HOW DO I SET THE HOUR - Audio Players & Recorders
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Audio Player... Master
  • 102,366 Answers
The support page for the RC46 is here.
Posted on Feb 07, 2012
How do I change the time
Best place to start is the manual:
http://waterheatertimer.org/pdf/Raindrip-R673CT.pdf
The manual shows Technical assistance 888-825-4716
Are you wanting to change current time? If not, then read manual, and then add a comment with detailed question and where you are in the steps.
To set current time, or change current time, Press TIME button.
Hour digits will flash.
Use the triangle buttons to scroll up or down and select current hour.
Timer uses 24 hour clock so 11pm is hour 23/ and 9pm is hour 21/ and 1 pm is hour 13.
Press SET to enter hour.
Minute digits will start flashing. Use triangle buttons to select. Then press SET.
Days will start flashing. Use triangle buttons to select. Then press SET.
Sep 23, 2011 | Raindrip R673CT Digital Water Timer
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will work. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers each offer 7 day function with choices of each-day, week-day, or week-end programming. The wider choices with newer timers may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 04, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
This is older timer with backup battery. Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers offer 7 day function with more programming choices... which may explain why TD1000 instructions are hard to find
Set time
Oct 04, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
Memorex travel speaker with ipod dock speaker system black I cannot set the clock on this item
Hold the "Time Set" button until the time starts flashing, then press the "play/pause" button so that only the hour is flashing. Use the ">>" and "<<" buttons to set the desired hour. Once the hour is set, press the "play/pause" button again so that the minute is flashing. Again, use the ">>" and "<<" buttons to set the desired time.
To change to military time from am/pm, hold the "Time Set" button until the time starts flashing, then press the ">>" button. In order to revert back to am/pm, hold the "Time Set" button until the time starts flashing (if it is not already flashing) and then press the "<<" button.
Sep 16, 2010 | Memorex Travel Speaker with iPod Dock...
Decora 6124H Timer
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Jan 04, 2010 | Leviton 6124H 24 Hour LCD Programmable...
How do I switch from 24 hour time to 12 hour time?
Hi greg780,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Oct 12, 2009 | Timex 1440 Nylon watch
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
Hope it helps.
Oct 09, 2009 | Timex 1440 Nylon watch
I have a Zenith ZG120M alarm clock radio. I can't set it.
Here is how I set my ZENITH ZG120M radio alarm clock.
1) PRESS AND HOLD DOWN the HOUR BUTTON and then PRESS the TIME BUTTON to set the correct hour.
2) PRESS AND HOLD DOWN the MINUTE BUTTON and then PRESS the TIME BUTTON to set the correct minute.
To Set The Wake Up Time
1) PRESS and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the HOUR BUTTON to set the desired hour.
2) Press and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the MINUTE BUTTON to set the desired minute.
There are two light indicators that light up on the left side of the LED display...the top light indicator will come
on once the time turns to PM. The bottom light indicates the alarm is set.
Mar 25, 2009 | Timex T309TT Clock Radio
Instructions for Sunbeam clock model # 882-495
Move the second button from the left to set, enter the time in 24 hour format via the HH and MM buttons, then move the button to start. The far left switch, on/auto.off is for the chime. Set to on for 24 hour alarms, set to auto for no chime from 11pm til 6am, set to off, to turn it off.
Mar 29, 2008 | Office Equipment & Supplies
Clock
Press POWER to Turn ON the unit.
Press CD/Door OPEN.
With the Doors Open, on the Inside Right is a "Clock Set" Button... Press it once.
With the Hour blinking, press the "CD-Tuner-Skip" Up or Down Buttons to set hour.
Press the "Clock Set" Button again to make the minute display blink.
Adjust the minutes the same way.
Once the hour and minutes are both set, be sure to press the "Clock Set" button
one more time. Now the Hour and Minute display should no longer be blinking and
you should be good to go. (I just figured it out for myself.) Hope this helped!
Jan 04, 2007 | Fisher SLIM-2000 CD Shelf System
 Grubhead
Grubhead
