Question about Samsung SCX-6345N Printer
Can't delete an email job
I have a Samsung SCX-6345n printer, scanner, fax, etc. machine and there is 1 job in the job queue that won't go away. It keeps saying the email is transferring. It can't be deleted. This prevents any other job from processing without shutting the printer off and restarting. Then it will process 1 job and then quit working again. "Expert" says I need to replace the main board because the firmware can't be updated for some reason. Please help.
2 Suggested Answers
  • 19 Answers
SOURCE: On a Samsung SCX-6345N, how
bend over stick your head between you legs and kiss your a** goodbye...
Posted on Sep 02, 2010
How to delete or clear out print jobs for scx-6x55series printer
To clear stuck print jobs from the queue, I use and recommend Stalled Printer Repair. You can get it here...
http://www.fantasticfreeware.com/?page_id=2451
May 08, 2014 | Samsung SCX-6x55 Series PCL 6
MFC465CN-PAPER JAM- NONE IN MACH.CANT USE
Sir/Madam
MAKE SURE YOUR BROTHER MACHINE IS THE DEFAULT PRINTER
If the printer driver is not set as "default printer", you can not print. Make sure your Brother machine is set as default printer. If your brother machine is not set as default printer, set it as default printer.
  1. Click Apple Menu and choose System preferences..., click Print & Fax, Print & Scan or Printers & Scanners.
  2. Choose from pull down menu of "default printer".
DELETE ALL PRINTER JOBS
  1. Click Apple Menu and choose System preferences....
2 Click Print & Fax, Print & Scan or Printers & Scanners.
For Mac OS X 10.5 - 10.7 users
Choose the print job (1) and click Delete (2).
CHECK THE PRINTER STATUS
Choose brother machine's icon and click "Open Print Queue..." then check the printer status.
The Resume or Resume printer icon which is surrounded by red lines is displayed in printing when the printer is out of paper or the printer is turned off and on. Click Resume or Resume printer.
For Mac OS X 10.8 or later users
If you connect the brother printer via USB cable, the error message The printer is not connected or Offline is displayed on Print Queue when the USB cable is disconnected or the brother printer is turned off. Connect the USB cable and turn the brother machine on.
If the other error message is displayed on Print Queue, check if the LCD display or LED indication of your Brother machine is not showing some error. If an error is displayed, go to the Troubleshooting section and find a solution.
REGISTER THE PRINTER ICON AGAIN
  1. Choose your printer icon.
  2. Click [-] button to delete the printer icon.
  1. Click [+] button to register the printer icon again.
In spite of if you click [+] button, the brother machine is not displayed, then the brother machine is not recognized.
If you use the printer via USB connection, reconnect the USB cable or restart the Macintosh or your brother machine.
For Mac OS X 10.4 users
I Suggest You Go To Official Brother Printer Website For Brother Printer Troubleshoot:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000046/faq002646_001.html?reg=us&c=us&lang=en&prod=mfc5860cn_all
Or
If You still having Problem Then Follow Us For Brother Printer Support
Jan 23, 2014 | Brother MFC 420CN All-In-One InkJet...
Scx-6345n toner supply error
DID YOU RESET THE PRINTER TONER ERROR? CHECK YOUR USER GUIDE.
Feb 15, 2012 | Samsung SCX-6345N Printer
My Lexmark s605's print queue won't clear, and so the printer has stopped working altogether
Please follow the steps below to clear the print queue and restart the print spooler of your computer.
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Jan 07, 2012 | Lexmark Interact S605 All-in-One Color...
Have a Samsung SCX 4521F printer scanner machine. Toner is full but won't print when trying to photocopy....will print if something is faxed. The bulb doesn't seem to come on when it starts to...
push menu and # 1943
the fax will go in service mode
push menu again and scrolle until you get new cartrige
push ok
then swich the machine of and on
and it will work
Jul 13, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-6345 machine is blocked by a fax arrived that captured both the printing and copying. how to reset the machine?
  • Turn on the printer.
  • 2 Press the "Machine Setup" button in the upper left corner of the control panel.
  • 3 Press the "Admin Setting" button on the touchscreen. Touch the password input area if the administrator set a password for the printer. Press the number keypad buttons to enter the password. Press the "OK" button on the touchscreen.
  • 4 Press the "General" tab shown on the screen.
  • 5 Press the "Default Settings" option. Press "Yes" to reset all at once the user settings configured on the printer, such as copy and scan options, fax settings and network and system options
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    May 19, 2011 | Samsung SCX-6345N Printer
    My problem is lack of any kind of support from Samsung tech support. At first they tried to be helpful, but got to the point of telling me that I was a unauthorized dealer. Now they won't supply any...
    Authorized dealers have the same problem. I suggest contacting an authorized dealer. Most techs will try to help over the phone.
    BTW, the SCX-6345N is a mono machine. With Samsung, and SCX prefix always denotes a mono copier. The color ones are denoted with a CLX prefix.
    May 10, 2011 | Samsung SCX6345N Color Copier
    Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
    Follow the steps below to resolve the issue
    The print queue and Dock printer icon
    When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
    You can alternatively open the print queue from the Print & Fax pane of System Preferences.
    printer%20queue.png In the Print Queue toolbar you have these buttons:
    1. Delete - Deletes the selected print job.
    2. Hold / Resume - Will hold / resume the selected print job.
    3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
    4. Pause / Resume Printer - To Pause / Resume the Print Queue.
    5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
    6. Printer Setup - Lets you configure the printer's name and location details.
    7. Printer - Sets the Print Queue window into Printer mode.
    8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
    You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
    From the Print Queue menu bar, the "Printer" menu has these additional options:
    1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
    2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
    3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
    4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
    5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
    6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
    From the Print Queue menu bar, the "Jobs" menu has these additional options:
    1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
    2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
    You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
    printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
    Feb 08, 2011 | HP DeskJet 6988 Printer
    The OEMCFG.dll on Samsung needed
    GO TO SAMSUNG/SUPPORT.COM
    TYPE IN YOUR MODEL# AND DOWNLOAD THE DRIVERS YOU NEED.
    Jul 15, 2009 | Samsung SCX 4521F All-In-One Laser Printer
    Samsung SCX-6345N Printer Logo
    318 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    Victorman
    Victorman
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
