
Good Luck,
Bill
Aug 17, 2012 | Kenmore 23822 Top Load Washer
My washer overflows. it wont stop putting water
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.########) and you'll see a list of major sub-components with diagrams and parts.
(The 110 means that it was manufactured by Whirlpool, you also need to enter the 8 digit model number)
Also see the Whirlpool / Kenmore Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It has testing procedures as well as a good description of how the washer works.
It sounds like a defective water level switch or water inlet valve.
See the following for how to release the console and cabinet on these machines in order to get to the switch for testing.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Basically, what happens is:
When the washer is turned on, the water inlet switch is closed allowing water to flow thru the inlet valve. When it senses that the machine is to the level selected by the water level dial, the switch opens shutting the inlet valves.
If the switch or valve is defective, water will continue to enter the machine.
The Whirlpool Service Manual has testing procedures (basis continuity tests with a multimeter) for both the switch and valve.
May 10, 2010 | Kenmore 24032\24036 Top Load Washer
Myn washer always overflowes as it filling it wont
This is usually the pressure switch. Also you could check the water inlet valve if water is still flowing in the machine after it stops. There are free videos on testing these components at www.appliancehelponline.com/servicemanual.html
You can also punch in your model # for diagrams
Mar 18, 2010 | GE Washing Machines
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
When I start the washer it continues to fill up and wont stop
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which one is... while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..The inlet valve is normally located in the back of the machine where the hoses hook up. The pressure switch can normally be found inside the control panel with a small rubber tube attached to it. You should replace the faulty part. If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Aug 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore model 8566645 Washer is connected and runs but water flows out of the bottom and not into the tub.
Remove the front and side panels if you haVE TO. Look for a bad water pump most common on older units.
The fill tube to the tub from the fill valve is a second likely problem
I water filter located under the tub and in line with the water pump is also a possibility.
A bad hose is not likely but a connection to a hose could be a problem.
Jul 10, 2009 | Kenmore Washing Machines
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore heavy duty 70 series extra capacity
This could be from a few things. First test. Turn on the washer to fill it up about 3/4 the way. Now turn it back off. Does the water stop? No? You probably have a bad water valve. Replace it. Yes? Listen for the sounds of running water or look for water on the floor. Do you see/ hear this? Yes? Your pressure hose has probably come off, reattach it. If it does turn off and there is not further sounds or leaking water, you probably need to replace your pressure switch.
Jun 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
54 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
