Question about Directv Televison & Video
My direct tv on main reciever fine until verison made internal adjustments to accomidate my internet. since then my directv does not get a signal on that tv
4 Suggested Answers
  • 217 Answers
SOURCE: Universal remote for DirectV Model D11
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/ge/rm24930-manual.zip&area=other
Posted on Jun 27, 2008
  • 718 Answers
SOURCE: my philips lcd digital tv says I am recieveing
First verify that the direct TV satellite box is set to receive and display digital stations. If you old set on the sat was analog, the box may not have been reset. You may have to contact you satellite provider. Next you will have to go to the TV menu and auto program/scan in the stations. This should pick up all the stations.
Posted on Mar 16, 2009
SD Tech
  • 14553 Answers
SOURCE: HCT TV Model HPP-42HCB Direct TV Remote code needed.
If code not found look to see if this remote has a search mode where every possible code it has can be tried one at a time---it may just not have the code and in that case you are out of luck.
Posted on Apr 23, 2012
Direct tv reciever keeps flashing when plugged in.
Probably a power supply problem. Have you tried switching off at the mains for a few minutes?
Mar 25, 2014 | Directv D11 DTV Receiver
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
Direct tv came with apartment. has never worked says NO Signal on the screen I had cable put in but why pay for somethiing that is already included? I have tried everything but since it is not in my...
Try calibrating the antenna to the nearest satellite. The DirecTV box has in the installation menu instructions on how to do this. You'll need some tools like a socket wrench to unlock and adjust the antenna. Put in the menu your global position or your city and select the transponder that gives better signal. If all satellites are out of signal, move the dish until you receive at least one.
To calibrate the dish from the ceiling or wherever it's installed, put the TV volume up until you hear the short "BOOP" sound from the dish location. When you get signal, the "BOOP" will turn to a continuous "beep" with a higher pitch when higher the signal you're receiving. After getting the best signal, switch transponders to see if there's another with better signal, after that, lock the antenna and try watching a channel.
Nov 04, 2009 | Philips DIRECTV H20 DTV Receiver
My directv d12-300 receiver won't take the software download why?
Because the reciever has a internal issue. you will have to call directv and get a tech to bring a new one. to redo, turn of reciever and when you see the blue light power press 02468/
Jul 18, 2009 | RCA DRD430RG DirecTV DTV Receiver
Sharp 37" LCD/TV will not remain programmed with DirectV. DirectV technicians have come out to re-program the Sharp TV. They simply say over and over again that it is a Sharp problem. They keep telling me...
First of all any make or model tv will work with any directv receiver as long as it is connected properly. In my expierence Sharp TVs are compatible with all directv recievers. Is the directv remote not functionly properly with your sharp tv or do you have a black or snowy display. Your tv has to be on correct input in which the technician should of educated you on this instead of suggesting the purchase of a sony branded tv. Black or snowy display indicates the wrong input. Using the tv remote find a button labeled source or av or input and try pressing that button until you see a picture. otherwise call directv tech support at 800-347-3288 and demand that this issue is resolved immediately.
Mar 09, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Direct Tv Receiver No sound Black Screen
unplug the power from the reciever for a few moments. plug it back in and let it load. once its finished turn to channel 201. Usually it the reciever is on an unavailable channel (channel with no programming) when it restarted it will go back to that unavailable channel hince the black screen and no sound.
Jan 01, 2009 | Philips DIRECTV H20 DTV Receiver
Blurry text on 27-inch Zenith "Sentry 2"
I have had this problem before and restarting the reciever fixed it. Just push the red button under the front panel of your reciever, or unplug the reciever for a minute or so.
May 13, 2008 | Zenith B27A11Z 27" TV
Off Air?
The Scientific Atlanta box was a cable box and recieved CATV signals. The Direct TV box is satellite only. You might check if it has a built in ATSC tuner for off air digital signals. Direct TV in most locations offers the major networks in HD format.
Jan 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
DIrectv Sat internal box.
You can try eliminating whethor or not the receiver is actually the problem by moving it to another TV and seeing if it works on one that isn't having any problems. Or moving a working receiver onto the TV to see if it will pick up signal with a working receiver. If you don't have any receivers in your house working, then odds are something needs to be serviced outside your home, like the Dish and/or LNB.
Did DirecTV actually come out to the home and troubleshoot at the site? If not, they would have no way of knowing if it's the TV or Satellite that's causing the issue.
Aug 09, 2007 | RCA F38310 38" TV
Sharp 27F-630 27" TV
Dear eligas1312, Most probably your antinna is not reciving TV signals properly.Try to adjust it in a right direction at a proper height, also adjust frequency of various channel of Direct TV through menu button. regards ajay
Aug 04, 2007 | Sharp 27F-630 27" TV
Televison & Video Logo
24 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
