Question about Konica Minolta magicolor 2400 Laser Printer
VERTICAL LINES ON KONIKA 2400
I CANT GET THE VERTICAL LINE OFF OF MY KONIKA PRINTER KONIKA PRINTER 2400W
  • Anonymous Oct 23, 2008
    every page got the center missing with a print out
  • jwerne Nov 12, 2008
    Center of page does not print.
    This started when I changed the Black cartrage.
    Prints the same in B/W and color.
  • 210 Answers
If the line is white (no toner is added in that area) check the laser head glass which is located right below the drum. Remove the drum and you should see it below a narrow strip of glass. Just be sure to be clean, with no dirt, toner or pieces of paper on it.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 12, 2009
KONICA MINOLTA 2400W PRINT BLANK PAGES
Verify the drive transmission mechanism to developing unit,the image transfer current terminal and the scanner drive transmission mechanism.
Feb 13, 2013 | Konica Minolta magicolor 2400 Laser...
Remove lines in print from Minolta Magicolor 2400w
check the fusing unit the hot part where the paper comes out? is the line a certain color replace that image unit.
Sep 22, 2012 | Minolta magicolor 2400W Laser Printer
How can i install my printer magicolor 2400w with no cd
Thank you for your question.
I have provided a link to the page where you can download the driver for your printer. You can save it to your computer and when installing the printer, point the "wizard" to the file you have saved when it asks for the driver.
Kind regards
Apr 22, 2010 | Konica Minolta magicolor 2400 Laser...
Where can I purchase a replacement fuser for konica minolta magicolor 2400w
You could buy it from :-
http://cgi.ebay.com/Konica-Minolta-Magicolor-2400-2400W-2430DL-2450-Fuser_W0QQitemZ180400879568QQcmdZViewItemQQptZPrinter_Accessories?hash=item2a00baf7d0
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 05, 2010 | Konica Minolta magicolor 2400 Laser...
Konika Minolta 2400W can not connect. Clearly Windows XP sees it, and the driver is installed etc. When I plug or unplug the USB cable, Windows plug 'n play notices the difference. And the USB cable works...
Everytime you disconnect and reconnect the USB cable to a different port, unfortunately, Windows creates a new and distinct copy of the printer. You can see this by looking at the Windows Printers folder. The solution is when you change around USB ports, right click on the printer icon that is actually the active one (the other copies will be grayed out) and Set to Default. Then you can delete the other invalid copies. Then in the Minolta status software, go to the Display menu and Select Printer to change which printer is monitored to the correct copy. It's very stupid that Windows Plug n' play does this, but it does. So avoid change around USB ports on your Konika Minolta printer.
Jul 19, 2009 | Minolta magicolor 2400W Laser Printer
Printer won't print until I restart my computer.
After you have this problem again. Go to Control panel and look for administrative tools. Click on services and scroll down until you see the print spooler service.. Right click on this and select restart. Let me know if the printer then functions after this.
Jun 17, 2009 | Konica Minolta magicolor 2400 Laser...
Printing with MAC 10.5 and Minolta 2400W. How can
http://www2.konicaminolta.co.uk/more-information/support.html
Try this link for any help.
Jun 16, 2009 | Konica Minolta magicolor 2400 Laser...
Laser printer
I developed a color print that has all 4 principal pure toner colors in vertical and horizontal bars that are at least 2" wide.  If perhaps you are having a toner problem only one of the colors will be affected.  If all colors are affected there are two possible issues.  The drum, which I think is actually a belt, and the other the fuser assembly.
The fuser is a heater and pressure roller system that presses and melts toner onto a page.   The drum is an imaging device that picks up toner where images should be and transfers toner onto a piece of paper.  Any toner not transfered from the drum / belt is destined for a waste toner hopper.  If the belt is not being cleaned properly or has an image or flaw artifact that cannot be cleaned / erased you always get that printed on a page.
Aug 04, 2008 | Konica Minolta magicolor 2400 Laser...
Konica minolta magicolor 2400w printing proplem
pleas check transfer belt, and drum unit, probably these lines are caused by drum unit and you have to change it. also you can clean laser glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
May 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
457 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
