Question about Gigabyte Intel G31 775 DDR2 )
How do i unlock my system
I cant open the dvd drawer
  • 31 Answers
Under the Dvd drawer tray towards the right hand side where you have the open close button just next to it you will see a small pin hole. you can insert a safety pin in the pin hole and push it so that you can open the DVD drawer. Good Luck
Posted on Feb 07, 2012
Panasonic dvd home theatre system SA-HT520. My 2 year old was playing with buttons on dvd player and now when i press open/close button it is saying locked and won't open, is there anything i can try...
The system has a locked / unlocked toggle sequence on the main unit by holding down stop (or Play) and then tapping the power button. Use this sequence lock or unlock the DVD / CD drawer.
Sep 29, 2011 | Panasonic Home Theater System System
DVD drawer will not open - stuck dvd inside
My only suggestion is to press and hold the eject button for a period of time (15 - 30 seconds). This might unlock the drawer. If not, I would contact Bose Customer Service directly.
May 15, 2010 | Bose Lifestyle 28 System
The dvd drawer will not open on Bose 3-2-1 system. When you push the button to open the dvd, the display say ''opening'' but it does not open. There currently is a dvd inside.
That happens when you close the drawer instead of pressing the close button  you can skip gears and it would have to be taken apart and re-calibrated.   Sometimes it is just a glitch that you can over-ride using a straight pin into a small hole on the front  (assuming this uses a drawer).
Nov 09, 2009 | Audio Players & Recorders
Can't get dvd drawer to open - has a lock symbol
On your remote there should be a unlock or seomthing that looks like a key if not in the menu system there should be. Please refer to your user manual if you do not knowhow to navigate the setup screens Thanks
Sep 23, 2009 | Televison & Video
DVD drawer will not open on Zenith ZHX-313....help???
hi friend,
Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire—such as a paperclip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs. If this is the case you should have it serviced or perhaps it is time for a new one.
I hope this helps.
thank u for using fixya
regards,
sivaranjini
Aug 05, 2009 | Zenith ZHX-313 System
Dvd drawer will not open
Manually open the tray. It's possible that you have a dvd stuck in the drawer because it wasn't fully seated. Look at at the front of the drive and you will see a tiny hole. Take a paper clip or safety pin, stick it in the hole and push. You will see that the drawer will pop out and you can retrieve your stuck dvd. Thanks for using fixya.com
Jan 27, 2009 | Progressive Computer JSI 6 spkr. Home...
Unlock Sharp DVD region code
open drawer on dvd
then press volume + key
while holding it down press the language key
and release volume+ still holding language
then look then use up and down arrow keys to change region code
Dec 14, 2008 | Sharp 21" Multi System Stereo TV
Dvd problem
try to reset the system disconnect the system from power and re connect it again.
Jun 06, 2008 | Panasonic SC-HT75 System
I want to unlock my dvd player a120
Try this open cd drawer, Press 9, 8, 1, 7 on the remote control, Press ENTER till it shows region 9 and Press RETURN.
Apr 21, 2008 | Panasonic DVD-A120 DVD Player
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Gigabyte Intel G31 775 DDR2 ) Logo
41 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
