Question about Leica LRF 800 Laser Rangefinder
Leica disto classic 5a
My leica disto classic 5a wont measure over 25 metres in outside conditions even with a reflector, Battery reading shows 4 bars.Error is always 255. Using the viewfinder i cannot see the beam anymore than 15 metres. This thing is supposed to measure up to 200m. I have tried it with a tripod and in my hand still no better. Reflector i used is the on that ships with the hilti pd20. Any ideas anyone
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: leica disto classic 5a
The optical lens of a laser rangefinder must always be kept clean for optimal performance.
The most common cause for a reduced range on this devices, is caused by dirty, or defective lens.
If the lens are dirty, on the outer or inner side, or they are opaque or defective, or there is wet inside the lens, than that is the cause for the sensibly reduced range.
Posted on Oct 24, 2008
What does error 270 mean?
There is no error code 270 listed for a Leica Digital DISTO D3a 100M Laser Distance Meter.
Are you sure that's the code?
Or do you have a different make or model of laser distance meter?
Sep 06, 2016 | Leica Digital DISTO D3a 100M Laser...
the only thing which comes to my mind is that
the laser may have become weak ....
did u try with new batteries..
ne way the new ones also cant measure more than 200 m...
the device might be loosing its strength..(maybe that guy had used quite a few times)
Oct 22, 2008 | Leica DISTO A5 Rangefinder
My leica disto A5 is not measuring more than 2.5 meters , if i measure more thank 2.5 meters it give info 255
First, insert brand new Duracell batteries. Then you might try cleaning the optics with a Q-tip and some rubbing alcohol. A 255 error indicates that the unit is not getting a strong enough signal, essentially that not enough of the laser is getting back through the optics to the sensor. If these don't make a difference, contact the dealer you bought it from, it may be eligible for the Leica repair program. (good luck if you bought it off ebay or from an unauthorized dealer)
Mar 06, 2015 | Leica DISTO A5 Rangefinder
Does not measure distance
Put in new batteries, clean lens, and calibrate. If this does not work, type " Leica Disto A6 Laser Distance Meter user manual " into computer search engine. It will bring up sites for manual.
Oct 18, 2014 | Leica Disto A6 Laser Distance Meter
Leica disto
Low battery. Mine does that when batteries are too low to operate the laser.
Aug 20, 2013 | Optics
Leica Disto D3a shows ERROR 220
I had this exactl problem and resolved it by replacing the batteries
Feb 19, 2013 | Leica Digital DISTO D3a 100M Laser...
Always get error 279 on my Disto Classic
Put in new batteries and clean lens and calibrate if it has that function. If that doesn't work, Type the " Leica Disto A6 Laser Distance Meter user manual" and it will bring up sites to manual.
Jun 28, 2011 | Leica Disto A6 Laser Distance Meter
After I changed the batteries for my Disto A6 the screen stayed blank. I see the laser beam and beep. but nothing in the screen.
MY LEICA DISTO D5 SCREEN DOES NOT LIGHT UP ALTHOUGH THERE IS LEISER AND READING. HOW DO I RECTIFY THIS.
Jan 18, 2011 | Leica Disto A6 Laser Distance Meter
Disto A3 - problem acquiring readings over 3-4m
A short rectangular "dot" is normal, a 255 error indicates that you are not getting enough reflection back to the optics. This may be due to the surface you are aiming at. Try placing a piece of white paper over the surface, if it does not measure 30 or 40 meters to a sheet of white paper, indoors, and the optics are clean, I'd contact your dealer to initiate a warranty claim. 3 or 4 meters should not be a problem unless the surface is very rough, such as dirt or sand, or very dark color.
If you just bought the unit from a licensed distributor, you should have at least a two year warranty, possibly 3 years.
Greg DeTray
www.distagage.com
Aug 27, 2009 | Leica DISTO A5 Rangefinder
Getting error code 279 on my Disto Classic 5a
can not measure distance.
each time the button is pressed dist, 279 error appears.
Aug 12, 2009 | Leica Disto A6 Laser Distance Meter
Leica LRF 800 Laser Rangefinder Logo
478 people viewed this question
Top Leica Optics Experts
woodzowl307
Tom Chichester
Bill Boyd
Are you a Leica Optic Expert? Answer questions, earn points and help others
