Question about Electrical Supplies
Gwb67v motorguide only runs on high speed - Electrical Supplies
4 Suggested Answers
SOURCE: 46 lb motorguide stays on high speed. Motor is 2
It was just user error. It works now. Thank you.
Posted on Jun 22, 2009
SOURCE: My variable speed motorguide only
Would you mind letting me know how you made out? I have the same problem.
Thanks, Mike
carmic@wightman.ca
Posted on Aug 18, 2010
SOURCE: Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Posted on Sep 16, 2011
Motorguide Pro 70 only 2 speeds out of 5
CHECK ROTARY SPEED SELECTOR SWITCH. $20 PART IF BAD.
Mar 29, 2012 | MotorGuide STANDARD MOTOR REPLACEMENT...
My trolling motor stays on high speed all the time
Is the toggle switch on rabbit speed? If so it will go on fast as soon as u step on the pedal switch
Sep 26, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Lost #1 and #2 speeds
Contacts inside switch may have become corroded.
May 12, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
May 22, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Electrical Supplies Logo
43 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
