Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Legacy garage door opener
I hear the motor go on but garage door does not operate.
The belt which connects the motor to the door may be slipped, place it to the correct position.
Posted on Oct 22, 2008
I have an overhead garage door Legacy 496cb/d that stopped 3/4 of the way in the down motion. It now will not open or close and only clicks. The lights work and power is on.
If this picture at the link shown looks like yours, the red and white cord with the red plastic piece needs to be pulled to disconnect the automatic door opening chain.
http://www.aypapaquerico.info/overhead-door-legacy/overhead-door-legacy-large-size-of-garage-and-modern-overhead-garage-replacement-with-legacy-opener-overhead-door-legacy-496cd-b-manual/
Then, pushing the garage door fully open should move the mechanism back to connect in the ceiling. Then the remote control may work. If not, seek a repair service.
Mar 18, 2018 | Building Materials
Garage door lift door mechanism maintenance
disconnect the motor and operate the door manually. check and adjust until it operates correctly. re-attatch the motor and check operation. provide a more detailed question if this does not help
Apr 09, 2014 | Sears Craftsman LiftMaster Chamberlain...
Unit has power, went up, won't go down. Pushed re set, still nothing. Can hear unit try to engage but will not operate
Check to see if the trolley is jammed against the bolt just in front of the motor housing. If it is you need to loosen the chain enough to release the tension and then run the opener until the door is closed.While the door is closed, locate the 'up limit' control on the side of the motor unit. Turn this 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
I had a lightening strike at my home. Since then, the garage door does not function with wall switch or remotes. when i press the switch, light comes ON on the door opener and i hear a click but nothing...
Well, I don't think that disconnecting the garage door from the garage door opener would affect function.
The lightning strike could have destroyed the circuitry inside the garage door opener, seeing that it won't operate with the wall switch or remotes.
It's likely that a board was fried by the lightning which would render the garage door inoperable.
Aug 08, 2010 | liftmaster Chamberlain Garage Door Opener...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: when i push the wall unit i hear a click from the ...
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor. It may be going bad.
May 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door hums but does not open. It had
Sounds like you have a bad start capacitor. It sits next to the motor and is about the diameter of a silver dollar and about 5 inches long. You can get one at any good door opener service company.
Feb 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
150 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
