Question about Honeywell Programmable Thermostat Heater
I just installed a honeywell RTH2510 thermostat but the heat won't kick on, it is electric?
Buffalo12980
  • 625 Answers
SOURCE: installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Posted on Dec 07, 2007
  • 96 Answers
SOURCE: Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Posted on Nov 25, 2008
  • 27 Answers
SOURCE: Honeywell PRO TH4110d Prog Thermostat not responding
cfheck to make sur ethat the t-stat is set for your type of heat. if you do not go through the instructions sep by sep then you will have problems. if you have then call a professional.
Posted on Nov 26, 2008
SOURCE: SECO TA2000 to Honeywell RTH7000 wiring diagram
I found one answere where X goes to C.
Posted on Jan 04, 2009
  • 252 Answers
SOURCE: Honeywell thermostat reads ''-AC'' what does this mean?
-AC means no power to thermostat from furnace.
Posted on Apr 12, 2009
Electric furnace/air handler short cycles
check that the replaced thermostat is the same temp degree setting of the last one
Dec 16, 2013 | Goodman Heating & Cooling
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
Dual heat system, honeywell thermostat, auxiliary heat won't turn on
IT SOUNDS TO ME LIKE EITHER YOUR SYSTEMS LOW VOLTAGE WIRING IS INCORRECT, MOST LIKELY @ THE FURNACE. IT COULD ALSO SIMPLY BE THAT WHEN THE TECHNICIAN THAT INSTALLED THE T-STAT AT START-UP DID NOT GO THROUGH THE INSTALLER SET-UP & CHOOSE THE CORRECT SETTINGS FOR A DUEL FUEL SYSTEM. TRY THIS " SET THE THERMOSTAT TO EMERGENCY HEAT, WAIT A MINUTE OR TWO & SEE IF THAT TURNED GAS FURNACE ON. IF SO THEN IT'S A SIMPLE FIX IN THE WIRING OR PROGRAMMING & NOT SOMETHING MAJOR! GOOD LUCK!
Nov 25, 2012 | Honeywell VisionPRO Thermostat TH8110
Heating won't go off
Honeywell manuals are online for all its thermostats.
Google search your model number.
Model number is on back of thermostat.
Copy following link for Honeywell resources:
http://yourhome.honeywell.com/home/Applications/FindYourModelNumber.aspx
Honeywell manuals are detailed, but each pdf file can be word-searched.
More resources:
http://www.ehow.com/how_6596826_troubleshoot-honeywell-thermostats.html
Jun 25, 2012 | Hardware & Accessories
Honeywell RTH2310b thermostate - my thermostat worked just fine through the winter with the heat but now it won't kick on the central air. I have tried switching the yellow(cool) and the white(heat) to...
You can check your float switch, power to both the air handler and outside condensing unit and ensure power is present, also check control voltage from transformer ensure 24Volts on secondary side. If you are not comfortable around electricity though I recommend you call your A/C Contractor for safety reasons.
Further information would be needed to further diagnose your problem.
Jul 05, 2011 | Honeywell Heating & Cooling
What does the "auxillary heat"
Auxiliary Heat is used to turn the electric heat strips ON, If the heat pump is not working. Or if the heat pump can't bring the space temperature up to Set Temperature it will display Aux Heat ON....... Assuming you have a Heat Pump System with Auxiliary Electric Heat as Back up...... If the tech didn't install a jumper wire from AUX to W on the subase which is in back of the Display on the Thermostat.....you won't get Auxiliary Heat if the Thermostat is set for Auxiliary Heat. Other wise the thermostat will turn the heat pump on first and then the electric heat (Aux Heat) if it needs it to satisfy the set temperature....... Hope this helps
Apr 21, 2011 | Honeywell Electronic Programmable...
I am trying to install a Honeywell RTH2510 thermostat for my heat pump. The wires coming from the wall are red, white, green and blue. Where does the blue one go? My second question is what to do with the...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jan 08, 2010 | Heating & Cooling
I have a TH8000 Vision Pro. It is controling a
Whats' so hard is the Honeywell thermostat has a built in 1@ differential. It is not adjustable.
You might ask your installer about a time delay relay installed in the furnace to break the thermostat heat wire (usually white wire).
Most time delay relays are 90 seconds. But that might be enough to reduce the furnace cycling.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Honeywell rth7400 keeps turning furnace on
check your heat antisipator setting make sur eit matches your tpye of heat. also, do you have a 2 stage heating sys?
Nov 21, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
176 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
