Question about Home Security
I have a genie pro max PMX 300 IC/A garage door opener and bought a Genie 3-button remote (model G3T-R) and I can't get it programmed. I push the button on the back of the opener, push the button
  • 3 Answers
Take the opener apart and see if there are about 4 numbers that can be set. If you have an older remote take it apart and match the numbers, then program it.
Posted on Feb 07, 2012
  • 244 Answers
SOURCE: garage door slamming shut
springs are shot/wrong. door not balalnced.
Posted on Jan 15, 2009
dburns60
  • 410 Answers
SOURCE: Genie Directlift garage door opener, wall control problem.
Sounds like a skinned wire on your front or rear limit switches is touching metal. Go over your low voltage wiring and test again.
Posted on Jul 05, 2009
  • 31 Answers
SOURCE: Genie garage door openner won't stop when it goes down or up
there should be a "travel distance" adjustment screw on the opener.
Posted on Aug 26, 2009
blanchettohd
  • 143 Answers
SOURCE: The motor on my Genie Chain Glide garage door
If the chain does not move but the motor runs then you have stripped the internal gears. I would replace here. These chain glide units are not very strong. There might be a chance the chain is telescoping down the rail but the trolley is not hooked up. Pull the red cord back toward the motor to engage. Thanks BB
Posted on Sep 03, 2010
blanchettohd
  • 143 Answers
SOURCE: Genie Garage door will not
If you hit the button on the remote and nothing happens then you may need to code in the remote. On the motor head press the learn button and then press the button on the remote 3 times.
If it looks like the remote will work the opener or it opens the unit but not close it you are experiencing safety sensor problems. Make sure they are aligned. There will be a light on each and each should be on. Check the wiring to them too. They are not polarized. Thanks BB
Posted on Nov 06, 2010
How do I program a "clicker" brand remote for a genie pro 83 garage door opener?
generally you find the program button on the motor housing, press it once and it should start blinking, then press the remote button, and then press the remote button again and see if it works.
Jul 10, 2015 | Genie Pro Building Materials
What is the battery size for a genie garage door remote opener model gict390
The GICT390-1 (one button remote) and the GICT390-3 (three button remote) both use a 2032 coin cell battery.
The manual for the GICT390-3 is available from Genie on their Programming Accessories page: http://www.geniecompany.com/garage-door-openers/programming_accessories.aspx . The direct link to the instructions is: http://www.geniecompany.com/data/products/accessories/manuals/legacy/36484U_1-Btn%20IC1,%20390_3577435796.pdf .
I hope this helps.
Feb 25, 2015 | Televison & Video
Can I use a chamberlain remote with a genie pro garage opener
you can try to see if it works but probably no- get anather genie remote
Oct 02, 2014 | Chamberlain 953cd multi-function 3-button...
Genie garage door keychain remote not working
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 11, 2013 | Genie G3T-BX Keychain Intellicode Garage...
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
G3T-BX
check manual for erasing codes and reprgraming remotes should be something about a learn button
Oct 21, 2012 | Genie G3T-BX Keychain Intellicode Garage...
Unable to program universal opener with genie pro max garage
Actually, this remote can be used with Genie Garages. See the article here on eHow - I used this to program a KLIK1U to work with my Genie Promax 2 garage. Hope that helps!
Oct 11, 2012 | Chamberlain Clicker Universal Remote...
Genie g3t-r remote seems like it 's programmed but doesn't open door. led's suggest it was programmed.
1) test the batteries 2) rETIGHT THE spring contact batteries 3) Resolder wires for contact batteries, see if there are some wires missing. 4) Try again with the codes.
go www. fitness.manualsonline.com get the code , and reset again.
Otherwise the remote control you must go to the repair shop.
God bless you
May 09, 2012 | Genie Company IntelliCode GICT390-1BL...
Have a 3 Genie remote and the center button works in programming one garage door, but the side buttons will not work to program the other garage door. Can you help?
The other opener has to be a genie, compatible genie to be exact. An older one will not work with new devices. If it will not program it will be the openers fault not the remote. Thanks BB
Feb 16, 2010 | Genie Company IntelliCode GICT390-1BL...
Home Security Logo
1,333 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
