Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aqous 42"LCD..will not recieve digital over the air..it used to !!..any ideas???
This tv used to recievedigital channels but now it has almost no reception . i have tried 3 different ants. and even ran a cable to the other room ant. which is working fine on another tv...any ideas ?? i'm thinking maybe the tuner took a ****??
thanks abunch
Ken
    Scholar:
  • 70 Answers
First make sure you have a good signal, one you know definitely works. Then make sure you connect to coaxial input on Television. Put television on channel 4. Which is good indicator. If no picture/ just snow. You want to access your T V's Menu. Go to Channel Set Up. You should see SIGNAL TYPE. Make sure this is set to CABLE. Right below is a AUTO PROGRAM selection. Let the Television run all the way through. You should be able to view Television as soon as this is done. Providing you have a good signal and there is only one Coaxial input on TV. If there's more than one for example ANALOG, or DIGITAL. Try each one. Each Televsion is different. This is this basic troubleshooting steps. I've done this at a hundreds of installations and trouble calls. Good Luck
Posted on Oct 30, 2008
42 inches LCD TV,Aqous brand. where to buy parts inthe philippines
Sometimes the lizards can cause a lot of board wear-off as they being highly conductable and when shorted within the electrical circuit can make the secretions runs into the board therby contaminating and shorting circuits. If you are able to remove and use petrol to wash off the dirt on the board, look for open tracks that have burned or corroded. If you are able to trace and rewire using thin strands of wires , and assuming that no component damage had taken place, you can try this out.
If not as suggested you need to find the cost of a new board if a final consensus is taken.
Nov 07, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cannot find input for sharp aqous tv
The input selection should be on your remote and also on the right side of the set. (I believe)
Nov 10, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I HAVE NO RED COLOUR ON MY SHARP AQOUS 37D4OU
Recheck all ur tv connections,take out the incomming broscast coalax cable connect it to use on another tv,see have the same problem no red,no than it the tv Tuner board is dead,must be replaced the tv Tuner board.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Jul 01, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Has sharp 42 inch aqous got inbuilt digital tuner
Hi www_andremou
You are right. It has got a digital tuner. After you power on, press the Menu button on the Remote Control, select Setup. Select the Auto Installation. The Inbuilt digital Tuner will search for all the available channels r and tune automatically.
If you wish change the Volume and Screen etc
The Instruction manual gives full details.
Good Luck
luciana44
Dec 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Have new LG 42" LCD and no sound on the 5.1 Surround Sound
Try running a set of audio cables(Red/white) from your audio out jacks on the back of your TV to your reciever's audio in?
Feb 01, 2009 | LG 42LC2D 42 in. LCD HDTV
Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Dec 03, 2008 | Sharp Aqous LC-26D5U Television
Freeview channels (DTV) on a Sharp Aquos TV
On my Aquos it's saying no carrier and database empty what do I do, I have trying to reset TV but free view isn't coming on and it's saying carrier 0.
can anyone help
Nov 22, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp LCD 42" Aqous
If the tv's are still under a warranty program then get a repair tech to check it out They have access to technical websites and will be able to diagnose each individual blink code as they refer to different possible causes according to each specific model
Jun 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Volume control
I am a Sharp servicing technician and I have seen this "problem" with this particular model many times. I have tried replacing the Main Board and the Terminal Board and it does not help. The reason i put "problem" in quotes is because I came to the conclusion that this is model is just not that loud. However, a few months after the initial production run, BAM, these TV's are as loud as any other TV on the market so sharp must have caught onto this.
Dec 31, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
387 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
