Question about Dryers
Where is the circuit board on an LG dryer - Dryers
    Top Expert:
  • Dryers Master
  • 76,846 Answers
It is behind the top control panel on almost all models.
Posted on Feb 07, 2012
Change board LG washer
Screws for the lid are at the back, normally only two. Then push lid towards the front to release lid from the two clips. assess...ame
Jul 21, 2014 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
My lg dryer model dle2140w will start but not stay on.
sounds like you should check your element could be wet or damaged
Jan 28, 2014 | LG DLE2140W Dryer
I have and lg gas dryer modeldlg7188rm cooling light is on constant wouldnt heat atall. replaced gas valve now it will fire up but after a few seconds shuts down. Cooling light still on on any cycle is it...
Most dryers if and when they have issues can be traced to the circuit board main IC software or IC flaws. Replacing the board with a new or rebuild board usually fixes all
Oct 31, 2013 | LG Dryers
LG washer WM2455H The start button does not work,
Unplug the washer for 5 minutes to see if the commands for the cycle will reset. Also try pressing the stop button for ten seconds.
Dec 04, 2010 | LG WM2455 Front Load Washer
LG DLE7177 Thermal fuse
Thermo Fuse is normally followed by the power source or on
the circuit board, Follow power source and you will find fuse.
Oct 21, 2008 | LG DLE7177 Dryer
MY LG DLE5977 Electric Dryer will not power on
Check the junction connection behind the dryer where the power cord and terminal block to make sure that the screws are tight.  Then use a volt meter to check for voltage.  The 2 outside wires should be hot leads and the center is neutral.  Check hot to hot and you should get 240 volts.  Check hot to neutral and you should get 120 volts.  If you get those voltage readings, then you have a control board malfunction and needs to be replaced.  There is no reset switch within the dryer for the control board.
Jun 09, 2008 | LG DLE5977 Electric Dryer
No heat
Check the high limit switch located on the combustion chamber tube.  There is a button that you can reset and that should take care of the problem.
Dec 04, 2007 | LG DLG2532 Gas Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
