Question about Icom Ic 2200h Vhf Mobile Two Way Radio Ic2200h Ic2200 H ()
How to change face light from amber to green ic 2100h
How to change face light from amber to green icon-2100H
Power on, push v/mhz,then set to scroll thru to what you need Turn Dial to make aappropriate adjustments from GREEN to AMBER
Posted on Jul 24, 2012
Weak signal receive of ic2100h
The reference would not prevent you from receiving. It is more likely that the pin diodes in the antenna TX/RX switch are defective or the RX front end amplifier is shot. Check the diodes with an ohm meter. If you get a short across one, check with the leads reversed. if you still get a short, then the diode is most likely shot. Make sure you have the schematic to follow. You can get it at www.mods.dk.
Feb 06, 2014 | Icom Ic-2100h 144 Mhz Vhf Fm Transceiver...
Howto change face light from amber to green on ic2100H
http://www.icomamerica.com/en/downloads/DownloadDocument.aspx?Document=2 Page 74 and 75
Feb 07, 2012 | Icom Ic 2200h Vhf Mobile Two Way Radio...
I have a Whynter ph-2100h and the pilot will not light the burner nor will it stay lit once i have ignited the pilot. The gas runs for approximately five minutes then shuts down completely.....help
I would think the thermocouple isn't working. The thermocouple provides the power to open the gas valve. One end of the thermocouple should be in the pilot flame, it is on the end of a small copper tube that connects to the gas valve. Make sure you are following ignition instructions. Hope this helps ya.
Dec 22, 2010 | Whynter SOLARIS 41000BTU Outdoor Propane...
R71A replacement of the DP-2 Matrix Board
The best source of info is Paul Hansen in Columbia, SC. He is an ICOM approved warranty service tech, and the last telephone # I have for him is: 1-864-222-3539. He fixed an ICOM IC-2100H for me four years ago, and I was very pleased with his work, and repair cost. At least, give him a call. I do not think you will be displeased with him.
Longshorts.
Jul 10, 2009 | ICOM Informatique Icom F21GM GMRS Radio...
Icom IC-2100H Sqealing
The squeal in this model is a famous problem. If you look at the circuit board, you'll see there are a few places where it looks as if someone kinda forgot to put in a ground screw -- even to the point that there are threaded holes in the casting just begging to be filled by the little screws used elsewhere nearby. Take 3 or 4 similar screws, put them in the remaining holes, and make sure all (including the existing ones) are snug. It seems there just weren't enough ground points for all the RF swirling around on the solder side of the board, so there's a bit of RF feedback on this radio. And as long as you've got about 16 amps of clean DC, you're fine; the power leads are correctly fused at 20 amps. BTW, the power amp module in this model is really only spec'd at 144-148; if you're running an odd "MARS or CAP" split, the PA brick can get way unhappy. HTH, -- Barney --
May 07, 2009 | Audio Players & Recorders
Change the colour
CLICK HERE for a PDF copy of your owner's manual.
Page 17 States to change the display color -
Setting the Multicolor Illumination
ILLUMI BLUE (Initial setting) / ILLUMI GREEN/ILLUMI AMBER /
ILLUMI RED
You can change the lighting color of the following four buttons:
SOURCE/POWER, BAND, (left << arrows) and (right >> arrows).
BLUE > GREEN > AMBER > RED > BLUE
• According to the lighting color of the above four buttons, the color
of the other buttons also changes. When the color of the four
buttons is AMBER/RED, the color of the others is AMBER. When
the color of the four buttons is BLUE/GREEN, the others are also
GREEN.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | Alpine CDA-9847 CD Player
Face plate LED Color
What is the model number?
Oct 01, 2008 | Sony Car Audio & Video
Icom Ic 2200h Vhf Mobile Two Way Radio Ic2200h Ic2200 H () Logo
122 people viewed this question
Top Icom Boating Experts
Steve
Steve
Tony
Lawrence Oravetz
Are you an Icom Boating Expert? Answer questions, earn points and help others
