Question about Thermador C272 Electric Double Oven
Thermador ct127n-04 d/o
Have to change the selector switch, how do I take the control panel apart?
Thermador oven control panel light is very dim
FixYourBoard.com fixes this problem, and they back their work with a two year warranty!
See the photos of what your new display will look like below.
Feel free to ask questions-- info@fixyourboard.com
Apr 24, 2017 | Thermador Ovens
I need a selector switch part # 00415047 for a Thermador oven that does not maintain heat.
I found these can usually disassembled, cleaned and returned to service. A really handy tech would do it for you, but usually just independents.
Nov 08, 2013 | Thermador Ovens
I need a replacement selector switch for an electric oven. It it for an old Thermador electric oven (one cavity type wall oven). Model number: WO-18A
Hello & Welcome to FixYa
You can buy it from here. Please get back to me if you have any other questions.
Kevin
Sep 13, 2011 | Thermador Ovens
The control panel is very dim on my Thermador RDSS30 oven
Cannot Read Display or See Temperature Thermador RDDS30
FixYourBoard.com repairs this failure and back their work with a two year warranty.
May 14, 2011 | Thermador Ovens
CODE F64 WHEN TRYING TO USE THE BOTTOM OVEN.
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Mar 29, 2011 | Thermador C302U Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
I need to change my neff oven u1744N0GB selector switch. I have a new one, but need to know how to change it out.
pull of control knob first, remove oven from housing and remove top panel undo 2 screws holding selector to fascia withdraw it back into top and change wires there will be quite a few dont get them mixed up! reverse to reassemble.
May 20, 2010 | Neff Ovens
The upper oven works fine. The lower oven won't
Make sure you hit the reset switch first... on top of the lower over... behind the panel...they trip easy and "kill" the oven.
Nov 27, 2009 | Thermador SC302T Electric Double Oven
Thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Nov 16, 2008 | Thermador SMW272 Electric Double Oven
Thermador C272 Electric Double Oven Logo
94 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
