Question about Samsung LN-T2332H 23 in. LCD Television
How do I do a factory reset on my Samsung LN-T2332H
We can't get the signal from the cable to pick up new channels so we want to start fresh by doing a factory re-set of the set, how do I do that
  • 280 Answers
SOURCE: Best Picture Quality
The set may not be at fault. If you are on cable some channels are still in anolog and some are digital. if you are on a nolog channel the picture will look preaty bad compared to the digital ones.
Posted on Jul 03, 2008
  • 1779 Answers
SOURCE: limited channels
If you have two inputs- Cable and Digital, make sure it is in cable then proceed to AUTO PROGRAM.
Posted on Feb 04, 2009
  • 12 Answers
SOURCE: samsung plasma cable problem
your digital or anolog board is bad needs replaced can find on ebay if you can get part #
Posted on Feb 07, 2009
  • 304 Answers
SOURCE: samsung ln t3253h 32_in_lcd_
Call 1-800-Samsung and ask them if there is a Firm Ware Upgrade for your model.. If there is none then you have a bad Main bd and need to be replaced.
Posted on Jul 17, 2009
techman007
  • 1112 Answers
SOURCE: Thmy samsung LN-T3242H - 2 years old - the picture
Hi:
Make sure under your audio options you are in stereo mode and not it SAP, (Special Aided Programing).
Posted on Dec 24, 2009
Samsung LN-S4095D HDTV Screen Glitching
look to see if same issue with a DVD etc connected to a rear input.
Jun 07, 2012 | Samsung LN-S4095D 40 in. LCD HDTV
Hello, My samsung ln82341w has sound problems. Two cable channels have no sound; 1 channel has crackling/static sound; and most of the other channels the sound will go out when the first one or two...
The problem isn't with your TV, its with the cable company.
Call the cable company, problem is most likely with your digital box or a signal problem.
Aug 22, 2011 | Televison & Video
Hi, My Samsung UE46C8000 is suddenly showing left half of the screen fine, right half is simply colourful blurry vertical lines. After about 3 seconds the TV then restarts itself, but the problem...
if you have this tv connected to the internet try and see if it needs updating. it also could be the pip settinmg picking up an air signal instead of a cable channel.
Jun 25, 2011 | Televison & Video
My samsung ps42c91hdx/xsa tv wont tune in the high def channel 10. the tv can't find it. My sons tvs are picking it up so it cant be the signal.
go to MENU, SETUP,
There you can reset to factory settings. After you set the clock and date, it will ask to scan for all active channels and it will block out the channels it does not find a signal for. Let it complete this task (20 minutes). It asks you for the type of signal but just leave the STD setting for both options before starting the channel finding routine.
When complete, go to channel 10 to see what show is on (low def version). then click down to channel 2 and then push the channel down button several times again to try and find the HD version of that show. (HD channels are high-number channels that are easiest to get to by scrolling below channel 2. Most will have a hyphan in the channel name (e.g. 93-2; 94-1, 94-2, ...).
If your TV goes directly to a 2-digit channel, they you do not have an HD tuner in your set. I doubt that is true so I think you will find what you need.
Let me know if it doesn't work.
May 06, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
Picked up used LN-T4053H, hooked it up to cable and I get no signal.
Did you set the ON SCREEN TUNER setup tuner to pick up from the signal from cable?
Did you download the user manul from SAMSUNG web site?
Mar 01, 2011 | Samsung LN-T4053H 40 in. LCD Television
Samsung LN-T4053H---No signal
Here is the check list;
Go into the menu to verify the signal source is correct.
Try it on other channels.
Check the connections.
Check the source.
If cable, is it working, bill paid etc.
If antenna and it is amplified, has it failed.
Feb 08, 2011 | Samsung LN-T4053H 40 in. LCD Television
The channels won't work.
you can use another TV to test the cable.
Apr 30, 2010 | Samsung LN-R409D 40 in. LCD Television
How do I turn on the digital tuner? Samsung
Hi my name is Roety,
I can help you with your issue ,
The digital tuner is always on, you just need to run the autoprogram in the setup menu with a digital signal connected.
An antenna is ant or air signal
using Cable click cable when scanning in channels.
If using a cable box there is no need to scan channels.
if using an indoor antenna it may not pickup any (roof antenna is better)
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 01, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
No digital channels
Hi quinny 1982,
The first thing to check do is look in the manual on how to do a factory reset.
Once you've done that look at this page on how to check the signal strength the TV is receiving. Anything less than 50% and most tuners will not display a picture.
If the signal strength is okay then try another auto tune.
If your still having a problem then I'd suggest you you might have a faulty unit. However, a lot the time companies like to blame your reception area, TV Antenna (Ariel) or cable length or quality. Yes, old coaxial cable used for analogue TV is not very good when used with digital equipment (not a surprise)!
From what you've described, if you can only get a mono signal I'd be surprised it that's actually a digital channel.
Don't forget to check your Antenna connectors.
Hope this is helpful.
Best of luck.
Spare head 2.
Jan 04, 2008 | Samsung LN-R409D 40 in. LCD Television
Samsung LN-T2332H 23 in. LCD Television Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
