Question about LG DLEX2501 Dryer
Won't power on
Could it be a fuse? Where is the fuse box
    Top Expert:
  • LG Master
  • 78,267 Answers
There is no fuse box, all there is for fuse protection is the electric drive motor "thermal fuse" and it is located inside the dryer cabinet near the drive motor. If the fuse blew then you have a problem, find out what that is before putting another fuse in it, you can create a fire hazard.
Posted on Feb 07, 2012
All 4 windows won't work and rear door latch won't open! So, I have two problems: Firstly my rear hatch won't open as of yesterday (Keyless entry pushed & it doesn't even make a noise...
Look at your maintenance manual. To find where your fuse box is located(may be under the hood or under the steering wheel). When you find the fuse box look on the back of the panel flap and you'll find a fuse map. Locate the fuse that corresponds with your problem. It could be the same fuse but not likely. If fuse is blown then replace it with a spare. Most manufacturers will put spare fuses in the box or you could pull a fuse from some where else just to try and see if the problem is still there( make sure it's the same size and understand that it could blow this fuse as well then you will need 2 fuses). Most of the time fuses don't just blow. For some reason it pulled to much load. Probably a dead short in the wiring. I hope this helps.
Jan 22, 2013 | 2005 Toyota 4Runner SR5 V8
What's your problem?The horn won't work, the light that is supposed to go on when you open the doors won't work, the cigarette lighter won't work, and the head unit won't work
on 1987 all you mentioned are on same fuse #11 located in fuse box below steering wheel 3rd row 3rd fuse from left next to either a blank space if you do not have power windows,or next to silver circuit breaker if you do have power windows.
May 23, 2012 | 1987 Chevrolet Camaro
Windows won't roll down, and it won't auto lock,
There are fuses for both windows and door locks, If fuses are good may be electrical problems
Sep 23, 2011 | 2001 Mercury Sable
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Starter shorts when turning key from "on" to
Check all ground wires and make sure they are tight. Start at the battery, starter, solenoid switch.
Dec 15, 2017 | 2005 Scion xA
I have no power to several fuses on 01 ford expedition
Check in the high amp fuse box under the hood as one of those fuses may be blown causing no power to several accessories.
Mar 23, 2011 | 2001 Ford Expedition
LG DLEX2501 Dryer Logo
276 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
