Question about Sanyo Televison & Video
Why does ......loading epg keep coming up at the bottom of my screen... then there is a bar that i cannot get rid of??
  • clark83297
    clark83297 Feb 07, 2012
    Mine is doing this also!
  • clark83297
I went into menu went to the lock folder selected ALLOW UPDATE press ok to access its menu, the ACTIVATE item is highlighted automatically. press < or > to select ON. after i did that i exit menu and turned tv off for about an hour turned it back on and it hasn't come back on.
Hope this helps
Posted on Feb 07, 2012
EPG WILL NOT WORK ON PHILIPS 42PFL9703 TV
Philips - Support Forum
www.philips.com/supportforum
PhilipsHere you can discuss all topics related to using Smart TV and Smart TV apps. Also find topics on IP-EPG, HbbTV, MHP, and Google Play store apps on Philips TVs Powered.... First of all JorisM, you're not the only one with this kind of Problem.Missing: 42pfl9703
No EPG data when using WEP EPG ' MediaPortal Forum
forum.team-mediaportal.com > ... > Electronic Program Guide > WebEPG
Jan 1, 2010 - Remote: Microsoft remote. TV: Philips 42pfl9703. TV - HTPC Connection: HDMI Hi, can use some help here. I can not get web EPG to work.
Powerscheduler shuts down PC too early during WEB EPG grabbing ...
Feb 8, 2010 - TV: Philips 42pfl9703 ... I found that data is loaded, but randomlystopped. ... EPG grabbing is busy, but still the system shuts down to early.
DVDR 7250H missing EPG problem - Philips - Digital Spy Forum
Jan 30, 2016 | Philips Televison & Video
How do I remove the bar which appears on the bottom of my screen after the TV says it is loading EPG?
Contact the authorized service centre. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 01, 2014 | Televison & Video
Can't get rid of electronic program guide on screen of palsonic tftv8060mw it appears on screen automatically after 1 minute and won't go away! EPG button on remote does nothing
Go into the TV background Menu options and search out the program guide settings that should be there. Turn off the "always on" setting.
Dec 26, 2012 | Televison & Video
EPG LOADING THEN BLACK SCREEN
Elderly couple downstairs had the same problem with their Sanyo TV this morning, the tech has just left, he has never heard of this problem before, however he reset the factory settings in options and all is okay AT THE MOMENT.
Feb 07, 2012 | Sanyo 42 in. LCD TV
We have an LG LCD television - we have had a menu appear on the screen...which gives 5 options...audio channel, epg and a couple of other options...it just stays on the screen and we can't get rid of...
first u remove the cells of remote. if the menu appears then we are sure that remote is working properly & fault is in tv. then find the menu button on the front panel. when menu appears operate with panel switches. if menu disappears & come again it means that any of the front panel switches is stuck. u need to replace the front panel switches or if it does not disappers the main board is defective.
Sep 21, 2011 | Televison & Video
Will not record from EPG settings but will record on 'live' record ie whilst already watching a program. Tried all usual reboot tricks but to no avail. Please note the forward recording schedule list has...
mikelake735
If you have DISH Network equipment, you can try a check switch test on your receiver so the receiver can update its information from the satellite. With the DISH remote press the Menu button which will display Main Menu on the TV screen.
Press 6 (System Setup), 1 (Installation), and 1(Point Dish). Highlight the CHECK SWITCH button on the upper right of the screen and press the Select button on remote. On the Installation Summary screen, highlight the TEST button at the bottom of screen and press the Select button on the remote. This will initiate the test. Allow the test to complete. Once completed, exit out of each screen till you get Acquiring Satellite Signal on TV screen. After acquisition completion, allow it to download the program guide. If this doesn't fix the problem, you may need a new receiver. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
Can't get EPG to display after set up
johnandja460
You haven't specified which type equipment you are experiencing the problem. With our DISH Network receivers, if the EPG does not display you can do 1 of 2 things. First, unplug the receiver from the electrical outlet for 10 seconds and plug back in. This causes the receiver to reboot and re-acquire satellite signal. Then it will download the EPG.
If you still don't have the EPG, you can then run a check switch test. Press the Menu button on the remote. Main Menu will display on the TV screen. Press 6 (System Setup), 1 (Installation), and 1 (Point Dish) on the number pad. Highlight the Check Switch button on the right of the screen and press select. On the Installation Summary screen, highlight the Test button on the bottom left. Press select. The receiver will perform a switch installation check. After the test is completed, exit out of all screens till you are back to the TV screen. The receiver will acquire satellite signal and download the EPG. I hope this helps.
Ray Calo
DISH Network
Jan 19, 2011 | Sony Televison & Video
My jvc lt32de1bj TV has very slow loading epg. Is there a quick fix to speed it up
I'm afraid not. The loading of EPG programme tames is down to the TV transmissions. Some times you may hit lucky and find the EPG guide straight away, othertimes I have waited 5 minutes for a basic list!
Jan 02, 2011 | JVC Televison & Video
Pioneer dvd recorder dvr-530H
The EPG is the electronic program guide trying to download TV listings.
http://en.wikipedia.org/wiki/Electronic_program_guide
This is normal for this player. To disable this, you would need to turn off the TV guide function.
Sep 28, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Televison & Video Logo
244 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
