Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
On 1-vars stats i cant put comma - Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
4 Suggested Answers
  • 8068 Answers
SOURCE: my 1-var stats button is not working it says the
You will have to report faithfully the message returned, you cannot use your interpretation of the message. Error messages are codified. Each one will correspond to very particular error conditions. I did check the manual for all possible error messages and there is none that states wrong info.
My hunch is that there are errors in your data, but I can't say what type of error: I do not have the actual message returned. Verify you data, item by item, and try again.
To make sure that the calculator is well configured to do statistics
  1. Press [STAT][5:SetUpEditor][ENTER]
  2. Press [2nd][0] (CATALOG) and press [PRGM] (C) to jump to the first command starting with C.
  3. Scroll down to [ClrAllListsts] and press [ENTER]
  4. Calculator replies Done
Restart your statistical data entry.
Hope it helps.
Thank you for rating this solution
Posted on Dec 11, 2009
  • 8068 Answers
SOURCE: when I type a list of numbers into L1 and then hit
  1. Press [STAT][5:SetUpEditor][ENTER].
  2. Press [STAT][1:Edit..]
  3. Enter your data in L1.
  4. Press [STAT][CALC][1:1-Var Stats].
  5. Command echoes on main screen.
  6. If ONLY one list contains data, it must be L1.
  7. When you do not specify the list in the command line it will take L1 by default.
  8. If L1 is empty and the data is in L2, or another but L1, the name of list must be specified.
Posted on Feb 20, 2010
  • 8068 Answers
SOURCE: When I go into the 1 Var-Stats menu, I need to
If you are performing 1-variable statistical calculations, that presupposes you have one set of data only. Technically all you need is ONE LIST where the data is stored (ex. L1) . However if you have some data elements that are repeteated, you may choose to create a second list where you enter r the frequency (L2 or other). Both lists must have the same dimension (length).
When you bring up the 1-var calculation menu , the list of data elements is specified on one line (Xlist) and the fequency List is specified on the menu line Frequency. Thus there is no need to enter two lists on the Xlist line.
Posted on Oct 19, 2011
My TI-84 plus silver edition doesnt allow me to use the comma when using the 1-Var Stats button.. I can't use more then one list and I need the mean of both lists
Pay attention to the name: 1-var statistics mean you have ONLY one list of data. So you cannot use two. However if some data values are repeated you may choose to create a FREQuency list. So at most you have two list, one for the data values and the second for their frequency.
When you use the 1-var stat, specify the list that holds the data value (Xlist) and one the FREQ line specify the list that has the frequency
If your data values are in L1 and L2 or any pair of lists, then you should do 2-var stats. You will get the stats of both lists, you can also perform regressions, etc.
Apr 09, 2012 | Texas Instruments Office Equipment &...
How do i calculate the standard deviation
for 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. you should be able to recognize what each variable means.
Oct 26, 2011 | Casio fx-300ES Calculator
When I go into the 1 Var-Stats menu, I need to type in L1 and L2 but my comma button will not work. It will only let me type in one list at a time, and if I put two lists in without a comma it says error....
Oct 16, 2011 | Texas Instruments TI-84 Plus Calculator
I am curently taking Statistics and when I hit "stat" then enter information into the L1, L2 , L3 area etc then I go to stat again and press calc and choose option 1 then in the list area I need...
I have followed your description and entered bogus data in Lists L1, L2, and L3.
I hit STAT then CALC then Option 1, which is 1-Var Stats. In this context you have only one set of data. If the data set contains many repeated values you can enter the frequency for each (repeated) data item in List L2, inserting 1 if an item is not repeated.
Thus when you do 1-Var Statistics you have at most two Lists (L1 contains the data values, and L2 their frequencies).
If you press the 1-Var Stats calculation option, the calculator takes L1 as the default data list so you see List:L1 and the ALPHA cursor blinking
On the secoond line you see Frequency: and nothing else on the line.
On the third line you have Calculate.
If Your data is not in L1, you can change that by pressing the [2nd][2] (L2), or [2nd][3] (L3). Only one list is specified there, so no need for the comma to separate. (you are doing 1-var Stat).
If your frequency data is in L2 you must specify it on the line Frequency. However, since the ALPHA keyboard is activated you must deactivate it first by pressing the ALPHA key. After that press [2nd][2] to select L2 or [2nd][3] to specify L3
If there is no frequency list, leave the Line frequency empty.
Aug 25, 2011 | Texas Instruments TI-84 Plus Silver...
Cant figure out how to do standard deviation on this calculator
TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume you know the theory. I will show you the key strokes
For 1-Var statistics
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Jan 12, 2011 | Casio FX-115ES Scientific Calculator
Standard deviation
Here it is.
Oct 07, 2010 | Casio fx-300ES Calculator
How to calculate standard deviation
Aug 27, 2010 | Casio FX-115ES Scientific Calculator
HOW TO USE LINREG(AX +B)
The post addresses several questions
  1. 1-Var statistics and standard variations
  2. 2-Var stats (calculating the statistical values)
  3. Regressions (linear or otherwise)
I assume you know the theory. I will show you the key strokes for 1-Var statistics and 2-Var statistics
- To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
REGRESSIONS
To use the regression a+bx,
1. Select STAT mode : [MODE][3:STat] [ENTER][2:a+bx]
2. Fill the X and Y values in the template.
3. Press [SHIFT][STAT][7:Reg]
You have several options 1:A to get coefficient A, 2: B to get coefficient B, 3:r etc.
To access each one, you have to press [SHIFT][STAT][7:Reg] anew.
To access the various sums, you press [SHIFT]{STAT][4:Sum] and you can select Signa_x, Sigma_x^2, etc..
Jul 15, 2010 | Casio FX-115ES Scientific Calculator
How do I use stat plot to graph a set of points?
1.Press [MODE], scroll to set Function graphing mode.
2.Press [STAT] [5:SetUpEditor], command is pasted in home screen. Press [ENTER]. Screen displays Done. This clears old values in lists
3. Press [STAT][1:Edit] to enter data.
Press [ENTER] after each number. Cursor moves to next row. After finishing the data of Listt L1, use arrow right and UP to the head of list L2. Enter the values in list L2. Press Enter after last element.
4. Press [Y=] to display Y= editor. Clear function Y1 and all functions or remove highlight from the = in Y2, Y3, etc.
5.Press [2nd][STATPLOT]1 to select 1:Plot1
The blinking cursor on ON means graph will be drawn. Type chosen is Scatter plot. Mark chosen is a dot.
Press [ZOOM][9:ZoomStat]
If you think that the curve look like a straight line you can try to do a linear regression.
Press [STAT] Arrow right to highlight [CALC]
Select [4: LinReg(ax+b)]
LinReg(ax+b) echoes on run screen. Press [2nd] L1 Press comma, Press [2nd] L2 press comma Press [VARS] Arrow right to select [Y:VARs][1:Function] [ENTER][1:Y1]
68a28f1.jpgENTER
That is the equation for the linear regression. As you see eqaution has been saved in Y1. Press [GRAPH] to get the data and the regression curve drawn on same graph.
Hope it helps.
Oct 04, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
329 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
