Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Hdd bad sector problem
How can i repair bad sector in my hdd?
    President:
  • 1,901 Answers
When your computer starts booting, tap F8. At the option menu select Command Prompt.
You will get this:
C:\
Type in chkdsk c:\ /r
Press Enter
Alternate way:
Click Start>Run
Enter cmd in the box and press enter.
Type chkdsk c:\ /r
Press Enter
If you get a message that "the volume is in use" "would you like to check this volume the next time the system restarts", answer Y and press Enter.
Exit the command window by typing exit then press Enter.
Restart your computer.
Posted on Oct 22, 2008
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
How to repair samsung HD502HJ bad sector
No way. Try to make it shorter and cut off that area including bad sectors. Make a two partition around and enjoy!
Feb 11, 2014 | Samsung HD502HJ Hard Drives Sata-ii...
My 2gb sandisk micro SD card reduce the size after formatting
Possible micro SD bad sectors. To check your micro SD bad sector or not, you use the HD Tune software. To restore the capacity micro SD, which is done is Low Level Format. You can use the software HDD Low Level Format Tool.
How to use HD Tune and HDD Low Level Format, you can see here
Transcend Repair Bad sectors
How to repair micro SD, you can see in here
MMC Repair Without Losing Data Video 2
Oct 12, 2011 | SanDisk 2GB microSD Memory Card
1. read time of hard drive clusters is less than 500ms 2. 33% of hdd space is unreadable 3. bad sectors on hard drive or damaged file allocation table 4. boot sector of hard drive disk is damaged 5. hard...
You can run ChkDisk utility to fix Bad sectors on the hard drive(If its fixable).
This utility actually marks the bad sectors on the Hard drive and Isolate from the being accessed thats why 33% of HDD space is unreadable.(Which is very high)
There is no option to fix this HDD, so suggest you to replace it with a new one.
Hope this helps Let me know if you have any query on this.
Jun 23, 2011 | Computers & Internet
I've a Samsung G2 Portable HX-MU050DC/GW 500GB. - I was using it fine on PC1 when a Scan Disk Message Window (bad sector) popped out. I did a scan disk, nothing happened and continue copying and pasting...
when you see "bad sector" you need to not only run scandisk, you need to tell it to "automatically repair bad sectors" if you didn't do this, then you have written to the bad sectors and that data can not be retrieved. As for the MAC issue, you didin't say what format your HDD was, if it was FAT32 it should mount on MAC, but not if it is NTSC as MAC can't read it. If I were you I would copy all the files from your HDD to a wiindows machine and then run scandisk again, only this time make sure to auto repair, these sectors will now be gone, and its not a great loss and does happen quite ofter unfortunately. The data you have written to the bad sectors "CAN NOT" be recovered, you might get part of it, but most likely not. Good Luck
Mar 24, 2011 | Samsung G2 Portable External HX-MU050DC/...
Bad sector problem, and hdd is not working proparly, hdd ditecting problem
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which willscan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
Nov 17, 2010 | Fujitsu 160GB 2.5" 7200rpm Internal Hard...
I need to do a low level format for my hard disk. Bad sector problem. Do you guys have any application for that particular kind of formatting?
Bad sector on hardisk there two kinds of that is software and physical. physical badsector caused from plate of hardisk damage is caused by dirt, fallen down, collided, to be incised, etc. While software badsector can be caused when hardisk busy sudden die, cause of usually broken electrics current.
For the bad sector damage of physical of hardisk, we require a really of expert to repair the hardisk. While damage of software we can repair xself use software or tool. One of the software which can be used to repair bad sector on hardisk that is HDD Low Level Format Tool.
Using this software hardisk can be low level format. Require to be paid attention that using low level format on a hardisk, causing all data in hardisk will lose and cannot be recovery again. But this way will be more effective eliminate sector bad.
HDD Low Level Format Tool Support Hardisk SATA, ATA or SCSI, can is also used on removable media like flashcard, flasdisk and etc. To run this software is very easy, that is :
  • Download HDD Low Level Format Tool from the link above and install it till finish.
  • Run HDD Low Level Format tools
  • Select a hardisk which will repair then click continue.
Select LOW-LEVEL-FORMAT tab", if you sure To format the hardisk click "format this device" button and await till finish. ad for hardisk repaired hence required time will longer.
HDD LOW format level can be download from following link,
http://hddguru.com
note : If on hardisk have detected badsector, before doing above steps, first step to backup all existing important datases
Premium experts are not paid for free questions so require your appreciation in form of a 4 thumbs rating
THANKS
Oct 03, 2010 | Computers & Internet
How to remove bad sectors laptop hdd
Sir,
Bad sector removing is difficult task to remove /find. u can't solve bad sector harddisk. first go to run and type CHKDSK and check how the disk was or % of bad sector. the chkdsk command will solve badsector automatically. if not solves better to buy a new one or using the hdd with bad sector it not a problem
Jul 11, 2009 | Computers & Internet
Bad sectors removal and formating Seagate 80 GB
I suggest puting your hdd on another computer, full format it again, and scan it for bad sectors.Also, searching for a program that repairs bad HDD sectors, the windows default erros scan could not be very helpful if there are many bad sectors.
Sep 02, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
