Question about MT&V (MTV-5965) 10.4" 10.4" TFT Ceiling Mount Monitor, Remote, Built In Room lights, AV Input/Outpu...
Need new wiring kit
My dog chewed up the wires for my tv while i had it in my house
I need a wiring diagram for my powermate 5700? Do to my dog chewing off the wires
you need 2 replace the dog...! (BEFORE THE WIRING job) ...that's a really tight spot they're in....
HE'LL SEE NEW WIRES AND SAY....
OH GOODY....I bet he'll like this ! that's what he gets for leaving me home alone ....i'll show HIM !
Mar 08, 2014 | Coleman Powermate Powermate 5000W...
Which wire on the charger is the power wire, solid black or the on with the white dashes
The one with white dashes is positive, the solid black is ground. Why don't you use a DC voltmeter?
Apr 26, 2012 | Stealth Cam 12v Battery Kit Stc12vbb
Dog chewed power cord. how do I repair
assuming this is a window air cond? It is not safe to use electrical tape, duct tape or any other kind of tape on a power cord to cover bare wiring. Many times I have cut the cord short enough to cut out the place where chewed and gone to a hardware store where I can get a new cord end that matches the wall plug and wire it in to the shorter cord. If this is not possible, you will need to either make a new cord or try to find a cord at an appliance supply house.
Apr 09, 2011 | Haier Heating & Cooling
My dog chewed up the t-stat wiring on my outside a/c unit (compressor?). I purchased some t-stat wire at Home Depot and replaced the wiring. At the outside unit, I connected the new white wire with the...
Hello,Yes there is a 3 amp blade fuse(same as in a car) in the blower unit,take off the door and it is plugged in to the(curcuit) board.Pull it out and slip a new one in.That will restore the control voltage.Your repair sounds correct.Some times there is a tiny button on the transformer itself (square box) that pops up instead of a fuse just push that in to reset it(if applys).
Oct 19, 2010 | Heating & Cooling
My dog chewed through a group of multi-colored wires on my AC outside. Is there any way that i can fix this?
HI there well i think what you dog chewed on was the thermostat wires. if you tell me the colors maybe i can help you out.
ordonez305@aol.com
This is my e-mail
Jun 03, 2010 | Ruud UBHC Air Conditioner
DOG CHEWED THE THERMOSTAT WIRE RUNNING FROM THE HOUSE TO THE AIR CONDITIONER UNIT
Sometimes you can just turn off the power and cut out the bad spot and strip back the outer casing, match the colors and wire nut it back together. You need to be careful so that the new connection is not accessable to the bad weather. If you cannot protect the wire from the wet weather you should just replace the wire by running new.
Apr 23, 2009 | Heating & Cooling
No spark
If the dog chewed up the coil wire you will need a new coil. How did the dog GET to the wiring? Did you let the dog live? The wires are color coded. Splice the wires color to color. Depending on how badly the dog tore up the wires, you may want to get a new, (or used) wiring harness and re-wire the bike following the pattern of the existing wiring.
Please rate this solution as "FixYa" if it has answered your question.
Mar 25, 2009 | 2004 Kanuni Tigrina 100
Dog chewed sensor wire so garage door won't, i
Basically any bell wire will work, available at any home centers everywhere. if the existing wire is long enough, just wire nut it together (white to white, color to color)
Feb 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
My dog chewed up wiring on outside unit and i dont know where they hook up it is a 4 wire set up with red white blue and green large ac unit dog chewed thru little brown wire leading to house and now ac...
That wire is to your thermostat which of course turns the A/C on/off. One thing you can do is to splice the wire back together w/ small wire nuts (available at hardware store or wal-mart, and just hook it up color to color and then tape w/ electrical tape. Make sure you turn your breaker off and turn off the thermostat control.
Feb 11, 2009 | Heating & Cooling
MT&V (MTV-5965) 10.4" 10.4" TFT Ceiling Mount Monitor, Remote, Built In Room lights, AV Input/Outpu... Logo
27 people viewed this question
Top MT&V Car Audio & Video Experts
xxxxxx xxx
Are you a MT&V Car Audio and Video Expert? Answer questions, earn points and help others
