Question about Vizio Televison & Video
Hook up headphones to vizio E321VL - Vizio Televison & Video
4 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: My vizio E321VL freezes when i turn it on
does it do it on all inputs including a DVD player etc?
Posted on Apr 18, 2012
SD Tech
  • 14553 Answers
SOURCE: I need to program my remote the tv vizio E321VL
If the set does not turn on:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
Posted on Jun 03, 2012
jeffthern
  • 3 Answers
SOURCE: Need Vizio E321VL TV Stand Screws
I have a M420VT Vizio TV. I used (4) M6-1.0 x 16mm screws to attach the stand to the TV stand adapter. The screws I used to attach the adapter to the TV were (3) M4-0.7x12mm. It worked out perfectly!
Posted on Jul 27, 2012
What do I have to do to hookup a headphone to my 60 in vizio TV?
Without opening set, easiest thing you can do is hook up a small receiver to the audio outputs of tv and then plug your headphones into the headphone output of receiver. And when not using the headphones you can always hook up some external speakers to the receiver - they will always sound better that the speakers that come with the tv.
Feb 23, 2017 | Vizio Televison & Video
Vizio E321VL has no back light
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Oct 28, 2016 | Vizio e321vl 1080i 720p hdtv
E321vl no power. could this mean bad logic board?
The downside of a product getting a power surge is it will never be just right. It is not worth the cost to repair it. Consider buying a new TV instead. Suggest a Smart TV.
Mar 24, 2015 | Vizio Power Supply Input Main Board Unit...
I have a vizio E321VL its an LCD and recently the screen went black. When I turn it on the vizio logo comes up and backlights come on but then screen goes black. Ive tried changing input or changing...
Vizio had problems with the processor boards.
If you had no lights, I would say power supply, Logo with lights, I would go with Processor board, check ebay. It is called a main board and they run about $60. That is what I would get, but then again, how old is it? If I could replace it with a new for $250 why take a chance for $60. I have pitched them before.http://www.ebay.com/sch/i.html?_odkw=E321VL+main+board&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR2.TRC1.A0.XE321VL+main+board+refurbished&_nkw=E321VL+main+board+refurbished&_sacat=0
You tube also have videos if you are a electronics repair person.
Oct 31, 2013 | Televison & Video
Fuse locations for Visio E321VL tv
Try to download the repair manual to this set by internet. It has all details.
Aug 17, 2013 | Vizio 32" E321vl Flat Panel Lcd Hd Tv Full...
Take subtitles off vizio
closed captions can come from either the set or a cable or sat box hooked up and active----check both in set and the box to turn them off.
May 15, 2012 | Vizio E321VL 32-inch 720p LCD TV...
Feb 19, 2012 | Insignia Televison & Video
No sound with new Vizio 22" LCD TV being used as monitor
you have to hook up the 1/4 headphone jack plug to the TV, from the computer. an Y audio cable with RCA plug (male) with headphone 1/4 male plug. hook the headphone jack to the green hole of the computer(sound out) to the audio input of the TV better yet to a stereo AUX port. also make sure the mute button hasnt been pressed.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 03, 2008 | Dell Dimension 4600 PC Desktop
Televison & Video Logo
212 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
