Using windows dvd maker vista with sp1 starts to burn then at about 98% get error message and stops the burn. also when i try to format a dvd disc ready to burn that wont work and the dvd drive d is removed from my computer.have to restart to get it to show in my computer
  • Edfix Jan 08, 2009
    windows dvd maker stops working
  • gronbotmom Jan 27, 2009
    When using windows dvd maker with vista, the project starts to burn then at 98.9% I get an error message that says "The DVD could not be burned because an orror occurred. Try using another blank disc and make sure that your DVD burner is connected and working properly Learn move about this problem." I have tried using blank DVD+R and DVD-R to no avail.
  • 903 Answers
Two things. Firsly make sure that you are using the correct disks i.e if your drive is dvd-r then only use dvd-r disks, if its dvd+r then only use dvd+r disks if it is a multi drive then it won't matter what disks you use. Secondly don't format the disk first. If it asks you to format the disk click on the X to shut the pop up box. Only put the disk in when dvd maker asks for you to insert a disk.
Posted on Oct 23, 2008
I am trying to copy Windows 7 SP1 either as the simple service pack or Windows 7 Ultimate with SP1 but for both files I receive the same Toshiba Disc Creator error message 310981-34-00000000. I have...
That will only work with the Toshiba Disk Creator software and if anyone has made those already it won't work at all. Those are both copy protested files that use a special format to keep people from making copies of them. The back up files stored on the hard drive for restore purposes only work with the disk creator software that comes with Toshiba computers and that software has a hard coded counter that won't let you make more than 1 copy. If your using the correct software and still have the problem it maybe the DVD's your using. Make sure you have DVD's that are a compatible format with your DVD writer function. You may need the DVD -R instead of the +R dvd's you indicated you are using.
Feb 18, 2011 | Computers & Internet
Is there a way I can finalize a DVD-RW so I can show films burned onto the DVD-RW?
You have not pointed out what type of program are you using for DVD authoring. The option to finalize the disc is usually provided when you start burning.
I have an alternate solution for you which is easier. You can use the Windows DVD maker available in Vista Home Premium. This way you will not have to manually finalize the disc; it will take care of it itself.
Remember to install codecs such as k-lite basic coded pack for trouble free work with different formats. Then run DVD maker from the start menu. A tutorial can be accessed here.
Note that DVDs created by DVD maker can be played on most DVD players and on computer as well.
Oct 12, 2010 | Microsoft Windows Vista Home Premium...
Cannot burn AVCHD disk. Get this error
The problem with creator 2009 has been fixed by the roxio people.
Instead of burning directly to the DVD disk as roxio software states,
one needs to first save this to be AVCHD movie as a file and then burn directly from the file. This works OK, but as stated this is different
from what the software claims. I'm happy. Thanks
Aug 01, 2009 | Roxio Creator 2009 Ultimate for PC
HELP I made a movie using Windows (Vista) Movie Maker, was able to burn it to a CD-R and it appears to have burned to a DVD-R but it won't play on my DVD - message says: Playback feature not available
Well it looks like you saved it in the wrong format and belave me I done this as well save it as a MPG or AVI and not WMA or WMV your going to need another disc to burn but we all learn from little mistakes I pray it works for you if not you may need to use like NERO instead or ROXIO is good too good luck to you..
May 14, 2009 | RCA Scenium DVD Player DRX400N
Windows DVD Maker for Vista (64) error
Well try to export the movie into mpg format and save it on to the Hard drive... then try burning the disc for any other software... like nero...etc.,
May 05, 2009 | Computers & Internet
Windows dvd maker , vista home premium o/s, hp pavillion laptop
I found the biggest problem with using win dvd maker is when windows asks you to format the disk first. If you do format the disk first then win dvd maker has problems writing to it. Only put the disk in the drive when win dvd maker asks you to other wise you will be taken through to format the disk first and if you choose to cancel that it causes silly problems. If you are trying to make more than one copy of the same disk and win dvd maker is acting up, just do the one copy and then close the program. Then use a program such as nero and make copies from within there. You can insert the disk open Nero and select copy disk, you can do this until you have all of the copies that you need. Personally I found that win dvd maker is too slow and laborious.
Dec 18, 2008 | Computers & Internet
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Problem Event Name: APPCRASH
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Code: c0000005
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Sep 18, 2008 | Computers & Internet
I o magic external dvd burner wont work
most likey it is incompatlable with vista ? did you check the specks lala linda
Aug 14, 2008 | Computers & Internet
Optiarc DVD RW AD-5170A ATA not writing DVDs
sounds like your file is to large by the time it writes in and out or the disks a not to great
Mar 02, 2008 | Computers & Internet
how big is your movie les sthen 4.5 gb ha sto be and u only burn at 8x never full 16x ok thx for using fix ya nick
Feb 03, 2008 | LG GCE 8481B CD-RW Burner
Computers & Internet Logo
260 people viewed this question
David Payne
David Payne
