Question about Dishwashers
My dishwasher is not cleaning properly. It leaves dirty gritty water which sticks to glasses cups etc
I have cleaned filter and tried a dishwasher cleaner - which helped a bit for a week or two. Is there a home made cleaner that can clean the pipes maybe?
  • yadayada
    yadayada Feb 07, 2012
    Would you please rate my help for Fixya.com. Thanks
    Top Expert:
  • Dishwashers Master
  • 76,848 Answers
Run a product called "CLR" through the washer, that should do the trick, you may need to repeat it once a month. You can get this at any Hardware store throughout the USA.
Posted on Feb 07, 2012
  • lyndall666 Feb 07, 2012
    thank you very much Dennis
SOURCE: Dishwasher never cleans, glasses gritty dirty -- Bosch terrible s
you obviously need to check and make sure that you've cleaned your filter system. it needs to be cleaned every couple of months. and also make sure that your washing fans, the ones that spray water, aren't clogged. they need to be washed out and de-clogged regularly as well... i had this same problem.. but it worked fine once i cleaned the system.
Posted on Sep 24, 2009
  • 111 Answers
SOURCE: GE Profile PDW9200J dishwasher leaves a film and dirty dishes
Sounds like you have an excessive build up of hard water (mainly calcium) in it. Clean it like this: Close the detergent cup cover. Run hot water at the sink to clear cold out of the pipes. Start the machine on pots and pans/added heat. Wait about 10 minutes and open the door. If the detergent cup cover flops open, it is in the main wash. If it is still closed, let it run a few more minutes, check cup cover again, keep dong this until the cover is open. Once it is open it will be in the main wash (the longest cycle) and at that time put in about 2 cupfulls of Tang orange drink in the bottom of the tub. Tang is very high in citric acid and will clean the calcium and other hard water deposits from the tub, pump, spray arms, ect... Make sure your hot water is HOT (130 is great) and use Cascade Complete powdered detergent from now on. Should take care of it... Repeat every 6 months to keep it clean.
Posted on Dec 20, 2008
wheelshot
  • 102 Answers
SOURCE: Dishwasher
Make sure not to prewash your dishes before you put them in the machine. The water needs to be dirty to activate the enzymes in the detergent. Are the dishes coming out cloudy? Also a sign of prewashing your dishes. Use only powder detergent and clean your machine by running 2 cups of vinegar on hottest cycle once a month. No gel and no tabs. They cause a build up in the unit and causes poor performance. Use rinse aid. Hope this helps.
Posted on Apr 11, 2009
SOURCE: Bosch HydroSensor Dishwasher (SGS5342GB/17) -
Hi Julie,
The sprayer arms may need replacing.
Posted on Aug 21, 2008
woodchuck789
  • 4070 Answers
SOURCE: My dishwasher is leaving gritty, sandy particles
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Posted on Jul 12, 2010
Glass plates have "splashed" looking
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 21, 2010 | Whirlpool Dishwashers
Sandy grit left on dishes.
I was having a different issue with the same model but I think my issues solution might help yours. My dishwasher was not draining properly. It was the air gap that sits on top of the counter by the sink. It was clogged. We removed it and cleaned it out. Maybe if your air gap is slightly clogged as well it is not allowing the dirty water to flow out properly leaving you with gritty dishes. Hope this helps.
Jul 20, 2010 | Amana 24 in. ADB1200AW Built-In Dishwasher
Sep 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher
Mar 29, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Cutlery is cloudy and dirty, some food is dried onto knives and forks. Cups and glasses are cloudy and not clean on inside. Coffee or tea stains are not removed. Plates and soup bowls seem OK , and water...
they must have changed the way they treat the water in your area. those spots are caused by hard water. www.dishwasherfilter.com has a product out for this problem. it filters the water going into your dishwasher leaving them spot free and crystal clear with every load. you will love the way your dishes look.
Mar 21, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
My indesit DI620 isnt rinsing the contents properly
its the same water that rinses both sections just different arms, the one directly under the top basket usually cleans both cutlery and top basket. it could be a posibility that the arm itself is contaminated with waste that is too large to push through the holes and is now breaking up making a mess on teh glasses. (I have seen it before with melon seeds) remove the arm and rinse backward under a tap.
make sure that the salts are topped up as well this is very important if the salts run out you will not regenerate the resin beads which are used for water purification on the last rinse so this could also rinse with dirty water.
Nov 21, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Gritty white film all over dishwasher and dishes
Another way to descale your dishwasher is to use vinegar. This is also very inexpensive. Put a cup of vinegar into the dishwasher and run it, allowing it to go through all cycles. I would turn the heated dry off.
Please rate this solution
Aug 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
White Residue
most likely it is your detergent. palmolive eco is notorious for leaving a white chalky residue on dishes. try this out before calling a service tech: put unclean glasses in the dishwasher and in your soap dish and rinse cycle cup put 1/2 cup of distilled white vinegar. if it cleans (or improves) your dishes, then your detergent is the culprit.
Jul 29, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Hotpoint Auqarius dishwasher. I have resentley moved house and reconnected the machine. it works through programme fine but is sometimes leaving dishes gritty and not quite clean. I have cleaned filters,...
It sounds like there could be a gritty deposit in the bottom of the system. At the start of the cycle the unit takes in a set amount of water and recycles it around to the drying phase.
Try and run the diswasher a few times with no items in it - this will may help to flush it out.
If the gritty deposit coloured white this could be that your new home has more limescale in its supply. Try getting dishwasher tablets with limescale protection to see if that helps.
Finally, please ensure the spray arms free to rotate on each cycle. Failure to do this leaves grit on certain items and not others.
Please dont forget to rate.
Jul 07, 2008 | Dishwashers
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
