How to clean the filter on a ge gsd3606k00ww
How to clean filter
  • brad Feb 07, 2012
    how to get to answer
Why is there a ***** smell?
I worked extensively on GE Zoneline AZ Air Conditioners and Heat Pumps while a Maintenance Superintendent at a Senior Citizen's Apartment Complex. Not knowing what type of smell to which you are referring, I can assure you that other than "burnt electrical" smells, the only smell that could possibly be produced would be that from within the INDOOR SPACE. Perhaps something has made its way into the INDOOR AIR FILTER? Perhaps that INDOOR AIR FILTER needs to be cleaned. To clean the INDOOR AIR FILTER, simply lift both of the filters from the front cover, take to your clean bath tub. Run EXTREMELY HOT WATER from the back of the filter to the front of the filter. Then, fill your bathtub 1/4 way with EXTREMELY HOT WATER. Add 1 cup of Hydrogen Peroxide and 1 cup of Real Lemon Juice. Set both filters in this solution for 30 minutes; then rinse with clear water. Set filters up to dry for at least 2 hours in the sun or an air breeze. Replace filters into the GE Zoneline.
Also, not knowing how OLD your GE Zoneline system is, the COILS may need to be cleaned. To do this, simply turn OFF your GE Zoneline unit and remove the front COVER of the unit. Next, mix in a spray bottle 4 packets of LEMON flavored KOOL-AID (without SUGAR) and water. Shake well. Spray the INDOOR COILS of your GE Zoneline unit with the entire contents of this mixture. Let set for at least 10 minutes. Then turn your GE Zoneline to the COOL position. The citric acid in the lemon kool-aid will be forced through the coils to continue to remove any dirt, dust, debris and effectively CLEAN those coils. This will also provide you a LEMONLY odor within your room. Simple and cheap.
Enjoy your GE Zoneline unit.
Aug 30, 2014 | GE Zoneline AZ55H07D Air Conditioner
The dryer flashes the minutes and then cL and it says to clean the filter. It is clean but it wont turn on
It say to clean filter because it senses poor air flow so if filter clean the air flow is restricted,that could be caused by a restricted vent or espically in ge dryers the filter/blower housing is built up with lint and needs to be taken apart and cleaned
Jul 28, 2011 | GE Dryers
How do I clean the washer pump filter in my GE-WCVH6600HGG?
please go through this http://www.youtube.com/watch?v=x7rJkWE0nN0
Instructions:
  • Examine if there's a problem with the filter. If the machine isn't draining, spinning or agitating, the washer pump filter may be clogged, and you should clean the pump filter. Other giveaways that the filter may need cleaning include the washer performing an incomplete cycle, the timer not advancing or the washer just not running
  • Open the pump access door with a coin. Remove the pump filter by turning it counterclockwise and pulling it out.
  • Clean the filter with your fingernails, removing all loose debris. Wash the filter under running water until it is clean.
  • Replace the filter. Insert it back into its housing, turn it clockwise and close the door.
  • i hope this helps you ,thank you
    Feb 10, 2011 | GE Washing Machines
    Lint filter on GE wbsr3140dw
    Open the door and lint trap is right in front, just pull up and it comes out. Clean and replace.
    Sep 20, 2009 | GE WBSR3140DW Top Load Washer
    Front load ge washer does not finish cycle
    This model does not have a drain filter. There are filter screens inside the inlet valve where the hoses attach onto the machine. Take hoses off and look inside where the water goes into machine to see screens. Also, take the other end off hoses to make sure there are not screened hose washers in either end of the hose which may need to be cleaned or replaced.
    Oct 18, 2008 | GE WSXH208A Front Load Washer
    Wash machine agitates but won't drain the water -- on any cycle choice. Machine makes noise like something is happening, but water remains.
    Yes, the problem is the pump filter which is hidden behind the lower front panel. To access the filter, unscrew three screws at the bottom of the panel and carefully remove the lower front panel. Make sure to unplug the machine. With the panel removed you will see the pump filter. Get a bucket and some towels ready, because when you open the filter, you may get a gallon plus of water coming out. GE failed to put this in the use and care manual for the 6260. But low an behold, GE put an access door and explicit instructions on cleaning the pump filter in the updated 6400.
    You may have burned out your washer pump. That is what happened to me. The machine would not drain or spin properly and so I kept pushing the blinking start/pause button to get it going again. Then it finally did not drain at all. I installed a new pump and with the cleaned filter, the machine worked like new. For some, simply cleaning the filter allows the pump to work properly. As the filter gets clogged the pump has to work harder and harder to pump out the water. When this happens the cycle times get extended . One symptom of a clogged filter is the final minute (spin cycle) takes much longer. Obviously this is a "design flaw" that GE "fixed" in the recent version of the 6260.
    Jul 07, 2008 | GE WCVH6260FWW
    DCVH515 GE Gas Dryer
    The sensor in the filter "PATH" is actually located past the screen. It measures the amount of air flow passing through the exhaust cavity going outside. My suggestion is to clean the airflow duct from right past the lint filter all the way out side. It is recommended that this be done once a year for optimal performance. If this doesn't work, let me know.
    Mar 16, 2008 | GE DCVH515GF Gas Dryer
    Washing Machines Logo
    108 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
