Question about Intel Motherboard
No pictures they are no pictures but it has all the channels i needed
  • 89 Answers
So.. What's the problem?
Posted on Oct 28, 2008
Have a used Emerson tc1375a hooked up to cable only gets channel 3 and 4 picture is great. Does it need to be reset or what can I do
Usually a TV must be set to either channel 3 or 4 to receive a TV service provider such as cable or Direct TV. The service provider now controls your channels and broadcasts on either channel 3 or 4. You choose channels from what ever equipment they gave you which is usually not the remote that came with your set. You may need to check the way you are set up. If you are using an antenna go into the menu on the TV and make sure it is set to antennae not cable. This may also be the problem. Good luck.
Feb 19, 2015 | Emerson Televison & Video
Cannot get a clear picture with dish network I have a Clear picture when using DVD
Sometimes the input/channel for the DISH Network and the DVD are different, and if using the same for both, then you will get an unclear picture on one. If at TV1, the tv will need to be on channel 3 or 4, and possibly an input such as video 1 or 2. The DVD player may be on a different input, such as video 3, or even just on channel 3 only. If at TV2, the tv needs to on channel 60 or 73. When using the DVD, try putting the tv on channel 3 or 4, that is normally the channel that the tv needs to be on. Also, make sure that the DVD player is not on while you are trying to watch just the dish.
Becki Barned
DISH Network Customer Service
Dec 03, 2010 | Apex Digital LD4088 LCD TV
I chose the wrong channel on remote it took me to a Dish site whcih I chose to exit - when I did that my picture totally disappeared - could not get it back. It is fine on my other tvs - so I need to get...
Are you getting a snowy/blue/black screen on your TV? To get your picture back, you need to get the TV back to the correct channel or input. If the receiver is in the same room as this TV, the TV should be on channel 3/4 (normally 3) or an input setting depending on the TV. TV 2 (away from receiver) would be on channel 60/73. If you have the TV remote, put the TV on one of those channels. If you get a picture when the TV is placed on the correct channel, press and release the SAT button. This puts the remote back in SAT mode and will now operate the receiver.
If you don't have a picture, unplug the receiver for 10 seconds from the electrical outlet and plug back in. This will cause the receiver to reboot and re-acquire Satellite signal. i hope this helps.
Ray Calo
DISH Network
Jun 30, 2010 | DISH Network IR Remote Control
How do I get the picture?
The TV is usually set to Channel 3 or Channel 4. You may have a switch on the back of the VHS recorder near which is marked Ch3 Ch4.
Once you correct this, try the following procedure.
Some VHS have a tracking button that allows the user to tune to the best signal. The tracking can also be done from the remote controller.
Usually that tracking function is used as follows.
While movie is playing on the VHS unit and signal gets fuzzy, press the channel key repeatedly (for example >> to increase the channel number). f after awhile pressing the same channel change button does not find a better picture, you should press the other channel change button (to decrease the channel number <<) to see if the picture improves.
If that does not work, IT DOES NOT MEAN that you tv/vcr combo unit is defective. It could just be the movie. The tape is magnetic and it might have been accidentally demagnetized.
If picture is better with another movie/tape, your unit is definitely OK.
May 20, 2010 | Memorex MVT2135 13 in. TV/VCR Combo
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Need to see a picture of connector that holds window to channel it has fallen down
I do not think that there is such a picture...By window channel, do you mean the rubber/felt material that the glass touches? Where exactly has this come apart.
Typically all of these rubber channels are inteferance fit into a metal channel.
Sep 16, 2009 | 1999 Pontiac Grand Am GT
32LG3000 LCD TV shows no picture when resuming from standby
It seems just channel stored data issue.
Please perform Auto Preset / Auto Channel / Auto Tuning (mentioned menu items) and store all channels again.
Hope problem will resolve.
Dec 18, 2008 | LG 32LC7D Television
Color problem
Please fine tune those B/W channels to obtain color picture. If TV is more then 4 - 5 years old, it needs resoldering in tuning area or might need replacement of IF block.
Aug 01, 2008 | JVC AV-21meu 21" TV
My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Oct 15, 2007 | Televison & Video
Panasonic screen problems
Then recently, these additional problems: 1. The picture cannot be restored by turning off then on. 2. Sometimes, several channels will have the same picture. 3. Sometimes several channels will have the same ghost-like picture. the above all problems are due to one that is weak signal. 1 check for antena or cable or satellite input is ok or wire might be defective due to old. 2 input socket is loose some where. 3 loose contact near tuner or some print break. 4 at last & final its tuner might be defective. hope this will help.
Oct 03, 2007 | Panasonic CT-36D32 36" TV
Intel Motherboard Logo
18 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
