Question about Makita 4304 Factory-Reconditioned Variable Speed Orbital Jig Saw w/ Case
No power on the jigsaw
There is no power the jigsaw doesnt turn on
  • 2,176 Answers
Could be several problems. If you are mechanically inclined and have a volt/ohms meter I would unplug the tool and remove the handle half and start the process of troubleshooting with the cord,,,, switch,,,, and go on from there till you find the problem. Usually it is a cord or switch that would be the problem.
Posted on Feb 07, 2012
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
How to lock the jigsaw blade to make straight cuts on my Boschest 1587svs?
Use a straight edge guide. Clamp it on the work so the jigsaw can run against it. Be patient and go very slowly.
Mar 04, 2017 | Blade Saws
It dose not starts I don,t know whats wrong
When Jigsaws do not start, you have to check the power to them is good. Try checking the power socket by plugging a light into it instead of the jigsaw.
Sep 13, 2013 | Saws
My carrousel doesnt sping right the pully and whindup mecanism doesnt spin right what should i do
The instructions tell you to sand the gears and apply lacquer. I used a dremel tool to sand the gears and bought spray lacquer for the gears. Perhaps that will help.
May 23, 2011 | Wrebbit Enchanted Carousel Wrebbit 3-d...
I have an old bosch 158IVS uh, what do you call a little reciprocating saw? jigsaw? anyways i can't for the life of me figure out how to change the blade. i've undone every screw. opened up the motor...
well the sawzaw will be drastically different from the jigsaw, but the jigsaw will have either a round twist lock that needs to be turned a little to remove the blade, or two screws that hold a flat plate that clamp the blade. and as for the sawzaw, it will be a twist lock, or a latch lock, the latch lock will look like a lever that needs lifted to remove the blade, and the twist lock is the same as the jigsaw.
Dec 30, 2010 | Saws
Switch capacitor short circuit. Makita jigsaw
This capacitor is only used for RF suppression... really IF it is shorted, then simply remove it. It should work fine without. just be noisy around radios etc. But if you want to replace it Radio Shack, or Radio Spares, should have one.
Feb 14, 2010 | Makita 4329k Top Handle Jig Saw Power Tool...
Makita 4304T. jigsaw blade Do not know how to fasten it?
On the top of the Makita 4304T is a knob, (Top/Front)
This is the blade Installing Lever.
Viewing the jigsaw in the direction you would use it, the Installing Lever is turned towards the Right. Keeping it turned, you then install the jigsaw blade. Once you have the blade up in the Blade Holder, gently release the Installing Lever.
This is a PDF file of the Owners Manual for the Makita 4304T Jigsaw,
(From Makita - Products - Support)
http://www.makita.com/en-us/Assets/images/Products/4304T/owners_manuals/4304T.pdf
[Should the above direct link not work for you, this is Makita - Products -Support, and the download page,
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=248
Left-click on Owners Manual next to the PDF file Icon]
Nov 04, 2009 | Makita Jigsaw Blade
My cordless jigsaw doesnt seem to give out as much power anymore and its not the batteries
The commutator on the motor is probably dirty. Use a light grade sand paper and turn the motor by hand while you clean it.
Jun 24, 2009 | Dewalt DC330K XRP 18v cordless Jig Saw Kit...
Makita 4304 Factory-Reconditioned Variable Speed Orbital Jig Saw w/ Case Logo
117 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
