Question about Zenith C27A24T 27" TV
Concierge series 25" wont stay on channel 3
I had already deleted channel 52, and the problem still presists. The only channel added to the line up is 3, however when ever the power is turned off and then turned back on, the "start channel" is 52. any thoughts would be great.
    President:
  • 3,130 Answers
If Im not mistaking , some of Zeniths TV sets cannot be unplugged or disconnected from the wall. It will delete the memory and I guess the default channel is Channel 52.. I didnt know you disconnect the set in the ? you asked before. To stop this simply plug the set into an always on wall receptical and turn on the cable then the TV set. your going to need to do this order of operations as I know Zeniths will detune and you wont get any color sometimes if you turn on the TV then the cable. Sorry nothing you can do short of getting another set. Good Luck
Posted on Jul 30, 2006
Hello, I have a Zenith Concierge model number
http://www.manualsdir.com/manuals/228916/zenith-concierge-h25f39dt-concierge-h24f39dt-concierge-h27f39dt.html
Jul 02, 2017 | Televison & Video
My 52 " GE Projection
Tv needs to be realined by adjusting the Screen Drive Controls to Tubes.
Located behind the Front bottom Panel on front of Tv.
Focus/Screen Control Block 3 on top for focus and 3 under them for screendives to each Tube R/G/B.
Jul 03, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
How do i delete a frequency already programed? and can i get a frequency at 46.5000?
Programming a new frequency into a channel automatically deletes and replaces a frequency already programmed. Or, to just delete, and leave an unprogrammed channel, just program 000.000 into that channel
Yes, you can program/receive 46.5MHz. The full tuning range of your scanner is 25-54, 108-174, 406-512MHZ.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Nov 05, 2010 | Uniden BC72XLT Handheld Scanner
Ilo tv shows no tv signal, I believe that the channels are deleted but don't know how to add the channels back
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Jan 08, 2010 | iLO IWT3206 TV
Adding new books into the leapster TAG. I already
The one my kids had (a couple of years ago) could only hold 2 or 3 books at a time. Just limitations of the storage capacity.
Oct 03, 2017 | LeapFrog Tag Reading System w/ Bundle
I installed the converter box on channel 3 instead of channel 4
No reason to delete converter box from channel 3. Most converter boxes have a selection switch on the back for channel 3 or channel 4. Slide switch to 4 and set tv to 4.
Jan 13, 2009 | Televison & Video
My tv wont let me auto program the channels
if you can get to menu to unlock the channels type in 0000 or 1234 or 9999 or 0001 orif this doesnt work you could take back off tv and remove the little battery that looks like a coin out. becareful, this is high voltage in there.........
Dec 13, 2008 | Zenith C27A24T 27" TV
I would like to change the start up channel setting.
if you are using satellite or something that use channel 3 and there are no other channels(cable) do a channel scan from the menu of your tv.if you have an antenna or cable hooked up temporarily unhook it so when you do the scan all it finds is what you have on channel 3.channel scan may also be called autoprogram depending on your tv
Nov 14, 2008 | Zenith Televison & Video
Channel
Press menu key
highlight channel scan memory
press vol+ to highlight number entry area
enter channel you want to enter eg. C16
or if above 100 press and hold the 1 key until C1--pops up
change deleted to added by pressing vol+
Nov 15, 2007 | Sanyo DS27910 27" TV
You have to have the original remote. Then go into the menu under channel set-up. punch in channel 3 press add. The punch in channl 52. then press delete. Or turn on the cable box and go to auto tunnin g and let it do its thing. Im sorry , but if you dont have the original remote with a menu button your going to have to live with your problem. Good Luck
Jul 30, 2006 | Zenith C27A24T 27" TV
Zenith C27A24T 27" TV Logo
219 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
