Question about HP w1907 LCD Monitor
Gray volume box that won't go away
There is a gray volume box that is probably 3" wide and 6" tall that I cannot get off of the screen. Pushing the "menu" and "auto select" buttons remove the box for about 2 seconds before it returns. I plugged the monitor into a laptop and did not see the box, and when I plugged the monitor back into my PC, the box did not appear while I was working. Once the PC went into sleep mode and was reawakened, the box returned. Might this be some software running? I don't see anything in the task manager that makes any sense. Thank you.
  • HP Master
  • 1,891 Answers
What PC, ? we can not guess, what you have there.
well its sleep mode bug , right?
and sleep and hibernate both are very hard to get working perfect.
some folks just avoid those 2 modes, and live their lives
other spend weeks fixing it.
The auto-drivers are bad. in the PC that fails.
no PC stated, or OS stated, so how can anyone help.
here reload windows from HP media set. or F11 recover mode
or go to hp.com and download all drivers
and reload them all.
or just audio. but do know other chips work in concert with audio
sound chips, so.. all related drivers must be good.
pretend W7
pretend you googled
Windows 7, audio driver fails coming out of sleep.
or ask on the HP forum
tell which PC failed, and its model # in full.
http://h30434.www3.hp.com/
Posted on Apr 25, 2017
nliwilson
  • 114 Answers
SOURCE: the monitor just wouldn't turn on from the sleep mode.....
A little more info pleas. The single most common cause of this particular problem is the monitor being plugged in to an inactive VGA socket. Most manufacturers build several models of computer based on the same base components, you will often find that your computer has both a reasonably powerful graphics card plugged in to a socket on the motherboard and a less powerful, basic graphics chip built in to the motherboard that is disabled. The reason for this is that the base model of your computer is only supplied with the basic graphics chip but if you paid for a more powerful model a more powerful graphics card was supplied that disables the basic chip. have a look at the back of your computer (the box you described as the CPU) and see if you have 2 blue sockets with 3 rows of pinholes in them, if you do your monitor needs to be plugged in to the one that is higher up and sitting horizontally. If not message back.
Posted on Aug 10, 2007
SOURCE: Going to Sleep
got the same issue
hp pavilion 1723
Posted on Feb 02, 2008
Mark_Webber
  • 472 Answers
Due to the power surge, it is highly possible that the monitor was given a boot by your computer on it's way out.
This will short out a very small transistor inside the monitor on the video board and in turn, then monitor cannot see that there is a signal so goes to sleep.
If you get brave enough to venture inside the screen, then check near the cable input. The transistors are only around 3mm and have 3 legs (two one side and one in the middle on the other).
If you find anything like that burnt (get a magnifying glass) then replacing the board is the easiest option. Just don't be tempted to wipe the board before you look at everything very closely, you may wipe away the tiny bit of evidence you are looking for.
Hope it helps =)
Posted on Apr 09, 2008
  • 9 Answers
SOURCE: problem on hp monitor
I have a Dell E171FPB monitor that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
Posted on May 30, 2008
SOURCE: monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Posted on Sep 13, 2008
My LG HD tv screen has a wide, gray band on either side of the picture
Try changing 'perspective' or screen ratio.
This may work, but could also stretch the picture too wide,
On my non-LG TV this is called 'aspect ratio' under the 'picture' menu.
Nov 20, 2017 | LG 42LB1DRA 42 in. LCD Television
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Volume box won't go away!!! On iPod
did it get wet? is it dirty?
Mar 03, 2013 | Cell Phones
Samsung NT700G7A volume display won't go away
try and check in safe mode and uninstall reinstall video and chipset drivers in safe mode...then reboot system...to enter safe mode keep tapping f8...thanks
Feb 11, 2012 | Samsung Computers & Internet
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
Big gray spot on screen
Unfortunately, It's likely that your screen has been irreparably damaged. Probably, pressure was applied to the screen and ruined that part of it.
If you like to fix electronics, it may be possible to buy a non-working Sansa on eBay, open the case and replace the screen.
You can probably continue to use the player without fixing the gray spot. If it bothers you, the easiest solution would be to get another player....
Dec 03, 2011 | SanDisk Sansa Audio Players & Recorders
There are 6" wide gray bars on each side ot the TV
The grey bars signal that the source image is originally in 4:3 format - if you are using a box of some kind get in its menu and change the format from there to 16:9. The black bars appear when a 16:9 image is sent to a 4:3 format in Letterbox mode - leave it like that or the Pan and Scan mode will chop the sides.
Jul 20, 2011 | Panasonic Viera TH-42PX80U Plasma TV
I have no voice at all, how wood i get my volum ajusted.
Hi!
1. If it is visible, single left click on the 'Show hidden icons' button, which is usually located near the bottom right hand corner of the screen. 2. Single left click on the 'Volume' icon, which looks like a gray speaker.
3. Single left click and hold down on the slider in the 'Volume' dialog box. As you are holding down on the left mouse button, drag the slider up to raise the volume or drag the slider down to lower the volume. When you let go of the left mouse button, you should hear a tone to give you an example of how loud the volume is now set. 4. Single left click on the on the blue 'Taskbar' to make the 'Volume' dialog box disappear.
Hope this helps. :)
Apr 16, 2011 | Dell Dimension 2400 PC Desktop
Im replacing my kenmore #110.68932792 how many cu ft is it
to find the volume of an object you would have to multiply the length x width x hieght for example if an object is 2ft tall 2ft wide and 2ft long your object has a volume of 6 cu. ft
Jan 31, 2011 | Dryers
HP w1907 LCD Monitor Logo
177 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
