Question about Panasonic Heating & Cooling
Manual for Panasonic - CS/CU-E9JKR - 2.6kW - Panasonic Heating & Cooling
5 Suggested Answers
  • 534 Answers
SOURCE: Panasonic CS/CU-A242KR Air conditioner leaking water
OK lets see what we can help you with here. The condensate drain is clogged. There are a couple of ways to clear this clog so lets give it a try. If you know where the drain for the a/c is located outside (usually by the outside condenser unit) it will be a pipe that is just sticking out of the side of the house, if you find it take a wet/dry vac and place it on this pipe and turn the vacuum on and make a seal with your hand this should unclog the drain. If you don't find this pipe outside the house then go to the furnace and you will see at the bottom of the furnace a pipe (PVC) white, this is the drain for the unit inside. Take the wet/dry vac and have it at the ready in the event the clog is further down the line than at the furnace itself now the fittings on this pipe should not be glued together due to the ability to access for this very purpose. Take the pipe apart at one of the fittings and place the wet/dry vac on the end of the pipe towards the furnace and using your hand make a seal and evacuate the line. Do this to both sides since you don't know where the blockage is. If you are unable to separate the pipe at any fitting you will need to cut the pipe and at the spot of the cut you will need to repair it with a sleeve. Remember that the drain pipe is plastic and is made of pvc so you can get a repair coupling from any home improvement store for this repair.
Hope this helped you some
Dave
Posted on Feb 21, 2010
hvac1960
  • 2133 Answers
SOURCE: FAULT CODE H19? WHST IS
H-19 Error code means indoor fan mechanism locked. replace fan.
Posted on Dec 12, 2010
candgbabu
  • 53 Answers
SOURCE: I've purchased an 1 ton
I am not understand your location. please call Panasonic customer care.
Posted on Mar 26, 2011
SOURCE: Panasonic CS-W24DKR/CU-W24DKR not responding to remote control
to easily test remote,turn mobile phone camera on and operate remote with infe red end looking at phone camera,if remote is working you will see a white light on camera,if u get a light on camera reciever in wall unit may be faulty.
alan @zia airconditioning.
good luck
Posted on Dec 28, 2011
Panasonic heat pump timer light flashes
check if it is poor contact .or current is too small.
wall light
May 20, 2012 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
PARTS OF CU PC24DKQ
Hi
You can buy the parts from any of these links:
Link 1
Link 2
Hope this helps...please post back for further assistance.
Daniel
Jan 19, 2011 | Panasonic CS-A12C Air Conditioner
FAULT CODE H19? WHST IS IT? panasonic air conditioner cs/cu-e18jkr.
Dec 12, 2010 | Heating & Cooling
Split system not starting up for about 10 mins after turning on
Hi Wendy,
The manual for the unit is at this link. This should answer all your questions. http://panasonic.com.au/products/details.cfm?objectID=4601 then go to the bottom of the page and click on CS/CU-E18_21_24_28HKR Operation Manual
I take the time to answer you questions so please rate me
Thankyou
Mat
Jun 10, 2009 | Panasonic MCM INVERTER
Air con timer flashes cs/cu-e24fkr
likely it is low on battery juice . open it and replace
Jun 04, 2008 | Panasonic Heating & Cooling
Heating & Cooling Logo
428 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
