Question about Sony FD Trinitron WEGA KV-SW29M50 29" TV
Sony tv model kv-sz29n50 trinitron
Whene i flug my tv i see in video horizontal block booth side there is waist video whene i flug my tv the power is off thene i turn on again i see the problem video there is waist and booth side is block hep me pls! thnks a lots!
  • 5 more comments
  • luckyjoy Oct 22, 2008
    yes the same the problem tv model KV-SZ29N50 SERIAK NO.1001409 POWER ~110-240 VOLTS 50/60HZ 138 WATS THIS IS ONLY I SEE BACK PANEL THE INFORMATOIN THANK YOU VERYMUCH SIR FORE YOURE HELP ME!
    MODEL KV-SZ29N50 SERIAL NO.1001409 A/CPOWER IS~110-240VOLTS 50/60 HZ 138 WATS YES THE SAME PROBLEM YOU SHOW ME THE SAME PROBLEM I WAIH YOURE REPLY THANKS ALOT SIR
    yes i see confirm isee the picture the same the problem on my tv vedeo
    yes i repair by my self i have i know basic electrnonics i finish tv vcr repaire in ics internationalschoolpaiselvania and finish electronics technology thanks for youre helf me give me idea what is couse off trouble capasitors or resistor on primary power suply
    this new model i dont have idea yet if you give me idia what pars i see i open on my tv one of pars is heat and one capasitor is over heat like capasitor but there is coil this parts is become melt can you help me sir for this problem my dont hav watching tv pls sir help me for this problem
  • luckyjoy Oct 23, 2008
    sir i waithing youre reply sir beacouse i go back to riyadh nex week i have many friend out thre all pakistani doctors i hope you help me sir
    the picture is narow and has black bars on the sides the problem is probably horizontal yok
  • 10,594 Answers
Please confirm do you see this kind of picture in TV?
Mention exact model number to help you.
Posted on Oct 22, 2008
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Oct 22, 2008
    Ok, Thanks for update and reply.
    Let me know do you want to repair it by yourself or just want to know where can be problem in tv.
    If you want to repair at your own, you should know basic of electronics and some know how of tv repair like parts recognition and good solder work etc.
    Shahid Electronics Oct 23, 2008
    I'm in Pakistan and due to time difference there would be delay in reply to your question.
    See below picture circled problem area of main board of your TV. You need to confirm / check Q505, L507, C567. These parts can be cause of problem.
    Let me know circuit code of defective parts found to provide you part numbers etc.
    Below is portion of Pin Amp circuit of tv for guidance.
    Problem is called Pin Cushion and its related to pin amp stage. (conjenction of horizontal & vertical pulses)
    Please do not mess with yoke or any thing else in tv.
  • euad Jan 27, 2011
    that was so accurate! thank you very much!!!
  • bluethunder
    bluethunder Oct 13, 2014
    tnx a lot sir for your guide, noted since im far from the unit which i trouble shooted, but i really appreciate your guide/advice, tanx once again
  • 905 Answers
You can ask me
Posted on Oct 23, 2008
Thks a lot sir i salve the problem to yore help i found one of tuning capasitor is crack and one of coil is burn deef burn on coil
Posted on Oct 28, 2008
My tv is samsung 21A530 ultra slim the problem there are curve in all corncers and horizontal bar on the top and bottom
The problem of your television is the abnormal screen like the pincussion in booth side and bar at top and buttom.The cause of that is the abnormal supply voltage of the crt board.The power supply have low output voltage because deffective and leak parts like the regulator transistor or capacitor.If the power supply is low voltage it affects the apperance of the screen of the TV.So its better to replace the deffective parts of you television to came back the normal appearance of you TV.If you do not know how to repair and troubleshoot its better to called a repair technician.
Jul 11, 2011 | Televison & Video
I have a 32" Sharp LCD tv and last night we had a
You have a bad HOT, horizontal output transistor. It will have a number on it, and you can find it here.
http://shop.ebay.com/i.html?_nkw=horizontal+output+transistor+&_cqr=true&_nkwusc=horizontal+output+transitor&_rdc=1
Watch part replacement videos to get this working again. Also check for bad parts around this transistor if you have multimeter and component experience.
Jun 19, 2011 | Sharp 32R-S50 32" TV
Whene my hp a6300f pc is turned on only a black screen is seen
You should see first the RAM modules. eject one and try to start the pc without that. If starts you have to replace that module. If dont, try with the other one. do the same with HDD and each Motherboard periferic (DVD, Card reader etc.)
Apr 19, 2010 | HP Pavilion Desktop a6300f Intel Pentium...
My laptop whene i turn it on it starts to update thene it will say shutting down . and thene it starts to update again
You have been attacked by a virus. Total take over!
Just find a way to slave your hard disk, either as an external or over a network.
From a computer with an Antivirus software that is updated, scan the disk and eliminate all viruses found.
When done, backup your files and format the hard disk.
Then, use a bootable CD to setup the system again.
Apr 03, 2010 | Gateway MT3705 Notebook
I need to know where i can find the flug to heat the engine dvernight?
You are going to have to get down on your knees and in the lower part of the front grill closer to the drivers side of the vehicle will be a black cap covering the block heater plug. The cap is on a hinge and ours flipped towards the passenger side if I remember correctly.
Dec 08, 2009 | 2000 Ford Windstar
Why is my light bulb sybol lit up orange
It's telling you your lamp is reaching the end of it's life you need to replace it.
Jul 28, 2009 | LG RU-52SZ51D 52" Rear Projection...
Power Problem
if you tried to take youre psp battery apart to try and make a pandoras battery then all you need to do to turn it on is to take battery out plug charger in turn on put battery back in pull charger out and ther you go. if thats not youre case thene im sorry
Aug 24, 2008 | Sony PlayStation Portable (PSP) Console
Television wont turn on.
try to check first if theres an output voltage in the wall outlet. if there is, you have a completely inoperative (dead) set. this symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or IC), it may also be caused by a breakdown in the horizontal deflection circuits (horizontal oscillator, pre-drive or drive circuits). this is because the supply voltages for the tuner, video intermidiate frequency (VIF), video amplifier, sound intermidiate frequency (SIF) and vertical output circuit are usually supplied by the horizontal output circuit. but again, if you are not inclined in this kind of job, better bring it to a qualified tv technician. good luck!
Feb 04, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Broplem
i beleive the problem of your TV is the horizontal circuit probably cold solder. if you have soldering equipment, try to resolder the circuit. but if you don't know anything about this, i suggest you bring it to a qualified person.
Jan 14, 2007 | Toshiba 19A25 19" TV
No power
The problem with this set is most likly the flyback transformer, the horizontal output transistor, and possibly the supply voltage resistor off the horizontal driver transformer. Its a repair a pro should only attempt, as its the Hi Voltage circuit and a TV set is not a place to experiment with or tinker in them. This repair in my area cost anywhere from $175 to $250 to repair. Good Luck
Jul 31, 2006 | RCA F32676SB 32" TV
Sony FD Trinitron WEGA KV-SW29M50 29" TV Logo
2,144 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
