Question about GE GSL25JFPBS Side by Side Refrigerator
Ge side freezer makeing excessive frost - GE GSL25JFPBS Side by Side Refrigerator
  • 54 Answers
SOURCE: My GE Profile PSS26MSTSS is not keeping food cold.
You need a new defrost heater
Posted on Jan 04, 2009
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
  • 172 Answers
SOURCE: freezer has developed some frost in the back
This is a fairly easy problem to solve. First thing you will need to do is defrost the ice on the inside back panel of the freezer. Then remove the back inside freezer panel. You will need to remove your freezer shelves to do this. Once the panel is removed you will need to defrost the coils and surrounding area. Once defrosted you will see your defrost heather on the bottom of the coil and a defrost thermostat on the top of the coil. The defrost thermostat is about the size of a quarter and about 3/4 inch thick. It will be mounted on the coil line. If you have a multi tester you will be able to check continuity through the heater by unpluging it. The defrost thermostat is a bit more tricky to check. It will not read continuity once it is warmer than 50 degrees. The defrost thermostat is a fairly inexpensive part so if your heater is good you may want to just replace the defrost thermostat and see if the problem goes away. The other possibility would be your control board. It is located on the back of the refrigerator and has a metal plate covering it, with sever 1/4 inch screws. This board causes most failures on your model refrigerator. Also a point to remember. This board has had several new upgrades from the one originally installed on your refrigerator. So make sure if you get a new one that you get the listed number I have given you. The older ones are cheaper but they are also not updated and will not function properly on your refrigerator. The following parts listed are the possible parts you will need. Please let me know if you need one and I can ship it to you in about 1-2 days. I do not charge shipping and I give free advise. Thanks and good luck with your frost problem. you can reach us at.
Michael Anderson
Anderson Appliance
(865)945-3808
mca0824@aol.com
defrost thermostat. #WR50X10068 $21.57
defrost heater #WR51X10042 $56.50
control board #WR55X10656 $185.50
Posted on Feb 17, 2009
SOURCE: Where is the defrost timer located on GE
This model does not have a defrost timer. It has a motherboard. You must jump out the plug to the main board to test the defrost circuit. In order to do this take the cover off of the main board, find the three wire connector on the base of the main board, connecter is normally blue in color. On the board itself it will identify termials as line, defrost, and compressor. To test you must create a jumper wire.Install the jumper in the plug terminals identified as line and defrost.This will turn the defrost heater on. If the heater does not come on, look for a defective heater or a defrost thermostat(mounted on the top of the evaporator). If the heater does come on replace the thermister(located on top of evap, white in color and has two white wires part#WR55x10025)
Posted on Jun 05, 2009
  • 145 Answers
SOURCE: frost build up in freezer (ice maker section)
Your ice maker is overflowing and asking for to mush water to make the ice, you may have a real hi water pressure on your water supply
the is a easy way to adjust that but you are going to have to take
your ice maker out
then using a flat head screw driver remove the white square cover
you will see a gear and a adjustment screw and a lever like this
( - I + )
turn the screw to the minus sing a quarter way and install the ice maker back up.
Or a easier way is just closing the water valve before your fridge a little so it wont have so mush pressure and will not fill your ice maker so fast.
the ice maker feel up buy time not buy water level.
Posted on Jun 28, 2009
I have a GE refrigerator model # GSH25KGMB WW. It is a side by side with an ice maker and water dispenser. We have had it for about 9 years now. The ice maker hasn't been working right for about 6 or 7...
you could have several problems.
Since you mentioned your ice maker not working right - first check to see if your ice maker is hot (be carefull it can burn you if it is hot) - it is possible for an ice maker to hang in the heat cycle of the cycle producing excessive heat in the freezer. If this is the case unplug the ice maker and/ or just replace it.
The refrigerator gets it cold from the freezer so if the freezer is not working right, you'll soon notice it in the refrigerator side.
You can also check to make sure the evaporator fan motor is running(in the freezer) and the condenser motor(at the compressor) as well.
Also check the back panel of the freezer for excessive frost build up.
Jun 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer frost
Make sure that the evaporator fanmotor is working.
Nov 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Humming and frosting in freezer
Your defrost has stopped. Either the defrost heater, bi-metal or the control board has failed.
Sep 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
ICE MAKER FROST UP AT CHUTE
is this a u-line? Or a GE? If its a U-line make sure the freezer door is closing and sealing. If its a GE then check the gasket and make sure that is sealing.
Jul 29, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Freezer side not cold enough
Usually a thermostat is to blame when cold control suffers. However, check for excessive frost buildup first, this could point to other problems with either the fan or auto-defrost mechanism.
That is when I would call a technician.
Good luck
Jun 25, 2009 | GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB...
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Excessive frost build up inside the freezer
Your problem is not a recall it is the fan and how many items you have in your freezer. Is it stuffed pretty full?
Jun 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
Layer of frost on the bottom surface of ice maker
during periods of high humidity and or high use, it is not unusual to notice frost on surfaces in the freezer. the ICM is susceptible due to it being metal and having warm(compared to freezer temp) water in it. make sure the doors ar closed tight and nothing is stuck in the gasket area.
J
Jun 13, 2008 | GE Profile PSI23NCR Side by Side...
GE GSL25JFPBS Side by Side Refrigerator Logo
29 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
