I need the wireless adapter for my motherboard
Wireless network adapter
  • 807 Answers
What motherboard? Is it a laptop? Make and model number. If you want an internal one have a look on Ebay, or you can use a USB wi-fi adapter.
Posted on Feb 07, 2012
TP-LINK TL-WN321G USB Wireless Adapter OSX Driver
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
http://download.cnet.com/realtek-rtl8187b-wireless-802/3000-2112_4-206215.html
hope it helps
May 22, 2012 | AGPtek TPLink TLWN321G USB 20 Wireless Lan...
I am currently using a wireless 'dongle' to connect to the internet but I feel that it would probably give me a more stable connection if I had a wireless card. Can anyone give me details of
Hi Lynda,
The best option for you would be to purchase a wireless PCI network card.
They are relatively inexpensive and should have a stronger signal over a longer distance than a wireless USB dongle.
Below is a typical wireless network card and it should be freely available from your local PC store
I have included a brief explanation for your convenience:
A PCI wireless adapter card connects to a desktop computer's PCI bus. Because the PCI bus is contained inside the computer, the unit must be opened and the wireless network adapter installed inside.
An example of a PCI wireless adapter card, the Linksys WMP54G is shown above. This unit is more than 8 inches (200 mm) long in order to accommodate the standard connection strip required to electrically join to the bus. The unit attaches and fits snugly inside the PCI, although the wireless adapter card antenna protrudes out the back of the computer
Best wishes,
Graemevm
Jan 24, 2012 | QDI Group QDI KuDoz 7 Motherboard
I need a manual so I can set-up board HD LED, PWR LED PWR BTN, RST BTN SLP LED/BTN, etc.
Here you go! :)
http://download.intel.com/support/motherboards/server/s5000pal/sb/d31968004_s5000pal_userguide.pdf
Cheers!
Oct 28, 2010 | Intel S5000PALR Motherboard (891957) USB...
Can the HP Pavilion 763n PC Desktop use a wireless router?
Your computer has a "built-in" 10/100BT network connection integrated on the motherboard but to go wireless you'll have to add either a PCI (internal) or USB (external) wireless network adapter to transmit/receive the signal from your wireless router. Think "walkie-talkie" here with the wireless router installed AFTER the modem (phone line outlet needed) located in a central area of your home and transmitting/receiving to the individual wireless network adapters that must be separately installed in each computer.
Oct 19, 2010 | HP Pavilion 763n PC Desktop
I Formated my pc windows XP and I can t connect to the internet ASUS p5ld2 vm motherboard help me
Make sure your network adapters are working (wireless or wired). Go to Start -> Settings -> Control Panel -> Network Connections.
If you are using wireless, right click on your wireless adapter and chose Properties. If your network SSID is not there, click on Add and make sure you enter your authentication type (WEP/WAP/WAP2) and passcode that is the same as your network.
NOTE: Please rate our help to keep this free service online.
Jan 09, 2010 | ASUS P5LD2-VM Motherboard
Intel set pro is showing wireless physical adapter not installed
since i got the motherboard changed, the wireless adapter had changed and i didn't realise, i was trying to download the wrong drivers, i finally got the right driver for the dell wireless wlan mini card and now everythings working fine.
Aug 27, 2009 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
My HP wireless doesn't work? I don't have wireless connection on my compaq laptop anymore.
check your wireless adapter is on... the switch is on the front of your laptop and you should show a blue light when it's on, also go into device manager and see network adapters.. you should have 2 (the wire one built-in and your wireless network adapter.. if you only have one network adapter, check the front and see if the light indicating the status of your wireless network adapter is amber.. (if it's showing amber and you're sure it's in the on position you may have a motherboard problem and you may need to send the system back (I just had one of those with a compaq computer and since the item was within warranty the fixed in a week)
if your wireless adapter light is blue and you see your wireless adapter in device manager follow this instructions and you should be ok,
vista
http://www.home-network-help.com/vista-to-connect-wireless-network.html
xp
http://www.home-network-help.com/wireless-adapter.html
Oct 03, 2008 | Computers & Internet
Internet conections
you will need either a usb 54MBPS or 108MBPS wireless adapter of any make that will connect to a usb port or a pci wireless card to fit in the pc tower on the motherboard.
Oct 06, 2007 | Linksys (WUSB54GCU) 802.11g/b Wireless...
Wireless USB adaptor not found
Hi zlyman, The Belkin N1 Wireless USB 2.0 Network Adapter might be choosy with what motherboard it is attached to. Pls refer to this similar problem > http://www.fixya.com/support/t201253-not_identify_belkin_n1_wireless_usb Hope this be of some help/idea. Post back how things stand or should you need further information. Good luck and kind regards.
Oct 02, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Computers & Internet Logo
David Payne
David Payne
