Question about Cooktops
Electrolux Electric Hob EHE 683 X
How does one change the indicator lamp?
The only way into the Hob seems to be via the hole into which the Lens/Lamp assembly fits. Since the lamp wires are fitted with spade connectors, how is one supposed to get at the terminals?
Regards,
Harry
3 Suggested Answers
  • 222 Answers
SOURCE: Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Posted on Jan 11, 2009
SOURCE: electrolux insight cooker EKT6045 problem with hob controls
i have an electrolux model ekt 6045 it does not stay on it comes on for 1sec then goes off wot would be the cours of this please the oven stays on but the hob doesent thank you.
Posted on Dec 30, 2010
Induction hob not heating up. What does 5h or SH error code indicate?
if they are not steel bottomed pans they will not work with induction hob test them with a magnet
Apr 07, 2013 | Smeg Cooktops
We have an electrolux gas hob and it seems as if the electric spark ignition is stuck and it is clicking all the time on all four burners. Wonder if you have any suggestions ??
The problem is one(or more) of the 4 switches that turn on the spark when that burner is turned on is shorted and stays closed (on) all the time.To determine which one it is the face where the knobs are has to be removed,with THE POWER OFF a meter set to low ohms rating is used to check each switch by removing the wires to it and see which one has continunity (ZERO OHMS) when its off and that switch that slips on the burner valve shaft is the bad switch(s) and needs to be replaced to keep it from sparking all the time.
I hope this helps you to repair your cooktop,
Gene
Aug 07, 2011 | Electrolux Cooktops
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Electrolux EOB976: cooker hose or copper pipe?
The regulations state that the proximity of the hob to the cooker would dictate the use of a copper pipe to supply the hob.
Hope this helps.
May 26, 2010 | Cooktops
We have had a gas hob installeed by an expert!! However it just sits in the hole cut in the worktop and wobbles and is therefore not level.. Should a support of rubber have supplied with the hob or is it...
i think it should have been sealed with silicone around what happens if something boiled over where does the water go ? get it sealed and thats stops the wobling as well
Oct 28, 2009 | Electrolux 23 in. EGG689 Gas Cooktop
Electrolux insight cooker EKT6045 problem with hob controls
Aug 11, 2009 | Electrolux Cooktops
Jan 09, 2009 | Cooktops
Indicators
the 'L' means locked - to unlock turn on hob, hold down front right hand side plate control and minus botton to unlock - see manuals for further details
Sep 22, 2008 | Baumatic 23 in. B10 Electric Cooktop
Converting gas hob to electric hob
If you are in the USA most codes require a seperate circuit for the oven and the cooktop. Most cooktops require 30 amps and at least #10 wire.
Jun 09, 2008 | Cooktops
Cooktops Logo
123 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
