Question about Apple iPod touch
How do i reset my ipod - Apple iPod touch
    Top Expert:
  • Apple Master
  • 76,673 Answers
Please click here.
Posted on Feb 07, 2012
Ipod disabled want to reset.
there is no way to reset an Ipod fully without a computer. But if you go to settings>General>and at the bottom reset you can reset certain things on your ipod such as certain settings.
Nov 15, 2013 | Apple iPod touch
Ipod will not turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod.
When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch.
Press any button to turn on iPod.
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet.
Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge.
iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes.
If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Sep 08, 2013 | Apple iPod Audio Players & Recorders
Ipod wont turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Apr 16, 2013 | Apple iPod touch
Ipod does not power up
Mar 24, 2013 | Apple iPod Audio Players & Recorders
On the ipod 20gb after apple logo comes then bettry logo comes
Reset Click Wheel Ipod (newer ipods including resetting an ipod video)
1. Flip the Hold switch on and off and make sure it ends up no longer on hold.
2. Press and hold the Menu and Select buttons (center Button) until the Apple logo appears (may take 5-11 seconds, and you may need to repeat this step)
If this not work for you try plugging your ipod into computer or wall power
Resetting iPod (with dock connector)
Most problems with iPod can be solved by resetting it.
To reset iPod:
1 Connect iPod to a power outlet using the iPod Power Adapter.
2 Toggle the Hold switch on and off (set it to Hold, then turn it off again).
3 Press and hold the Play/Pause and Menu buttons for at least 5 seconds, until the
Apple logo appears.
If Your iPod Won't Turn On or Respond
* Make sure the Hold switch is off.
* If you're using the iPod Remote, make sure the remotes Hold switch is off.
* If that doesn't work, connect iPod to the iPod Power Adapter and connect the
adapter to a working electrical outlet. Your iPod battery may need to be recharged.
Resetting iPod (with out dock connector)
If that doesn't work, your iPod may need to be reset.While the iPod
is connected to power, press and hold the Play and Menu buttons
for at least 5 seconds, until the Apple logo appears.
Mar 03, 2011 | Apple iPod classic MP3 Player
How to use an ipod shuffle charge
Use iPod Reset Utility to restore the following iPod models back to their factory settings when iTunes is unable to do so. The process completely erases all music and data and reinstalls the iPod software version listed below:
  • iPod shuffle (1st generation) - iPod Software version 1.1.5
  • iPod shuffle (2nd generation) - iPod Software version 1.0.4
download here
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_4_for_Windows
then install..
follow these instructions..
Using iPod Reset Utility
  1. Quit all running applications on your computer.
  2. Open iPod Reset Utility.
  3. Connect iPod to a USB port on your computer. Do not connect iPod to a USB port on your keyboard, or other non-powered USB hub.
  4. Click the Reset button.
  5. If prompted, enter an administrator name and password. Notice: Do not disconnect iPod during the reset process.
  6. When complete, quit iPod Reset Utility and open iTunes to load music onto iPod.
Jun 05, 2010 | Apple iPod shuffle MP3 Player
Ipod will not play properly after connected to Vm9512
Well, the screen issue you are describing with the ipod sounds like the ipod's clickwheel is malfunctioning. A malfunctioning clickwheel will allow you to reset the ipod, but not actually make selections. At this point, you can either replace the clickwheel or if your ipod is under warranty, take it in for service.
*I am assuming that you are actually resetting the ipod correctly. For example, when reset, after bootup, the ipod will ask you to select a language. If you are not getting to that screen when you "reset" it, then you are likely doing it incorrectly. If that is the case, I'd suggest checking your HOLD button before suspecting a bad clickwheel. Since there are slightly different procedures for resetting ipods depending on model and generation, I'd suggest doing a search online (or going to Apple's website) for instructions on how to reset your particular model. Note that ipod generation can be easily found printed on the back case of the ipod.
Jan 06, 2009 | Audiovox VM9512 Car DVD Player
Cant unlock ipod
if you give the correct password it must unlock.
else do a reset so that the password gets resets
Oct 21, 2008 | Apple iPod nano
Apple ipod 20gb
Try a reset:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog at:
http://www.pchelpforanyone.blogspot.com
Apr 03, 2008 | Apple iPod nano
Apple iPod touch Logo
14 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
